Author Topic: quadco 5660 heads  (Read 779 times)
Offline supertrucker
quadco 5660 heads
« on: June 09, 2018, 05:43:36 PM »
Any one with experience with these? they look awesome but doesn't seem like a lot out there or if there is not a lot of publicity.
2006 westernstar, 1989 LTL 9000, 3406B 425, 8LL, 1994 Stoughton chip wagon, 2011 John Deere 1510E, 2011 pmi trailer, 2003 serco 7000.
Offline quilbilly
Re: quadco 5660 heads
« Reply #1 on: June 21, 2018, 10:21:59 AM »
I think there was a guy on here who preferred the disk saws. Might have been ctllogger. Use the search function. I'm sure i have run across someone preferring them before.
a man is strongest on his knees
Offline Skeans1
« Reply #2 on: June 21, 2018, 10:34:57 AM »
There was a few out here in the PNW but they all had problems cutting our longer lengths that we do out here. Plus they’re super heavy and not very fuel efficient.
Offline Riwaka
« Reply #3 on: June 21, 2018, 06:55:38 PM »
Processor heads are a continuously evolving technology.
If purchasing a processing head new or used you need to check with the manufacturer what the current specs for the new head are and whether any/ some or all of the new spec parts might be available as upgrades for the used head.
Depending on what base you use, for some forestry machine combinations (base/ head) there are very few of them around to look at working, so it can be difficult to know what machine combination is going to be exactly right for your application/ conditions.
This has for the 5660 that there have been over 25 improvements. (similar weight to the risely rolly ll  disc saw version)
At least by having a bottom disc and a top saw it should reduce the amount of time searching around for chain that has been thrown off the bar.
http://www.quadco.com/wp-content/uploads/2013/06/Attachments-Guide-8.5x7_eng_low.pdf
Cat 521 with 5660 (260 hp net) many newer machines are now 300hp plus and larger hydraulic flows/ pressures than previously.
Offline quilbilly
« Reply #4 on: June 22, 2018, 10:51:56 PM »
Skeans what was the deal with longer lengths? Too much weight on the machine?
Offline Skeans1
« Reply #5 on: June 22, 2018, 10:57:50 PM »
Bark slip is about 90% we shoot out to 41’ so the wheel can slip more vs a 21’ length. Out here even in thinnings we cut 33’ and 37’ a lot.
Quadco ultimate 5660 or Risley rolly II
Started by logger444 on Forestry and Logging
Last post October 02, 2009, 11:27:58 PM
by logger444
Has anyone had experience with the "new" Quadco 5660 harvester head?
Started by Twig farmer on Forestry and Logging
Last post February 08, 2010, 08:13:54 PM
by Jamie_C
415 timbco with Quadco hotsaw
Started by newstick on Forestry and Logging
Last post October 05, 2013, 06:35:54 PM
by newstick
-Quadco Intermediate Ring Saw-
Started by BargeMonkey on Forestry and Logging
Last post April 04, 2014, 07:56:44 PM
by Northern Timber Harvesting
