Author Topic: skidsteer weights  (Read 632 times)
Offline farmfromkansas
skidsteer weights
« on: June 29, 2018, 10:47:43 PM »
Built some pallets after looking at YellowHammer's posts, and find I can not handle many layers of lumber with my skidsteer.  Higher I want to set the pallet, less I can load on the pallet.  Anybody have weights on the rear of  a skidsteer?  Mine is a Case, 60xt.  Talked to some guys who sell seed, heavy pallets, they said my tractor would not handle any more weight than the skidsteer, when I was considering forks for my 4020.
Offline mike_belben
  • Pulp Friction
Re: skidsteer weights
« Reply #1 on: June 30, 2018, 12:17:14 AM »
To unload mafia blocks we used to chain a 6" steel round stock about 5ft long to the rear chain pockets on my dads LS170.  Just use the bucket to wheelie the machine, roll the thing onto the two basket chains, clevis back to machine and off you go.
Revelation 3:20
« Reply #2 on: July 01, 2018, 12:41:03 PM »
Thanks Mike, have a piece of RR rail that I could use.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #3 on: July 01, 2018, 02:01:44 PM »
I used to run a Bobcat 843 with a 3'x5'x2.5" thick steel plate bolted underneath it. If you put the bucket on and tried to move forwards, it would just wheelie up. I don't think the tree spade has been off it in about 15 years.
Offline Brian_Rhoad
« Reply #4 on: July 01, 2018, 11:24:13 PM »
We have a 300 lb. chunk of steel bolted behind each rear wheel on our Bobcat 943. It will lift a 500 bf 42" wide bundle of White Oak with no problem.
Offline mike_belben
  • Pulp Friction
« Reply #5 on: July 02, 2018, 06:09:29 PM »
I have wanted a bobcat/barko 980 since i found out they existed. Someday -when the very last spare part on the shelf has been sold- i will have one.
Revelation 3:20
Log weights
Started by Robert R on Forestry and Logging
Last post October 28, 2005, 10:17:33 AM
by OneWithWood
Log weights
Started by Sawyerfortyish on Forestry and Logging
Last post October 14, 2004, 07:16:19 PM
by Sawyerfortyish
Wheel Weights
Started by ncsawyer on Sawmills and Milling
Last post December 10, 2016, 10:53:32 PM
by Andries
woodworking weights
Started by hackberry jake on General Woodworking
Last post January 28, 2015, 09:36:39 AM
by JohnM
