Author Topic: Looking for advice on chain sharpeners for slabbers  (Read 1661 times)
Offline Fether Hardwoods
« on: June 29, 2018, 10:13:01 AM »
I am running a Peterson slabber, and have come to the conclusion that a sharpener is appropriate for my opperation. So what are you slabber folks using for grinders? It came with a bar mount grinder that is a joke.
Offline maderahardwoods
  • California Sawyer
    • Madera Hardwoods
Re: Looking for advice on chain sharpeners for slabbers
« Reply #1 on: June 29, 2018, 02:29:44 PM »
I have the Lucas DSM and sharpen by hand. The mill came with a fixture that attaches to the mills frame rail, the fixture has a 10 degree scribe to guide your eye.
This works best for me, I have the hydraulic Oregon grinder but cant use it as i have replaced teeth at various points.  It is also probably faster to hand sharpen as the rakers have to be sharpened every time.  If you are only sawing clean wood, the electric grinder could work. I would not want a sharpener without the hydraulic locking feature to hold the chain in place.
-Marco
Offline Joey Grimes
  • Quality is remembered long after price
« Reply #2 on: June 29, 2018, 09:54:33 PM »
I recently purchased the grandberg grind an joint and I am very happy with it I don’t think anyone can do as good a job by hand I know I can’t I can do my 60 inch chains for my Lucas in about 10 min .
94 woodmizer lt40 HD kabota 5200 ford 4000 94 international 4700 flatbed and lots of woodworking tools.
Offline xlogger
« Reply #3 on: June 30, 2018, 05:24:37 AM »
I have two grinders one for sharpening and the other set for lowering the rakers.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #4 on: June 30, 2018, 04:57:17 PM »
I have an Efco grinder, made in italy,  its about 20 yrs old.  For any kind of chain sharpening.  I also use a 4mm ABN wheel that I got from Bailey's which I recommend.  I think the brand was Dinasaw. It cost about $250 but what I like is that it doesnt wear and change shape as it is used.  I sharpen slabber chains at 15 degrees (viewed from the top) and set the grinder angle at 60 degrees (from horizontal).  Unless there is damage the grinding takes off very little metal. No reason I couldnt sharpen by hand file.
If I were to get another grinder I would check out whatever people recommend here, and what Bailey's sells.  Probably would be one of the more expensive Oregon ones.  But I don't really need to get a new one.
DJ Hoover, Terrific Timbers LLC,  Mystic CT  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Online YellowHammer
  • Work = Force X Distance
    • Hobby Hardwood Alabama
« Reply #5 on: June 30, 2018, 10:42:15 PM »
I don't have a slabber but sharpen a lot of chains. I have a Stihl USG grinder, same one the Stihl dealers use.  Very good machine, no slop, excellent results.
HobbyHardwoodAlabama.com
Offline scsmith42
    • Whispering Pines Farm
« Reply #6 on: June 30, 2018, 10:57:14 PM »
I bought an Italian knockoff of an Oregon electric chain sharpener from Bailey’s about 10 years ago.  We’ve sharpened a LOT of chains on it, including the slabber chains.  It was around $180 back then but the price has come down.
Put a CBN wheel on it; you won’t regret it.
Tom's 3638D Baker band mill
Offline sam-tip
« Reply #7 on: July 06, 2018, 01:51:57 PM »
Oregon 511AX and 620 hydraulic assist with CBN wheels.  Carry 6 190 DL chains.  Just keep switching chains and sharpen at home.
CB E WiFi
stumpy 395xp, 346xp Wicked 562xp
Mastermind 355t, 201CE, 3120xp 20" 36" 44" 60" 72"
Super Split Special Editions TM 24 and 30 splitter
D&L 1020 mill
Online oakiemac
  • God bless the U.S.A!
    • Hickoryandoak
« Reply #8 on: July 09, 2018, 10:59:36 PM »
I have an Oregon grinder with a CBN wheel. Works great. I'm thinking of getting a cheap one just for the rakers.
Offline Silverfoxfintry
« Reply #9 on: December 28, 2018, 04:10:03 AM »
I have a "Carlton" electric sharpener. The biggest chain I sharpen is 186 links. Far too long to do by hand. Changing the chain on a double ended mill is a pain!
By the way, what is a "CBN" wheel?
Wet and warm in Scotland today +8c.
Thanks. Silverfox.
Online longtime lurker
« Reply #10 on: December 28, 2018, 04:49:17 AM »
Standard Oregon grinder. I hand sharpen chainsaw chains but slabbing chains I use a grinder. I buy chains in sets of two or three and keep rotating them : that way I can toss anyone at the chain sharpening/ raker filing task and they can't really screw it up, and they can be sharpening while I cut
Offline scsmith42
« Reply #11 on: December 28, 2018, 04:33:10 PM »
Thanks. Silverfox.
CBN - Cubic Boron Nitride - a synthetic material that is better than industrial diamond for sharpening chainsaw chains.
« Reply #12 on: December 28, 2018, 05:24:49 PM »
CBN wheel is a steel wheel coated with CBN.  The wheel has a profile determined by the shape of the steel, and the profile does not change as the wheel is used.  So you do not have to re-shape the wheel. This and the long life are the main advantages.  The CBN coating lasts a very long time and you buy a new wheel when it gets worn off anywhere.
They cost a lot more than pink, white or blue vitreous wheels.  In addition to the long wear, no changing profile, a CBN wheel doesn't throw off wheel dust in use. Just the material that is being ground gets thrown off.
Another material very similar to CBN is ABN (Amber boron nitride rather than Cubic Boron Nitride).   Some available chainsaw grinder wheels have ABN on them.
Offline offrink
« Reply #13 on: December 28, 2018, 11:34:02 PM »
I use a 59” and a 72” bar 880 with a custom mill. 7-59” milling chains and 5-72” milling chains. I take them in to the local dealer to get them sharpened. He cleans them, sharpens them to 10° or whatever I tell him, tags them with the date sharpened, and gets them back to me the same day 6 days a week. Best of all, it’s $15 a chain. If it takes him 25 minutes to do all that then I would lose money doing via taking away my time and a poorer quality finish.
Offline trapper
« Reply #14 on: December 29, 2018, 12:19:18 AM »
I bought a 3/16 cbn at the logging congress in oshkosh last fall.  Any recommendations  on where to get a 1/8 one?  ff supporter preferred.
stihl ms241cm ms290  echo 310 400 suzuki  log arch made by stepson several Logrite tools woodmizer LT30
Offline LAZERDAN
« Reply #15 on: December 29, 2018, 07:04:09 PM »
Maybe try Laona supply.  They have a lot of stuff   Lazerdan
Looking for advice on Peterson slabbers
Started by Fether Hardwoods on Sawmills and Milling
Last post December 12, 2018, 09:41:51 PM
by longtime lurker
chain sharpeners
Started by Don R on Chainsaws
Last post June 12, 2005, 09:02:31 PM
by Striker
Chain sharpeners!
Started by KPSTIHLSAW on Chainsaws
Last post February 21, 2010, 11:53:45 PM
by LorenB
ELECTRIC CHAIN SHARPENERS.
Started by KDEC19 on Chainsaws
Last post December 26, 2003, 09:32:56 AM
by Kevin
