Author Topic: Cheat sheet  (Read 1000 times)
Offline dean herring
Cheat sheet
« on: July 01, 2018, 10:24:34 PM »
Iíve got a lot of 1x12 pine boards to cut and am looking for a way to speed up the process. Iíve seen somewhere on here some have made up a list of measurements to hit the next cut without having to stop each time to figure or move the magnetic strip each time. Thanks for any advice
Failure is not an option  3D Lumber
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Cheat sheet
« Reply #1 on: July 01, 2018, 10:29:10 PM »
   I use one pretty religiously. Mine is set up for 1/8" kerf. BTW - I have SimpleSet on my mill so I start on one of the marks and it moves the distance programmed in every time I toggle the switch. I'd probably quit sawing if I did not have a setworks system.
Offline Ron Wenrich
Re: Cheat sheet
« Reply #2 on: July 02, 2018, 12:15:51 AM »
I worked for a number of years where I had to build the stack in my head.  After you get the math behind it, it isn't that hard.  But, I did have a setworks that pulled the same stroke for each cut.
For the math, I was running a circle mill.  For every 2 4/4 board, I needed to add 2ĺ" to the target size.  If you're running a band mill, you would reduce that to what suits you.  Multiples of my 2ĺ" would be 5Ĺ", 7ľ".  Add that to your target size, then set and go.
Without a setworks, you need to add 1 3/8", 2 3/4", 4 7/8", etc. to build your stack.  Adjust for your board thickness and kerf.
Offline Crossroads
  • letís make some sawdust
    • Kevin Bales faith family farm and portable sawmill
Re: Cheat sheet
« Reply #3 on: July 02, 2018, 01:01:52 AM »
I have a cheat sheet but have switched to the sawmill calculator app on my phone.
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins
Offline bandmiller2
Re: Cheat sheet
« Reply #4 on: July 02, 2018, 06:27:59 AM »
My band mill is of my own manufacture and uses a simple aluminum yardstick and pointer. I go down the cant one inch at a time which gives me about a 7/8" board. I have never had anyone complain. It sure makes figuring easy. My circular mill has a setworks that figures in the kerf, cheat sheet is only used to start the cut and have the boards end up right, no sliver cuts. Frank C.
Offline moodnacreek
  • Sawin by the notches
Re: Cheat sheet
« Reply #5 on: July 06, 2018, 08:01:22 AM »
The notched lane set works eliminates most of the math. I don't know how I used to saw without it.
I guess I just have to cheat
Started by Qweaver on Timber Framing/Log construction
Last post April 03, 2011, 04:22:55 PM
by Jim_Rogers
Woodmizer lt35 hd log loading cheat with a Logrite
Started by mrector on Sawmills and Milling
Last post August 21, 2014, 06:18:00 AM
by Nomad
Bid sheet sent out.
Started by gizmo on Forestry and Logging
Last post August 18, 2018, 08:48:09 PM
by gizmo
sheet rockers-ugh
Started by bman on Timber Framing/Log construction
Last post September 15, 2006, 07:16:14 AM
by Norm
