Author Topic: Staging area  (Read 276 times)
Offline jfruge
Staging area
« on: June 27, 2018, 03:36:36 PM »
Well I plan on going through with this and building a timber frame shop. I am very OCD when it comes to prep work. I was looking for any tips on where you stored timbers while you are cutting. What kind of orginization did you have? How did you lay them out. I live in Louisiana. Lots of humidity and brutal sunny days with rain. My longest timbers will be 16 ft. The sizes will mainly be 6 x 6 and 6 x 8. I'll be using southern yellow pine. Not treated. Or should I get them all treated? I am pouring my slab first. It gets a lot of afternoon shade. I have a 2 car garage with a half stall that I use as a "shop". I could store them in there. It's 9' x 22'. Also has anyone ever sealed the timbers once they are up or before raising? With like a water seal or varnish for protecting it
Thank,
James
Offline fishfighter
Re: Staging area
« Reply #1 on: June 27, 2018, 04:07:58 PM »
What part of Louisiana you in? Me, just North of BR.
Storing your timbers, best is out of direct sun. Having air movement is a big plus. Having them stacked and stickered level is a must. If it was me, I would wax the ends and cuts.
Having them treated, I would pass on that unless the post and beams will be exposed to the weather in the long term.
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
Re: Staging area
« Reply #2 on: June 27, 2018, 04:18:41 PM »
End coating with anchorseal should be done soon as they are cut to length.
lots of air flow as mentioned. blocks or stickers every two feet.
Jim Rogers
Offline jfruge
Re: Staging area
« Reply #3 on: June 27, 2018, 04:52:00 PM »
I am just north of lake Charles. I have a 2 car garage that doesn't have a back wall. From the road it looks like a garage bc of the doors. When you open the doors you have a carport. I could probably stack them there. Air flow and it's out of the sun.
Offline TimFromNB
  • New guy here.
Re: Staging area
« Reply #4 on: June 28, 2018, 09:30:43 AM »
For storing in the garage, I would just make sure you can easily access the pieces in stack as you need to. I imagine you will be handling them frequently. If you need to use a tractor, you might be restricted.
Best of luck!
Tim
Staging some logs.
Started by Skoalbandit78 on Sawmills and Milling
Last post November 30, 2012, 09:38:48 PM
by Ohio_Bill
Staging Logs with my Logrite Fetching Arch
Started by pnyberg on Sawmills and Milling
Last post September 08, 2009, 09:39:10 PM
by Don K
Mechanicsville Va. area
Started by TexasTimbers on Sawmills and Milling
Last post February 16, 2009, 02:28:04 PM
by ARKANSAWYER
Hard Hat Area
Started by WV Sawmiller on The Outdoor Board
Last post September 21, 2016, 10:08:13 AM
by Den Socling
