Author Topic: Help with the l200/kd250 powered vent kit  (Read 420 times)
Offline Hot Shot Rob
  • New Guy
    • Magic city woodworks
« on: June 26, 2018, 04:45:01 PM »
The shop I work at has recently purchased a kd/250 from woodmizer. We also purchased the powered vent kit to go with it as recommended. I have looked through the manual and talked with both woodmizer and nyle about location and how to set up the vent. According to the manual that came with the kiln it states to put the vent on the downwind side (opposite of the dehumidifier) which is where I installed it. After speaking with woodmizer I was initially told it should be installed on the dehumidifier side and then later on in the conversation was told that was for the kd/50 and that for the 200 it was placed right. I just got of the phone with nyle and was told that the fan unit should be on the dehumidifier side and the separate luvered vent should be on the opposite side. Someone please help. Pictures would be greatly appreciated.
Offline Southside logger
Re: Help with the l200/kd250 powered vent kit
« Reply #1 on: June 27, 2018, 12:55:57 AM »
My powered exhaust vent is on the same side as the dehumidifier, the non powered louvers are on the opposite side and it works just fine.
The box which houses the fan sits inside of the kiln chamber with the louvers to the inside as the fan will suck air through the louvers and push it past the fan and out of your chamber. Mine is flush mounted to the stainless steel chamber wall. It does not look right, but it is.
I went through the same exercise you are presently going through before understanding how to set it up correctly.
Also - Be sure to check the voltage set up in the fan motors, my taps were all tied in for 120V.
Offline K-Guy
    • http://www.nyle.com/
« Reply #2 on: June 27, 2018, 08:32:09 AM »
Hi Rob
This may help
Stan from Nyle.
Solar powered Nyle L200??
Started by ATLGA on Alternative methods and solutions
Last post April 03, 2012, 10:19:07 AM
by jdonovan
powered vent for kiln
Started by stevareno on Drying and Processing
Last post February 27, 2012, 01:50:03 PM
by Den Socling
Getting to 8% KD250
Started by Woodslabs on Drying and Processing
Last post September 09, 2018, 07:17:31 PM
by WDH
KD250 fan switch issues
Started by Southside logger on Drying and Processing
Last post October 13, 2018, 09:48:13 PM
by scsmith42
