TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: Sawmill Service in SW Michigan Wanted - BIG Log  (Read 253 times)
Offline D C
  • Member*
« on: June 22, 2018, 08:04:39 AM »
I'm looking to have a large diameter (60"+) red oak log slabbed in Southwest Michigan.
We had some not quite as large logs milled by a local sawyer that we found via the Woodmizer website, but he can't touch anything this size with his equipment.
He mentioned a Lucas mill, and provided a name, but that particular reference will mill logs brought to him, and we have no practical means of moving this log (it's in the 8-10' long range).
Is there a good resource for locating services?
Thanks,
Dave
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Sawmill Service in SW Michigan Wanted - BIG Log
« Reply #1 on: June 22, 2018, 09:54:02 AM »
   You might try the Extra button on top here of the FF or look at the WM site under Services for their Pro-Sawyers in your area.
    Another option might be to talk to local aroborists/tree services and see if they know someone with a mobile slabber that big or see if they have the equipment to load and haul the log to the guy with the stationary slabber. Those slabs will be heavy but a whole lot easier than moving the whole log. You can make several trips with a smaller trailer if you have to once it is broken down into slabs.
Kiln service in West Michigan
Started by RJV on Drying and Processing
Last post February 06, 2005, 08:27:37 PM
by oakiemac
18' white oak boards wanted in Michigan
Started by scsmith42 on Wanted
Last post March 03, 2013, 02:25:02 PM
by scsmith42
Kiln service wanted
Started by Woodwalker on Wanted
Last post April 26, 2007, 10:48:56 PM
by Woodwalker
Slab service wanted -- Lafayette, Indiana
Started by bakerhardwoods on Sawmills and Milling
Last post December 16, 2013, 06:20:53 PM
by nomad
