Author Topic: Woodmizer debarker question  (Read 671 times)
Offline delvis
  • "I jus' 'bout 'magine"
« on: July 10, 2018, 07:04:38 PM »
Hey folks,
My debarker is starting to get a little play in the pivot point between the vertical arm and the horizontal arm so it looks like it is time for a new pin.  On the WM site parts breakdown it doesn't appear there are any replaceable bushings.  Does anyone know what the two screws are on either side of the grease fitting in the pivot point barrel?
Thank you,
Mike
If I never saw another board I will at least die happy having spent the last few years working with my dad!
Offline Chuck White
  • Sawing Mobile since 2005
Re: Woodmizer debarker question
« Reply #1 on: July 11, 2018, 07:22:17 AM »
Retainer screws!
They hold the hinge pin in place!
~Chuck~
Offline delvis
« Reply #2 on: July 11, 2018, 10:27:33 AM »
Thanks, I figured that must be the case but haven't actually disassembled it to find out.
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
« Reply #3 on: July 11, 2018, 10:37:36 PM »
Hello,
 The screws keep the assembly from going over center. You remove them and push the assembly up to remove the springs. Well that is what I do any way. I do not think  :-\ the cap screws touch the pin. Most all the debarkers with some hours have play in this area. I replace the pin and it helps.
Marty
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
Offline Beavertooth
« Reply #4 on: July 12, 2018, 11:14:42 AM »
Mine did not come with a grease fitting anywhere on the debarker pivot pin and after 4200 hours has a great amount of play in it. Never understood why no grease fitting when it is one of the most moving parts on the mill.  LT70
2007 LT70 Remote Station 62hp cat.
Offline delvis
« Reply #5 on: July 12, 2018, 11:43:37 AM »
It would be nice to have replaceable bushings in this area for sure. For now I'll pick up a new pin and replace that.
woodmizer debarker question
Started by wills swamp on Sawmills and Milling
Last post March 01, 2014, 10:40:03 AM
by wills swamp
Woodmizer wide head debarker question
Started by JSTOM on Sawmills and Milling
Last post January 23, 2019, 12:19:23 AM
by Crossroads
woodmizer wiring question for debarker/lube-mizer and auto-clutch
Started by Dan_Shade on Sawmills and Milling
Last post April 03, 2008, 09:52:44 PM
by farmerdoug
debarker for woodmizer
Started by Gustavo on Sawmills and Milling
Last post April 14, 2007, 07:16:25 PM
by Dan_Shade
