Author Topic: JD 790 For Sale set up for small firewood operation  (Read 2415 times)
Offline gasman1075
  • I'm lucky
« on: June 05, 2018, 02:57:11 PM »
I have a JD 790 with 645 hours 419FEL manual transmission 4WD with power beyond. It has AG tires and the quick connect bucket so it takes 2 minutes to switch to pallet forks. I added a 3PT log lift with a thumb that runs off the power beyond. You can slide the forks under the log, lift and pinch and then buck at a comfortable height. It also comes with a 4FT finish mower and a 1/4 cord dump trailer tow behind that can be converted to hydraulic dump easily using the existing valving.
I am offering this for 2 days June 6-8 for $13500 before I trade it in.
** It is on its way to the dealer thanks **
Thanks Jack
** I have read, understand and agree to the terms of posting an ad
 on the Forestry Forum **
JD 2520/Stihl MS461/Stihl MS261/ MS 461 / Timberwolf TW-P5/ Norwood Skid-Winch
Offline gasman1075
  • I'm lucky
Re: JD 790 For Sale set up for small firewood operation
« Reply #1 on: June 05, 2018, 03:06:35 PM »
You can also add a Norwood hydraulic skid winch as well the plumbing and valving is all there currently.
Jack
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #2 on: June 06, 2018, 07:49:31 PM »
I have an interest. what can you lift with the FEL?
Offline gasman1075
  • I'm lucky
« Reply #3 on: June 06, 2018, 09:30:01 PM »
Not as much as the back for sure it is hard to answer that question  but I will tell you I had the 3PT thumb built because it was so much cheaper and stronger than adding a thumb on the FEL. With the FEL and forks I could lift most 12-18' sticks but it was sloppy while I bucked them up.
** The deal I made with FF to advertise this tractor has expired ( June 6-8 ) thanks all ! **
Offline Jteater
« Reply #4 on: February 05, 2019, 07:04:48 AM »
Did you happen to sell the 3 pt log lift for this?
Offline gasman1075
  • I'm lucky
« Reply #5 on: February 05, 2019, 08:48:02 AM »
I did not sell it. I would like to. I am in Stephentown NY
* I understand and agree to the terms of posting an item for sale on FF **
Offline gspren
« Reply #6 on: February 06, 2019, 08:40:35 AM »
Post some details and a price on the thumb.
Offline gasman1075
  • I'm lucky
« Reply #7 on: February 06, 2019, 10:09:09 AM »
As far as details go I had it made / made it myself because I was too cheap to put a grapple on my FEL and since my 3PT will lift much more than the FEL this seemed like a logical choice. It has been barely used due to injuries of my own making. Its a Green Machine thumb welded onto a Titan 3 point pallet fork. Essentially I had the thumb welded to the pallet forks. I plumbed a valve from my power beyond and could lower the forks, back under the log, pinch it and pull it out near the splitter and buck it up there. The only pictures I have are in my gallery but for the few months I used it I was very happy just to have the log up off the ground and be able to cut it up at a comfortable height. I
Offline gasman1075
  • I'm lucky
Re: Pallet Fork with thumb
« Reply #8 on: February 06, 2019, 10:17:15 AM »
Sorry if someone shows up with $800 i will load it in your truck. I have hydraulic valve for an additional $100 to control it.
** I have read and understand the rules posting an item for sale in FF **
want to buy skidder for small firewood operation ?????
Started by phil-tinker on Forestry and Logging
Last post December 27, 2010, 07:58:54 AM
by oldseabee
Skid Steer shopping for small firewood operation.
Started by danbuendgen on Firewood and Wood Heating
Last post October 03, 2016, 03:19:58 PM
by shamusturbo
dyna rover splitter thoughts for a small firewood operation?
Started by logman81 on Firewood and Wood Heating
Last post May 31, 2015, 08:24:53 AM
by logman81
moved
MOVED: Complete Logging Operation For Sale
Started by Jeff on For Sale
Last post May 23, 2011, 09:38:35 PM
by Jeff
