Arborwear
Author Topic: Tobacco Barn---Kiln  (Read 2777 times)
Offline Randy
Tobacco Barn---Kiln
« on: January 26, 2005, 10:31:46 AM »
Is it possible to convert these "Bulk" tobacco barn's to dry lumber in? I have several farmers that are selling out----------that have some of these barn's for sell. These barns move and look like shipping contaners except that they have a gas heater on the end. If anyone has done this or has any idea's get back to me soon. There is several of these barns about 1/2 miles from me that will be auctioned of in the morning(thursday morning}. Should I try and get one? Thanks Randy
Offline Buzz-sawyer
  • To see it is to saw it....
Re: Tobacco Barn---Kiln
« Reply #1 on: January 26, 2005, 03:11:37 PM »
I always like an auction sale BUT....
Is it a good value....?
I mean, it will keep rain off and is a shelter....but far from a tight building....but better than nothing, good for air/solar shed drying?.... :)
    HEAR THAT BLADE SING!
Offline Randy
« Reply #2 on: January 26, 2005, 05:26:24 PM »
These "curing barns" are built very tight. They are all metal outside, similiar to a shipping container. The farmer I talked to today said they would easily hold a temp. of  whatever the outside temp.is up to 180 to 200 degree's with no problem, but I don't know what would have to be done to control the moisture. The barns do have vents that open and close--Hmmmmmm Just don't know if it will work. Randy
Offline ellmoe
« Reply #3 on: January 26, 2005, 05:41:39 PM »
Randy,
  If the price is right they may make a good kiln for you. I have a couple of Koetter kilns that are basically a box with a heat source, air circulation, and venting. If I add another kiln I will probably build one out of a insulated overseas shipping container. However,one item of concern is the floor in the tobacco barn. Will it be able to handle the weight of the lumber?
  Good luck!
Offline Randy
« Reply #4 on: January 26, 2005, 06:33:19 PM »
Ellmoe
These barns do look just like a shipping container with a big gas burner heatsource hanging on one end with the double doors on the other end. The farmer said the floor would hold fine and he also said that New burners like hanging on the end of these would cost $5500 to replace, I figure it must be a big nice burner if it cost that much. He said that he felt that the older, but working "barns" would go for around $500 because they will have to be moved. The newer barns he expects to go for around $6000, but they also have to be moved. But I ain't paying no $6000 for one :o It takes the same type mover for these barns as it does for a shipping container(I also have a 40ft shipping container). Thanks for your advice. Randy
Offline proot
  • Member*
« Reply #5 on: June 26, 2017, 04:32:41 PM »
Did anyone use a Tobacco barn as a kiln?
Tobacco Barn used as a kiln
Started by SawyerTed on Drying and Processing
Last post March 14, 2018, 05:49:59 PM
by SawyerTed
converting a bulk tobacco kiln into a lumber kiln
Started by Bryce on Drying and Processing
Last post February 18, 2010, 11:09:27 PM
by scsmith42
tobacco bulk barn
Started by Ivey on Drying and Processing
Last post May 14, 2007, 11:16:47 PM
by Don P
Tobacco barn converted to free-span.
Started by Rooster on The Wisconsin Barn Preservation Program
Last post March 02, 2012, 08:32:04 PM
by Rooster
