Author Topic: Braden winch adjustment?  (Read 3421 times)
Offline logman81
« on: June 14, 2018, 09:25:55 AM »
So as some of you know i bought c4b tree farmer skidder. It has the braden mechanical winch and it hasnt been working to the capacity that it should meaning it isnt winching as hard as it should and slips on a decant pull. I would like to know if their is a way to adjust it to put more pressure on it to winch better and hold to hitch.
Precision Firewood & Logging
Offline Neilo
Re: Braden winch adjustment?
« Reply #1 on: June 15, 2018, 09:20:14 AM »
So it's the one with the long lever to engage? Some have hydraulic clutch. All you can do is clean the clutch bands and adjust the linkage. I don't think the Braden clutch bands are available, but you could try aftermarket parts.
Offline logman81
« Reply #2 on: June 15, 2018, 10:42:02 AM »
This is the winch. I think it just needs to be adjusted to put more pressure on the plate but i dont know how.
Offline bushmechanic
  • Someone else has it worse than you.
« Reply #3 on: June 16, 2018, 06:35:59 AM »
logman81 you adjust the clamping pressure by turning that hub that the lock pin is into( lock pin is the one your punch is pointing too). Your best bet is too remove all the outside items and free up that adjuster so you can take all the discs out and clean them up. once that adjuster unscrews then that large plate comes off exposing the discs. I pulled out that lock pin and held it out with a pair of vice grips then turned the adjuster, if you have to tap it to turn it don't hit on the arms where the forks attach they are very brittle! I suspect that it may need some heat to free it up and use plenty of anti-seeze when you put it back. I have one old winch here that someone welded a shim to the outside ring to take up the slack for worn discs.
Offline logman81
« Reply #4 on: June 16, 2018, 07:58:06 PM »
Ok yeah maybe ill try that. Last time i tried to get it apart i couldn't get that collar to budge. I only have a small propain torch for heat but maybe it will be enough.
Offline logman81
« Reply #5 on: June 17, 2018, 09:34:49 AM »
Im thinking if i cant get it off with a propane torch i might invest it one of those induction heaters, probably a good investment anyway.
Offline logman81
« Reply #6 on: June 19, 2018, 05:14:54 PM »
Well no luck with the propane torch and a large hammer! Its really stuck on there! Going to have a weldor friend come and heat it with a real torch and see if it will free up.
Offline logman81
« Reply #7 on: June 22, 2018, 05:52:09 PM »
Do you think it will be safe to heat the adjusting collar with a torch?
« Reply #8 on: June 22, 2018, 08:19:44 PM »
Well the best way to look at it is....it's not working right now! What I would do is heat it up to a cherry red and then take a garden hose a cool it off quick. After that you will be able to turn it by hand. The absolute worst is you may have to make a new one at the machine shop. You have to get it working! Now another option would be to take off the arms of the snap clutch and build them up with welding and then when you snap your clutch it will apply more pressure to the clutches. I wouldn't go that route because it's only a quick fix and down the road you'll be back in the same boat, better to fix the adjuster.
Offline logman81
« Reply #9 on: June 24, 2018, 11:04:48 AM »
Ok that is what i will try doing i would rather fix it right the first time.
Offline logman81
« Reply #10 on: July 09, 2018, 07:51:00 AM »
Anyone know where i could get parts for this winch? Mine is leaking out the pto seal.
Offline logman81
« Reply #11 on: July 12, 2018, 10:08:45 AM »
Am i the only one with a braden winch?
« Reply #12 on: July 14, 2018, 05:43:49 PM »
Logman81 I don't think your the only one that has one but they are pretty rare nowadays, and of course obsolete! Braden was bought out by Paccar I think, if I'm mistaking then I bet someone will correct me! Check those guy's and they might be able to help you out.
Offline Satamax
« Reply #13 on: July 15, 2018, 02:26:15 AM »
Logman, i thought about saying this. You could add some pressure by lengthening the little pieces of flat metal that we see in pairs.
For your seal leaking. I have a problem like this lately on my toyota. So i am may be not the man to ask for. But if you take the oil seal out and replace it. That should do the trick.
French CD4 sawmill. Latil TL 73. Self moving hydraulic crane. Iveco daily 4x4 lwb.
Offline logman81
« Reply #14 on: July 21, 2018, 03:47:22 PM »
Well got bad news we tried heating up the adjusting collar and we did get it to move but unfortunately it split. So im hoping someone can find one to replace it.
« Reply #15 on: July 22, 2018, 07:01:24 PM »
That's too bad that had to happen :( well at least you will get it working right now! If you can't find one you will have to find a good machinist to make one for you. Another idea is you could get it welded with a rod compatable with cast iron or steel whatever it is.
Offline logman81
« Reply #16 on: July 23, 2018, 06:17:43 PM »
Yeah im hoping to find the parts or i may just sell the machine. I like the size of the skidder and all i wish it was diesel and had a different winch.
Offline logman81
« Reply #17 on: July 24, 2018, 05:44:43 PM »
So called davco and the guy i talked to said that they could find the parts just will take a little time. He was very knowledgeable and offered alot of advice on my situation, very helpful.
Offline logman81
« Reply #18 on: July 27, 2018, 06:24:12 AM »
Looks like davco has found most of the parts needed to fix the winch so far.
Offline logman81
« Reply #19 on: August 10, 2018, 03:26:17 PM »
No luck with parts so skidder is coming home for new center pins and bushings and possibly a model 9 winch replacement for the braden junk!
Braden winch
Started by bandmiller2 on Sawmills and Milling
Last post December 27, 2010, 08:42:34 PM
by bandmiller2
BRADEN WINCH
Started by dht on Forestry and Logging
Last post May 11, 2018, 06:52:19 AM
by dht
Braden winch
Started by Scott on Forestry and Logging
Last post August 08, 2006, 12:40:37 PM
by junkyard
Braden winch issue
Started by logman81 on Forestry and Logging
Last post December 25, 2017, 02:01:30 PM
by logman81
