Author Topic: Drilling hole in pallet fork  (Read 1334 times)
Offline Novascotiamill
  • I walked the “Thin Blue Line “ for 20 years
« on: June 25, 2018, 02:03:08 PM »
Been trying to drill 1” hole in tip of my pallet fork to mount a ball to jig some small trailers around that always seem to be in the way. After several failed attempts with regbtwist bits I came across the milwaukee dozer hole saw set and thought id give em a try. Well with a bit of lube they cut thru the fork in about 4 minutes on slow speed.caught all the cuttings in a box so the dog wouldnt cut his feet,also remembered to set the clutch on low! Ill try and attach a photo.
2017 HM130
Stihl 261
2010 F150 xtr
Lots of rigid genx5 tools
1 long haired german shepherd
2017 kioti ck2610HST with FEL and forks
Grindlux band sharpener
Wicked 55” root rake grapple
O
Offline sprucebunny
  • Gender: Female
Re: Drilling hole in pallet fork
« Reply #1 on: June 25, 2018, 02:25:51 PM »
It amazes me that a hole saw will cut thru things better than a regular twist bit, sometimes.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #2 on: June 25, 2018, 03:04:15 PM »
Is that the style hole saw that has carbide cutters on it?
Offline mike_belben
  • Pulp Friction
« Reply #3 on: June 25, 2018, 03:11:12 PM »
Forks are hardened so they will tear up a HSS bit especially going fast.  At 1" you need to be down around 100 RPM for a happy surface speed in steel.
Revelation 3:20
Offline 2308500
« Reply #4 on: June 25, 2018, 04:22:35 PM »
plasma cutter was my drill bit of  choice for fork tips along with a few wet rags for cooling
« Reply #5 on: June 26, 2018, 06:18:07 AM »
According to milwaukee the teeth have a higher cobalt added forvdurability they also have a limited lifetime warranty on tooth breakage. Dont know if the teeth are carbide or not but it feels just as sharp as the unued ones innthe case.
2017 HM130
Stihl 261
2010 F150 xtr
O
Offline Mountain_d
« Reply #6 on: June 28, 2018, 07:05:01 AM »
I want to do the same thing. Has anyone tried cutting a hole in pallet fork with a set of torches?
Mountain.
1978 TJ 230E 3.9L Cummins 4B, Husky 372XP, Husky 61, Husky 266XP, JRed 625, Husky 265RX clearing saw,  Woodmizer LT40HD 1995, Kubota 4950DT (53hp 4WD), Wallenstein V90 Skidding Winch, John Deere 610 backhoe, 1995 Volvo White GMC WCA42T SA Dump Truck, 2004 Ford F-250SD 4WD, , Central Boiler OW
Offline breederman
  • getting by the best way I know how
« Reply #7 on: June 28, 2018, 07:53:03 AM »
Most of the ones I’ve seen were done with a torch, but i hang around with farmers mostly !  ;D
Together we got this !
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #8 on: June 28, 2018, 07:58:59 AM »
I've done it with a torch.  Since forks are hardened steel, care must be taken not to soften them by overheating, so pierce in the center of the desired hole, and quickly work outward and cut the circumference.
Plasma cutters work well, also.  I once cut the tip off a fork with a plasma cutter by mistake when I was cutting a piece on top of the forks.  When I finished the cut I heard a ping, plink and saw that not only had the piece I intended to cut hit the ground but also the top of the fork.  Ooops...
HobbyHardwoodAlabama.com
Offline Southside logger
« Reply #9 on: June 28, 2018, 09:31:21 AM »
A mag drill with a broach bit is your friend in these cases.
Offline John Mc
« Reply #10 on: June 28, 2018, 10:50:33 AM »
You're cutting a lot less metal with the hole saw.
Drilling out emitter hole in bar
Started by rasawing on Chainsaws
Last post July 11, 2018, 05:51:58 AM
by Al_Smith
drilling a straight hole
Started by dovetails on General Woodworking
Last post May 01, 2014, 09:29:10 AM
by Hilltop366
Drilling 1/2" Ř hole into wood on 30-60° angles.
Started by SwampDonkey on General Woodworking
Last post November 27, 2011, 04:00:42 AM
by SwampDonkey
sad
Bent Fork
Started by Bro. Noble on Sawmills and Milling
Last post September 01, 2004, 05:01:01 PM
by Jason_WI
