Author Topic: What's better than sawing through a ceramic insulator?  (Read 1166 times)
Offline Southside logger
« on: June 15, 2018, 07:49:35 PM »
The answer of course is picking up your 70cc chainsaw with a square chisel chain and while carefully cutting off the flitch which is concealing the ceramic gem in the walnut log, slamming right into the middle of the offending insulator.
Now we are in the chips....
Offline btulloh
Re: What's better than sawing through a ceramic insulator?
« Reply #1 on: June 15, 2018, 07:57:44 PM »
Uhhh.   smiley_annoyed01
HM126
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #2 on: June 15, 2018, 08:07:09 PM »
Gee Whiz that's time to take a BC for the headache.....
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline nativewolf
« Reply #3 on: June 15, 2018, 10:01:09 PM »
Ochh, come up to Delaplane and I'll give you a nice log with no insulators.  Name your Diameter.
Liking Walnut
Offline Crossroads
  • lets make some sawdust
    • Kevin Bales faith family farm and portable sawmill
« Reply #4 on: June 16, 2018, 10:36:20 PM »
If I understand correctly, you got it with the mill and the chainsaw? Im impressed! Sounds like something Id do 🤡
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins
« Reply #5 on: June 16, 2018, 11:27:28 PM »
Yup - a double hitter - If your're going to cause destruction, may as well do it right!!!  The old barn hinge I found today was just icing on the cake, but I only got that with the mill.  For what it's worth turbos won't saw all the way through the round part of a barn hinge, they give up about half way, I was disappointed in the bands performance on that one.   >:(
Offline Just Right
    • JustRightSawing
« Reply #6 on: June 17, 2018, 12:21:59 AM »
I didn't get the ceramic with the mill.  But I did get one with the chainsaw.  Since I saw it,  I thought I was far enough from it.  There I go thinking again.  But I will be on the look out for a barn hinge,  then I can tell you if the 4 degree blades perform any better.
If you are enjoying what you are doing,  is it still work?
Offline UpInATree
    • TreeSawyer.com
« Reply #7 on: June 17, 2018, 11:01:23 PM »
I saw the topic and thought to myself *DanG what is he using for blades?  Last one I hit went about the same as yours.
Wood-mizer LT70HD D55 Wireless, Wood-Mizer ED-26, A whole bunch of Stihls. Alaskan Mill 74",  Bucket Truck, Log Truck, Chippers, trailers, dump trucks,   Kubota M9540, L3010D and B7510. Cord King.   Learning Timberframing under Jim Rogers
Ceramic Saw Guides
Started by blake in spokane on Sawmills and Milling
Last post January 29, 2009, 10:12:59 PM
by Old Iron nut
Ceramic Blade Guides
Started by Cedar Savage on Sawmills and Milling
Last post December 04, 2012, 03:44:56 PM
by Chuck White
Laying Ceramic Tile
Started by Autocar on General Board
Last post February 18, 2014, 05:20:39 PM
by Autocar
Ceramic fiber boards
Started by BUGGUTZ on Firewood and Wood Heating
Last post February 28, 2016, 08:52:19 PM
by BUGGUTZ
