Author Topic: Belsaw build  (Read 8309 times)
Offline bandmiller2
Re: Belsaw build
« Reply #140 on: May 30, 2019, 08:26:52 PM »
Creeker that sawyers favorite departed 15 years ago on a load of scrap iron, sorry mate. Frank C.
Offline moodnacreek
  • Sawin by the notches
Re: Belsaw build
« Reply #141 on: May 31, 2019, 08:01:15 AM »
Darn, I herd your place was nice and neat unlike here. Thanks for the reply, Doug
Offline jimparamedic
Re: Belsaw build
« Reply #142 on: June 03, 2019, 09:57:22 AM »
every time I take a load of scrap I end up needing something I got read of
Re: Belsaw build
« Reply #143 on: June 16, 2019, 10:07:44 AM »
Here's the the homemade dogs looks like they would be easy to make.
Offline glendaler
Re: Belsaw build
« Reply #144 on: June 17, 2019, 05:53:01 PM »
Thats very similar to what I hope to build. Looks fairly simple.
Belsaw A10 circle mill,
Offline J R Bradshaw
Re: Belsaw build
« Reply #145 on: June 17, 2019, 09:44:48 PM »
I just got ahold of a Belsaw M-14 in fare shape just need new carriage wheels to rusty to even measure. Can anyone give me measurements on m-14 carriage wheels.
Offline Don P
    • Calculator Index
Re: Belsaw build
« Reply #146 on: June 17, 2019, 10:19:59 PM »
Don't have them off the bat but will be pulling a couple of mine on the blade side for bearing replacement as soon as I have time. I'll measure them unless someone posts first. The bearings in my wheels are these I believe;
https://www.amazon.com/Koyo-B-912-Bearing-Complement-Rotational/dp/B007EDXD5U
I'm down to one pair of the "bushings" that go in the wheels on each side of the bearings, sort of a lipped washer that locates the bearing and takes the side slop out of the wheel to carriage mount.  With 10 wheels I'll need 20 of them for a full set of replacements. I imagine this is a machine shop job, I'm wondering if there is a need out there, should we gang up on a run?
Re: Belsaw build
« Reply #147 on: June 18, 2019, 09:51:09 AM »
I have 2 different sets of guide wheel one is about 5/8" and are bushed and the other is about 1 3/8" with bearings I need to replace the smaller 5/8" ones. Been trying to find what options are out there. Worst case I can make them.
Offline glendaler
Re: Belsaw build
« Reply #148 on: June 18, 2019, 02:09:44 PM »
Mine just have the bushings, I just looked through my spare washer drawer until I found the right combos for minimal side play.
Re: Belsaw build
« Reply #149 on: June 18, 2019, 06:20:36 PM »
My wheels are what are warn. The guide wheels so need to replace them
Re: Belsaw build
« Reply #150 on: June 27, 2019, 12:29:14 AM »
Bump
Offline glendaler
Re: Belsaw build
« Reply #151 on: June 29, 2019, 05:02:12 PM »
Things are slow here. Trying to knock some overdue tasks off the list. Hope to do some sawing this month. Weather has been up and down so my mill building is near the top of the list to get under cover.
Re: Belsaw build
« Reply #152 on: July 01, 2019, 11:13:11 AM »
Been way to hot here or raining ugh.
Custom 5hp Foley-Belsaw beam-planer on track system build.
Started by kastle on Sawmills and Milling
Last post March 25, 2014, 01:09:00 AM
by hardtailjohn
Need help with Belsaw
Started by Farmer_17 on Sawmills and Milling
Last post May 08, 2012, 03:42:21 PM
by b dukes
New Belsaw
Started by loggah on Sawmills and Milling
Last post May 26, 2014, 08:08:12 PM
by sawdust joe
M14 Belsaw
Started by bill m on Sawmills and Milling
Last post June 08, 2013, 08:32:14 PM
by bandmiller2
