Author Topic: The little mill that could  (Read 1726 times)
Offline rlahaise
« on: May 30, 2018, 12:13:48 AM »
I have had my HM126 for a couple of years now and I just thought I would post a couple of pics of the brute of a Douglas Fir thatís on my deck..
20í long and I had to do a bunch of trimming with the chainsaw to make some clearance...the first two cuts off the top took almost a hour...
This old growth fir is tough stuff to cut... 6 passes with a new blade, sharpened after 3 cuts due to gritty bark I guess... and 15 feed into cut number 6 I broke a blade...
The Woodland mill might not be big but it sure can cut up a log..
Offline thecfarm
Re: The little mill that could
« Reply #1 on: May 30, 2018, 06:53:22 AM »
A mighty good job was done!! Poor thing! ;D
Offline frazman
« Reply #2 on: January 06, 2019, 08:35:20 AM »
That log looks like a beast. Curious on your saw.
Just a question on your saw. Have you cut smaller logs and if so, how has the saw done as for straight and even boards ?
I new here and was looking at getting the 126 or 130 sawmill in 2019. I like the options and construction on the 126 & 130 but the logs in my area could be cut with the 122.
Thanks for any info.
Offline rlahaise
« Reply #3 on: May 10, 2019, 02:16:01 AM »
Hi Frazman,.
Sorry I missed your question but if your still interested I have used the sawn for everything from that big fir to splitting 4Ē pine poles for fence braces... it cuts smooth, straight and square as long as I do my part.
My philosophy is go as big as your wallet will allow if you can.. I never planned to cut anything bigger than 12Ē and here I am with a 42Ē fir I had to split with a chainsaw and some leverage from my grapple.
Offline frazman
« Reply #4 on: May 19, 2019, 01:04:13 AM »
Thanks for the info. Looking forward to getting my HM 126 this year...
