Author Topic: UP Dated 450 case ??  (Read 955 times)
Offline dustyhat
« on: June 17, 2018, 11:19:49 PM »
We have a mid 70s 450 case track loader one of the other guys thinks motor oil is getting into the transmission oil is this possible? if so , where do i start looking
Running a custom built stationary bandmill with a slightly modded four cyl jeep go devil engine.
Online mike_belben
  • Pulp Friction
Re: 450 case ??
« Reply #1 on: June 18, 2018, 12:34:18 AM »
Case runs a driveshaft off a damper.. Here is a breakdown.  I dont remember it having any lube line but you should check, mine is 1,000 miles away.  If there are no hydraulic pipes from that damper to the trans i cant see it mixing.  The driveline is all gear, left and right trans.
What is making you suspect this?  the trans may have a motor oil grade lubricant.  Lotta the older stuff just ran 30WT in everything.
Revelation 3:20
Offline thecfarm
Re: 450 case ??
« Reply #2 on: June 18, 2018, 05:03:20 AM »
Seem like I had a forklift at work do that. Took the mechanic a little to figure out why. That was about 20 years ago,I forgot what it was now.
Online mike_belben
  • Pulp Friction
Re: 450 case ??
« Reply #3 on: June 18, 2018, 11:08:33 AM »
Dang i lost the link for the damper parts schematic.
Revelation 3:20
Offline dustyhat
Re: 450 case ??
« Reply #4 on: July 02, 2018, 08:37:25 AM »
Maby this can help others in the future, the suspected problem is we are thinking its getting in the hyd pump off the motor getting sucked in to the hydraulic system. so if anyone has this trouble look for a bad pump.
Online mike_belben
  • Pulp Friction
Re: UP Dated 450 case ??
« Reply #5 on: July 02, 2018, 12:43:09 PM »
I guess that would indicate a bad seal on the input shaft of the pump.  The drainback oil coming off the timing gears must be getting pulled in.  I would look to see if there isnt a clogged up suction side from the hydraulic reservoir.  Probably has a strainer screen inside.  Its hard to imagine that much oil getting in that way if the hydrailuc pipe is flowing properly.
My 450 case completely algae'd up a new filter in a year.
Revelation 3:20
Offline Skeans1
« Reply #6 on: July 02, 2018, 10:37:04 PM »
Quick easy way to check would be add some red dye into your oil if you see the dye somewhere it’s not supposed to be issue found.
Need some help (up dated)
Started by Bruno of NH on Sawmills and Milling
Last post November 18, 2017, 05:13:00 PM
by thecfarm
Timberjack 225 c can't find axle--up dated
Started by Wild willy on Forestry and Logging
Last post October 02, 2009, 06:39:09 AM
by Wild willy
Tractor tire studs (up dated )
Started by Bruno of NH on General Board
Last post December 28, 2017, 09:55:46 PM
by Peter Drouin
Fire stone forestry special(up dated agin)
Started by Wild willy on For Sale
Last post September 23, 2009, 01:23:57 PM
by Wild willy
