Author Topic: Spline joint question  (Read 263 times)
Offline jfruge
« on: July 02, 2018, 02:34:18 PM »
My tie beam going from my center post to my outer post will be and 8x10. On the side of the building I plan on doing a lean to. This lean to will serve as a car port. No insulation, minimal wood, and probably metal roof vs asphalt shingles for the main building. If I were to join the main tie beam to the lean to tie beam with a spline joint do the beams have to be the same size? I did the calculations and an 8x8 tie beam will be more then enough. The outer post will be an 8x8. Just seeing if I can change the beam size with a spline joint, or is their a better way to join this?
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
Re: Spline joint question
« Reply #1 on: July 02, 2018, 02:59:47 PM »
Follow the spline rules of thumb:
For the smaller timber if different heights so that you don't cut into the smaller one too much.
You may have to zoom in to read the text.
Jim Rogers
Spline Joint Drawing?
Started by jander3 on Timber Framing/Log construction
Last post June 06, 2012, 11:51:39 AM
by Thehardway
Scarf Joint question
Started by billyO on Timber Framing/Log construction
Last post April 15, 2011, 11:56:31 AM
by witterbound
log spline
Started by surfsupinhawaii on Timber Framing/Log construction
Last post August 22, 2007, 06:14:15 PM
by iffy
spline vs. scarf
Started by bigshow on Timber Framing/Log construction
Last post June 07, 2007, 09:37:49 PM
by fjc
