Author Topic: Need Help Identifying Tree  (Read 742 times)
Offline ewhite2316
« on: June 23, 2018, 02:27:49 PM »
I need help identifying a tall tree in the woods in my backyard in Indiana.  The pods have a citrus smell and are falling now.  The tree is too tall with no low branches to take a picture of a leave.  Can anyone help?
Offline Southside
Re: Need Help Identifying Tree
« Reply #1 on: June 23, 2018, 02:49:22 PM »
Can you get a picture of the bark?
Offline DelawhereJoe
  • Trapped in Delawhere
« Reply #2 on: June 23, 2018, 03:03:16 PM »
Does it have large heart shaped leaves or compound leaves ?
Online WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #3 on: June 23, 2018, 08:25:26 PM »
I believe that they are immature hickory nuts that have aborted.  This is a very common occurrence to see these small, undeveloped hickory nuts in the heat of the summer.  A bruised, green, hickory nut husk has a very strong, distinctive odor.
Offline ewhite2316
« Reply #4 on: June 24, 2018, 10:38:46 AM »
This is the trunk of the tree and a BAD photo from the ground as there are no low branches.  I also have a large black walnut 30 to 40 feet away and the pods may have blown from it ???
Online WDH
« Reply #5 on: June 25, 2018, 07:54:09 AM »
False pignut hickory, also called red hickory, Carya ovalis.
Virginia Tech Dendrology Fact Sheet
Help identifying a tree
Started by Full Circle on Sawmills and Milling
Last post September 20, 2012, 03:29:42 AM
by SwampDonkey
help identifying tree
Started by dirtmover1250 on Tree, Plant and Wood I.D.
Last post May 24, 2015, 06:50:18 PM
by wdmn
need help in identifying this tree
Started by alsayyed on Tree, Plant and Wood I.D.
Last post January 03, 2015, 04:14:42 PM
by wdmn
Need help identifying a tree
Started by joshcathey on Tree, Plant and Wood I.D.
Last post April 26, 2016, 01:33:13 PM
by mesquite buckeye
