AVAILABLE
Author Topic: Foam filled tires?  (Read 1958 times)
Offline Maine logger88
  • Don't force it get a bigger hammer
Foam filled tires?
« on: June 27, 2018, 09:36:43 PM »
Has anyone ever tried it? The caster wheel on my bell has been troublesome ever since I got it. Every once in awhile it will get knocked off the bead and today I drove a stick through it. I was thinking rather than buy a new tire Iíd have that one filled with foam
Offline Loghauler86
Re: Foam filled tires?
« Reply #1 on: June 27, 2018, 09:57:58 PM »
We have a Morbark three wheeler with a foam filled castor tire. Yes, it obviously hasn't gone flat but it is rough. If you hit a stump or something you really feel it. I don't know that I'd do it again, that's how bad it is.
« Reply #2 on: June 27, 2018, 10:09:54 PM »
Ok thatís good to know! I went from 35psi to 50 which helped keep it on the bead and I could definitely tell the difference in the ride with that so foam would probably be back breaking then. I know I cringe now when I stand it on its nose cause I know itís gonna hurt when it comes back down...
Offline mike_belben
  • Pulp Friction
« Reply #3 on: June 27, 2018, 10:55:40 PM »
My bobcat tires are hard foamed but i dont think its any rougher than normal since they run about 80psi.
Hare scramble racers fill wheels with tennis balls or pool noodles so they can still race on flats.  I wonder if soccer balls would hold up.
Revelation 3:20
Offline Skeans1
« Reply #4 on: June 27, 2018, 11:16:06 PM »
What about the run flat cushion tires make them for fork lift sizes maybe one will be close enough.
Offline Riwaka
« Reply #5 on: June 27, 2018, 11:26:53 PM »
Trophy trucks can run bead locks and tire sealant.
Racing Prevent & Repair Flat Tires With Monster Seal Tire Sealant
Defense and Off Road heavy haulers can have bead locks to keep the tire on the wheel rim.
Off-The-Road - OTR Beadlock | Hutchinson Industries | Home | Hutchinson Industries | [url=http://www.hutchinsoninc.com]Home | Hutchinson Industries | www.hutchinsoninc.com[/url]
Bell has made a number of versions of the castor wheel attachment for their machines. If the tire is undersized, it can be a case of modifying the rear of the Bell to take a larger wheel and tire.
Bell two rear castor wheels -Bell 220C
Offline John Mc
« Reply #6 on: June 28, 2018, 10:53:17 AM »
At one point, I read about someone selling foams of differing stiffness to allow for firmer or softer rides, depending on which you chose. I've never tried it myself, however.
Offline mike_belben
  • Pulp Friction
« Reply #7 on: June 28, 2018, 10:56:38 AM »
Yes, there are different density.  4lb, 8lb and 16lb are the typical 2 part foam products i have seen.
Revelation 3:20
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #8 on: June 28, 2018, 12:00:34 PM »
do a search for airless tire. that is probably the best you can get. unfortunately they will collect lots of junk in them.
I knew what I thought I meant.
Offline nativewolf
« Reply #9 on: June 28, 2018, 01:36:43 PM »
Mich makes the Tweel
https://www.michelintweel.com/
I have foam filled my Case 7130 front tires, needed the weight.  It added 3k pounds to each tire, helped me out in a very specific instance of having to balance this 12k lb mulching head on the pto.
However, I think I'd try the tweel if you could find one that fits, onen't be cheap but they are neat.
Liking Walnut
Offline nativewolf
« Reply #10 on: June 28, 2018, 01:37:15 PM »
Meant to add, we rented a telehandler with Tweel's the other week.  Very nice ride.
Liking Walnut
« Reply #11 on: June 28, 2018, 04:44:20 PM »
Great ideas guys! I just ended up ordering a new tire. Hopefully being a new sidewall and bead it will hold up better than the old one. I would have looked into other options but I have to have it going ASAP.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #12 on: June 29, 2018, 07:40:38 AM »
I typically find the older the tire the more durable it is. Seems once you mount them on something they just keep getting harder.
Offline ehp
  • logger/chainsaw hack
    • ehpsaws.com
« Reply #13 on: June 29, 2018, 07:59:14 AM »
You cannot keep the beads on my skidsteer tires here in this sand as machine is sunk abit at all times so when you turns the tire comes off the rim and I was running 65 psi, I put tubes in my tires and have not had a problem sense
Offline mike_belben
  • Pulp Friction
« Reply #14 on: June 29, 2018, 08:23:36 AM »
You cant let skid steers leak down at all or theyll fall right off the bead.  I kinda cant believe they dont utilize a safety bead rim.  Nothing scrubs sidewalls like a SSL.  I must have wasted 20 cans of ether over a tire with a slow leak many years ago, it came off constantly.  Winter is the worst for getting tires seated.
Revelation 3:20
Offline barbender
« Reply #15 on: June 29, 2018, 10:06:31 AM »
I have put many, many hours in skid steers and I can only think of one time I knocked one off the bead. That time I think I had a low tire and didn't notice.
Offline ehp
    • ehpsaws.com
« Reply #16 on: June 29, 2018, 09:53:15 PM »
then come here :D, I told Bobcat I wanted new tubes in the tires on my new skidsteer, they said I did not need them as you could not knock the tire off the rim, their truck driver knocked one tire off the rim unloading the new machine , the sand here is bad and very light . You have to watch what your doing just to not get stuck
Offline JB Griffin
« Reply #17 on: June 29, 2018, 11:18:10 PM »
Local guy got the tail wheel foamed for his bell, had the tire on for two days before he bought a new tire and wheel. :D
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2.5 million bdft sawn with a Baker Dominator and counting.
Offline woodmaker
« Reply #18 on: July 03, 2018, 09:46:52 PM »
I have a 530 dresser loader that came from a metal recycling business that has foam filled tires. The tires are all cut up,with cuts through the cords and large bolts sticking out. That machine rides a lot rougher than the other two that have air filled tires. Is is also way slower over the road,although I am not sure if the lack of speed is a tire issue or a converter issue.
franklin q80,builtrite 40,husky 372,sachs dolmar 123, dozers,excavators,loaders,tri-axle dump trucks ,autocar tractor with dump,flatbed and detachable trailers, and 8  f350 diesels
Offline mike_belben
  • Pulp Friction
« Reply #19 on: July 03, 2018, 10:58:20 PM »
 :o  i cant imagine what those weigh.  I can barely lift a foamed 16.5 bobcat wheel.
Revelation 3:20
DIY foam filled tires?
Started by coalsmok on General Board
Last post July 16, 2017, 07:34:30 AM
by drobertson
question
Foam filled tires ??
Started by Bibbyman on Forestry and Logging
Last post January 26, 2003, 09:45:28 PM
by Frank_Pender
Bobcat and foam filled tires
Started by Stephen1 on General Board
Last post January 16, 2013, 10:00:34 AM
by Weezer
NEW TRACTOR! , Tires filled?
Started by uplander on General Board
Last post January 07, 2014, 09:21:10 AM
by chevytaHOE5674
