Author Topic: drying under a plastic sheet  (Read 729 times)
Offline forrestM
« on: July 06, 2018, 05:25:38 PM »
Hey Folks,
Just wanted to see if what i'm doing right now will work for drying some 6.5x.5" poplar boards. I have them stacked and stickered indoors - and i've made a crude tent out of plastic to contain the wood, a fan, and a dehumidifier. I had it all set up in the room, minus the plastic, but it was getting so humid in there from the wood. Will this setup work, having it all within this plastic bubble? Hoping it will speed my drying up. Please let me know if i am totally screwing this up!
thanks,
Forrest
Online GeneWengert-WoodDoc
Re: drying under a plastic sheet
« Reply #1 on: July 07, 2018, 01:55:52 AM »
You are on target if the dehumidifier is large enuf.  That is, we need to remove the moisture fast enough to prevent discoloration, so we need a large enuf DH unit.
Online kelLOGg
« Reply #2 on: July 07, 2018, 06:26:00 AM »
Before I built my DH unit I did exactly the same thing. It worked great (except for crawling under the tarp to check MC%). Then I built my walk-in kiln.
Bob
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline forrestM
« Reply #3 on: July 07, 2018, 11:27:02 AM »
Yeah, the only problem so far is getting in and out!
Do i want to incorporate a heater? would that help or hinder?
thanks!
more drying under a plastic sheet
Started by forrestM on Drying and Processing
Last post July 11, 2018, 06:22:45 PM
by Ianab
Bid sheet sent out.
Started by gizmo on Forestry and Logging
Last post August 18, 2018, 08:48:09 PM
by gizmo
Cheat sheet
Started by dean herring on Sawmills and Milling
Last post July 06, 2018, 08:01:22 AM
by moodnacreek
sheet rockers-ugh
Started by bman on Timber Framing/Log construction
Last post September 15, 2006, 07:16:14 AM
by Norm
