AVAILABLE
Author Topic: ?your area's worst invasive plant?  (Read 2896 times)
Online caveman
  • In the land of the blind the one eyed man is king
« on: June 03, 2018, 08:25:18 AM »
While reading the post about the Devil's Walking Stick tree and the similar species from Asia, I began to wonder what the worst invasive plants folks deal with in their locations.
We have several that cause significant problems.  Cogan Grass, which is often spread by the county's mowing crews is spreading like an invading army around here.
Brazilian Pepper, just a little south of me has displaced a lot of native vegetation.  It does evidently make good tasting honey though.
Tropical Soda Apple has become problematic in pastures over the past several years.
In the lakes we have hydrilla and water hyacinths.  These two do provide good bass habitat.
Caveman
Offline Southside logger
Re: ?your area's worst invasive plant?
« Reply #1 on: June 03, 2018, 09:23:11 AM »
Around here it's the City Transplant that causes the biggest problems.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #2 on: June 03, 2018, 09:24:33 AM »
Privet Hedge.
Kudzu in some areas.
Chinese Tallow aka Popcorn tree.
:D  Sweetgum.  :D
Offline brianJ
  • Only get excersize if I choose the right hobby
« Reply #3 on: June 03, 2018, 09:30:14 AM »
Honeysuckle, buckthorn, multiflora rose, & box acer negundo.   Sometimes the order is different.
Offline Roxie
  • Gender: Female
  • I'm your huckleberry
« Reply #4 on: June 03, 2018, 09:45:08 AM »
Multiflora rose (thank you DuPont family), Albizia julibrissin or Mimosa tree, and poison Hemlock.
Save a farm today or starve tomorrow.
Offline curdog
« Reply #5 on: June 03, 2018, 09:58:21 AM »
Kudzu is the worst for us, but privet is bad to deal with as well. Japanese stiltgrass is rough on new seedlings, but once they get over the top after the first year they seem fine. We're getting oriental bittersweet moving in from our west as well as Chinese silvergrass. That silvergrass burns like gasoline and thrives with fire... and we got paulownia and tree of heaven and Johnson grass in fields , wisteria, .. definitely no shortage of invasive plants...
Offline sandhills
« Reply #6 on: June 03, 2018, 11:24:23 AM »
Leafy spurge, erc, muskthistle, and water hemp on the farming/ranching side of life.  A lot more but most generally easier to contain.
Offline firefighter ontheside
  • I like trees.
« Reply #7 on: June 03, 2018, 11:39:35 AM »
This is interesting.  Ive never heard of box elder being invasive.
Here it is bush honeysuckle and Bradford pear, otherwise known as Callery pear.
Is it truly invasive if its expanding its territory due to climate change?  I would say not.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Offline JBlain
  • Forestry, woodworking, mushroom harvesting
« Reply #8 on: June 03, 2018, 11:47:49 AM »
Honeysuckle, barberry, Mile A Minute and stiltgrass in central PA.  If you are in northern PA over 40% of all the forest is haycented fern
Josh
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #9 on: June 03, 2018, 11:55:20 AM »
PRIVET!
Offline Novascotiamill
  • I walked the Thin Blue Line for 20 years
« Reply #10 on: June 03, 2018, 12:01:09 PM »
Marijuana, government making it legal in the entire county this month .
2017 HM130
Stihl 261
2010 F150 xtr
Lots of rigid genx5 tools
1 long haired german shepherd
2017 kioti ck2610HST with FEL and forks
Grindlux band sharpener
Wicked 55 root rake grapple
O
  • I like trees.
« Reply #11 on: June 03, 2018, 01:39:52 PM »
I didnt know privet was invasive anywhere.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Online lxskllr
  • dummy with saw
« Reply #12 on: June 03, 2018, 05:31:03 PM »
Numerous vines, and I don't know what many of them are. I've noticed a steady increase over the last 20 years or so. I read not long ago that increased CO2 in the atmosphere has increased the poison ivy population. I've noticed that, and I suspect the other vines are doing better also. There's one particular vine that's insidious. I have a hard time seeing it until it's taken over half a bush or tree. I don't use chemicals on my property, so they're all cut with a knife or machete. I don't go for perfection; just try to keep it manageable.
They make work harder also. Awhile ago I set a couple control points for a job. I took prospective leaf cover into account when setting them up. I go back to do some work, and a rats nest of vines I neglected to notice, blocked visibility, and were too high and tangled in the trees to remove. I had to go play in traffic to get the job done  :bangshead:
« Reply #13 on: June 03, 2018, 06:22:21 PM »
In open ground around here it's palmer pig weed and sickle pod that is coming on strong - both nasty weeds, and being nicely assisted by just about every combine in the south.  Now there is a new reason to call Gleaners the "silver seeder".
Offline Don P
    • Calculator Index
« Reply #14 on: June 03, 2018, 07:15:16 PM »
Autumn olive, Ailanthus, stiltgrass, multiflora rose (what is the DuPont connection Roxie?), barberry, some kudzu
Offline btulloh
« Reply #15 on: June 03, 2018, 07:19:44 PM »
Privet.  Privet.  Privet.  Marestail, pokeweed, tree of heaven, northerners (the wrong kind), multiflora rose
And privet.
A lot of people around here have trouble with johnsongrass, but I think it's because they don't control it.
HM126
Offline btulloh
« Reply #16 on: June 03, 2018, 07:23:05 PM »
Almost forget a real nuisance - NUTSEDGE.
HM126
Offline jwilly3879
« Reply #17 on: June 03, 2018, 08:57:46 PM »
Knotweed
Offline runmca
« Reply #18 on: June 04, 2018, 02:22:13 PM »
Japanese barberry smiley_thumbsdown
Offline Ianab
« Reply #19 on: June 04, 2018, 04:18:29 PM »
Not in my specific location, but NZ has a big problem with invasive Pine trees of all things. To the extent that Lodgepole pine is now banned. Large areas of the South Island high country (open tussock land) is being taken over by pine trees, and it's costing millions to try and control them.
Wilding conifers: Weeds
Invasive Non-woody Plant Species (spreading dogbane)
Started by jayfed on Tree, Plant and Wood I.D.
Last post July 25, 2006, 10:58:12 PM
by jayfed
Replanting maple or red oak or black cheary to re plant blow down poplar area
Started by zach613 on Ask The Forester
Last post November 13, 2016, 11:33:11 PM
by zach613
Black Locust, to plant or not to plant, that is the question.
Started by Brad_S. on General Board
Last post January 29, 2007, 07:29:37 AM
by Cedarman
is ERC that invasive?
Started by m wood on Forestry and Logging
Last post March 31, 2013, 08:04:19 PM
by mesquite buckeye
