Author Topic: Buying logs?  (Read 1935 times)
Offline Southside
Re: Buying logs?
« Reply #20 on: June 15, 2018, 01:12:02 PM »
9,000 BF of WO logs on a truck would be a ticket to jail here, more like 7000 and that is pushing it. The problem becomes axle weight.
What about just buying some WO lumber from a circle mill?
Offline Brad_bb
Re: Buying logs?
« Reply #21 on: June 15, 2018, 05:08:35 PM »
Southside, yes but they'd have to mill it to my sizes.  That means they have to have the logs to start with.  There is a circle mill I've worked with before but he doesn't have the logs I'd need, and he's pretty busy/backed up for at least a couple months.  If I had the logs, I could better control the process- that is I could mill them right off, and get them drying.
Offline Southside
Re: Buying logs?
« Reply #22 on: June 15, 2018, 07:42:49 PM »
If you can't find what you need there is a circle mill over this way that saws white oak. I would be happy to help with the drying if that helps to avoid shipping a bunch of water halfway across the country.
Buying logs
Started by ncsawyer on Sawmills and Milling
Last post March 05, 2015, 01:35:08 AM
by gimpy
Buying Logs?
Started by urbanlumberinc on Sawmills and Milling
Last post December 05, 2006, 08:28:39 PM
by woodmills1
Buying logs
Started by Bub on Sawmills and Milling
Last post March 02, 2014, 04:46:40 PM
by red oaks lumber
Buying Logs
Started by BubbaG on Ask The Forester
Last post March 08, 2012, 10:44:05 PM
by NWP
