Author Topic: Grapple bucket or grapple forks?  (Read 2219 times)
Offline scsmith42
    • Whispering Pines Farm
Re: Grapple bucket or grapple forks?
« Reply #20 on: May 31, 2018, 05:01:03 PM »
I have grapple forks and a grapple root rake, and have also used a grapple bucket.
Hands down, the grapple root rake is my go-to implement for handling logs.  It's like using your fingers to pick up logs, and it's very versatile.
Tom's 3638D Baker band mill
Offline mike_belben
  • Pulp Friction
« Reply #21 on: May 31, 2018, 05:05:29 PM »
Phew, that was a beech.
-tractor.
Revelation 3:20
Offline PA_Walnut
« Reply #22 on: June 02, 2018, 08:24:11 AM »
Yep. Life's a beech! :D
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Baker Portable Edger with Kubota Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Online alan gage
« Reply #23 on: June 08, 2018, 10:30:38 AM »
The grapple forks showed up yesterday and I spent about an hour or so moving logs with them. Overall I was very happy with how they worked. I got the 48" version and they worked very well for picking up multiple logs at the same time. Much easier carrying multiple logs with the grapple as opposed to regular forks. If one log was as little off center it didn't really matter. Even if the end log was only part way on the forks the grapple would clamp it in place. It clamped them tight and stabilized the load very well while driving from point A to point B, especially on the downhill section where some logs would have rolled off if I'd had forks alone. It worked for carrying five spruce logs of varying dimensions to just one or two long and large (19"x20') ash logs.
Last night I had the forks set to the same width as the grapple so the grapple didn't contact the smaller logs. Next time I'll change the fork spacing so the grapple bypasses them and see how that works.
When I got done moving logs I grabbed a pallet of plywood and moved it under my new lumber shed. Very nice not having to switch attachments.
Ordered the pallet forks and thought the cylinder was bad since there was no control on the decent of the claw. They sent a replacement and it was slightly better but not much.
I see now what you mean. The forks snap open and closed very quickly. Much different than the grapple bucket I borrowed a couple weeks ago. I'm assuming the reason being the grapple bucket had dual cylinders where the grapple forks only have one. I'm hoping someone makes some kind of orifice that can install at one of the fittings to slow down flow?
Alan
Timberking B-16
Offline mike_belben
  • Pulp Friction
« Reply #24 on: June 08, 2018, 11:06:11 PM »
The offset clamping is one of a grapples best strengths.  Ya cant always put the machine where the log will balance on open forks.
Pull the hoses and fittings off your cylinder.  Weld or braze a reducer into the hole.  It could be a roll pin, a nut, a piece of brake line, a washer etc etc.  Just make sure its in there good.  Dont breathe the fumes.. Probably zinc plated.
Revelation 3:20
Forks vs Grapple for a tractor
Started by Riles on Sawmills and Milling
Last post May 26, 2007, 01:42:57 PM
by Dave Shepard
grapple bucket
Started by jmouton on Sawmills and Milling
Last post November 30, 2014, 05:00:13 AM
by Nate379
Skidsteer grapple bucket
Started by Justify008 on Firewood and Wood Heating
Last post June 26, 2015, 11:07:44 PM
by lopet
tractor grapple bucket
Started by rick f on Forestry and Logging
Last post December 08, 2011, 04:46:14 PM
by T Welsh
