Author Topic: Setworks  (Read 613 times)
Offline LeeB
Setworks
« on: June 11, 2018, 11:30:30 PM »
My old setworks laid down on me yesterday and I took it off and converted back to manual today. A lot of corrosion on there. I may try to clean it up and see if that helps. There are no longer any parts available for it so if cleaning doesn't do the trick it may well be toast.
Offline Southside
Re: Setworks
« Reply #1 on: June 12, 2018, 01:21:21 AM »
There is an Accuset that just showed up for sale in the For Sale section
Offline LeeB
Re: Setworks
« Reply #2 on: June 12, 2018, 06:35:29 AM »
I saw that but I doubt Lindy would be any too happy about me spending $500 for one even though it is a good price.
Offline tylerltr450
  • Trust me I run SAP and a sawmill
Re: Setworks
« Reply #3 on: June 15, 2018, 01:16:17 PM »
Why not trouble shoot the system look for the main power and follow it around and see if you can find the issue. Maybe something simple to repair.
Timber Harvester 36HTD25 fully loaded
2006 Dodge 2500 first Auto to NV5600 swap, EFI Live Tune by me
John Deere Tractor
Offline LeeB
Re: Setworks
« Reply #4 on: June 15, 2018, 01:22:31 PM »
I plan to try to but I have to rewire the control center first. Had a wire short out yesterday and took several others with it.
Setworks
Started by vfauto on Sawmills and Milling
Last post April 30, 2018, 07:22:29 PM
by vfauto
setworks
Started by Ikemonroe on Sawmills and Milling
Last post January 25, 2015, 05:49:56 PM
by beenthere
Need Setworks.
Started by BBK on Wanted
Last post May 25, 2006, 05:54:30 AM
by BBK
setworks
Started by pzimmerman on Sawmills and Milling
Last post March 18, 2019, 10:23:33 PM
by Larry
