Author Topic: Ms200t running issues  (Read 457 times)
Offline Grimace71
  • Member*
« on: June 05, 2018, 11:14:10 PM »
I need help with why after I rebuilt the carb it now only starts when I'm holding the trigger and won't stay running  thanks
Offline teakwood
  • Switzerland
Re: Ms200t running issues
« Reply #1 on: June 06, 2018, 08:34:00 AM »
try adjusting the L and LA screw. first put them to the original position. On stihl's its normally L and H open one turn. look at you manual
Offline ZeroJunk
« Reply #2 on: June 06, 2018, 11:51:20 AM »
Yes. Turn the LA screw in clockwise until the saw will stay running, hopefully. Then adjust the L screw for max RPM. Then turn the L screw CCW another 1/8 to 1/4 turn. Then adjust the LA CCW until the chain quits turning. That's usually pretty close.
Offline ladylake
« Reply #3 on: June 13, 2018, 05:36:35 AM »
 If adjusting doesn't help check the needle valve for dirt or the metering lever a little to high letting too much fuel in.   Steve
Timberking B20 14000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
MS200T Won't stay running.......
Started by Bark Buster on Chainsaws
Last post February 18, 2006, 04:38:36 PM
by ehp
Stihl HT-101 Pole Saw running issues
Started by tstex on Chainsaws
Last post October 08, 2016, 01:17:05 PM
by dougand3
question
Leaky MS200T
Started by KB0NES on Chainsaws
Last post May 03, 2011, 01:47:57 PM
by Cut4fun
ms200t parts...
Started by Cliniford on Chainsaws
Last post December 23, 2008, 07:12:50 PM
by Cliniford
