Author Topic: Cost for grouser bar versus new shoes  (Read 2302 times)
Offline LeeB
« on: June 23, 2018, 08:17:41 AM »
Is grouser bar economical? Consider that I don't have the welding equipment to do it myself.
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
Re: Cost for grouser bar versus new shoes
« Reply #1 on: June 23, 2018, 10:23:51 AM »
I suspect you mean to "reshoe"some tracks?
Uncertain on cost but am interested in hearing what
others with more experience have to say
D
Offline LeeB
« Reply #2 on: June 23, 2018, 11:32:36 AM »
Yes, to reshoe the tracks on my D4C. The toe steal is getting pretty worn. Hard to get a good push when you just spin.
Offline BargeMonkey
« Reply #3 on: June 23, 2018, 01:22:06 PM »
 Undercarriages just went up 30% with the steel tariff unfortunately. Welding on new grouser steel isnt a hard job but its alot of time. Personally I would go on "Machinery trader" and look towards the bottom, you will see a parts and attachment section, you maybe able to find a pile of shoes at a dealer as "old stock" or from a dismantled machine that are like new, that's how i typically shop for parts first.
Offline mike_belben
  • Pulp Friction
« Reply #4 on: June 23, 2018, 01:40:56 PM »
Machine by machine basis.  If you cant get some obsolete pad then there is no alternative.  Price new and then youll have a basis to compare.
Revelation 3:20
Offline Skeans1
« Reply #5 on: June 23, 2018, 02:02:39 PM »
You might call around to some of the tethering manufactures for their extensions they weld on the machines that might fit your needs.
Offline woodmaker
« Reply #6 on: June 23, 2018, 07:40:11 PM »
 I've done it twice;a td8 and a td20. As barge monkey says,its not hard,but it takes a lot of time. If you can weld,but don't have a welder,this may be the time to seriously look at buying one.If you can't weld,look at adult ed. classes,if available( it's hard to survive in this business if you cant fix at least some of your own machinery). The other question is ; how good are the chains themselves.Is it worth your time to fix pads on worn out tracks? Probably not ,if you use the machine very much.
  Around here , a man with a portable welder gets about $ 60.00 an hour. I cant believe the it would be cheaper to pay someone weld on grouser stock than to buy new.
franklin q80,builtrite 40,husky 372,sachs dolmar 123, dozers,excavators,loaders,tri-axle dump trucks ,autocar tractor with dump,flatbed and detachable trailers, and 8  f350 diesels
Offline Gearbox
« Reply #7 on: June 23, 2018, 11:31:11 PM »
If you have a welding tech school they are looking for projects for students to weld . 3/4 inch grade 60 rebar works good . You may have to look a bit to find graded rebar . most sell ungraded from mini mills . Cheap fix and wears quite well . I did this on a 850 Case and wore out a set of chains and only broke one bar .
Offline LeeB
« Reply #8 on: June 24, 2018, 02:59:53 AM »
Any special welding procedures such as preheat?
Offline Riwaka
« Reply #9 on: June 24, 2018, 07:20:10 AM »
There are a few tracked  machine undercarriage guides that cover the use, maintenance and repair/ upgrade of tracks etc.
lite guide
WELD ON PROCEDURE - titus steel
Depending on what your conditions are like, sometimes it is better to spin the tracks a bit  than load up the driveline too much.
Offline g_man
« Reply #10 on: June 24, 2018, 08:55:52 AM »
If you end up deciding on the new pad route, before you buy the new pads and bolts make sure you know how you are going to get the old pads off. When I put new chains on my dozer I did a pad swap. I had to cut the pads off the old chain with a torch. There was no way I could get them off with tools. At least no tools I had access too.
You should also plan on learning how to weld. It takes so time and dedication but it is well worth it if you have equipment.
gg
Offline LeeB
« Reply #11 on: June 24, 2018, 09:57:41 AM »
I can weld some, just don't have the welder rigged up since we moved. I'm trying to convince Lindy it will be economical for me to pick up a used portable.  :D
Offline Skeans1
« Reply #12 on: June 24, 2018, 09:59:54 AM »
If it was me Id pick up a gen set then run an inverter off of it.
Offline mike_belben
  • Pulp Friction
« Reply #13 on: June 24, 2018, 10:05:13 AM »
Pads are most certainly gonna be hardened, and will want a preheat and post heat.  A stick welder and specific rod is pretty likely to be called for.  Im not saying you cant just mig rebar on with ER70S6 and hope for the best but results may vary.  I guess ya gotta weigh how nice the rest of the machine is and how long you plan to keep it.
My D31 pads are worn way down and im happy about that.  Itll spin instead of breaking a final drive now.  I never met a log or stump i couldnt push with it just the same.  It also leaves a lighter turning footprint in the woods.
Revelation 3:20
Offline Skeans1
« Reply #14 on: June 24, 2018, 10:24:09 AM »
Normally dual shield is used as well with pre and post heat.
Offline teakwood
  • Switzerland
« Reply #15 on: June 24, 2018, 11:07:52 AM »
With a 1" drive impact pistol they come off pretty nice! You need a big compressor though
Offline Skeans1
« Reply #16 on: June 24, 2018, 11:10:09 AM »
Not always weve broke sockets, bolts, rounded the nuts off in the rails before sometimes the best way is the blue wrench.
Offline LeeB
« Reply #17 on: June 24, 2018, 11:32:58 AM »
Cost for a half decent 1" impact, socket, and a compressor big enough to drive it would just about pay for the labor having it done.
Offline mike_belben
  • Pulp Friction
« Reply #18 on: June 24, 2018, 02:21:33 PM »
You can make due with a tiny compressor that fills a big storage tank and a big hose to the gun with non check valve couplers.  I had to build a reservoir for my 1" gun to run off a little craftsman compressor and it works perfect.
A 3/8 hose hundred foot long fills the storage tank.  It uses about 20ft of half inch hose with no checks direct from tank to gun.  Cant tell its not hooked to a monster compressor.
Revelation 3:20
Offline g_man
« Reply #19 on: June 24, 2018, 05:54:21 PM »
That's a good idea, maybe in a pinch and if you have a lot of patience. You don't get anything for free. Your little compressor can't take many long duty cycles to fill the big tank w/o suffering badly. Then you get a couple big blasts from the big tank and have to wait on the poor little compressor again. There are about 264 or so bolts to take out !!!!
gg
Cost of Air Drying versus Green Lumber
Started by WDH on Sawmills and Milling
Last post September 20, 2014, 06:27:24 PM
by Alligator
source for 14" single grouser pads
Started by OneWithWood on General Board
Last post May 02, 2007, 10:59:30 PM
by scsmith42
The real cost of bands? Swing mill have lower cost?
Started by Doug_D on Sawmills and Milling
Last post May 09, 2010, 04:39:05 PM
by ARKANSAWYER
MBT Shoes
Started by Magicman on Health and Safety
Last post May 14, 2010, 09:43:13 PM
by Magicman
