Author Topic: I think my mill has a drinking problem  (Read 2114 times)
Offline Mt406
« on: July 11, 2018, 03:42:27 PM »
My day is going good cutting lap siding for my own house.
Customer picks up his order and asks if cash is all right. (if you insist)
Have a quick bite and back to the mill.
Just before lunch cut 20 wide no problem.
After lunch I am just cutting along (maybe just a little Cocky I have cash in my pocket and were cutting good) And at the 7ft mark a little dive were ok life still good.
Now at 13 ft off on walk about.
19 in cut 4degree blade  Pondarosa pine green.
Have a good chuckle.
Hopefully your mill wasn't drinking at lunch :)
Offline Pjames
Re: I think my mill has a drinking problem
« Reply #1 on: July 11, 2018, 03:59:35 PM »
Looks like time for a blade change 🙈🙈
Offline Mt406
« Reply #2 on: July 11, 2018, 04:04:03 PM »
new at start of log and another new now
Offline Pjames
« Reply #3 on: July 11, 2018, 04:21:50 PM »
Did second one fix it??
Offline mike_belben
  • Pulp Friction
« Reply #4 on: July 11, 2018, 10:38:27 PM »
Apparently the blade was drinking at a dive bar.
Revelation 3:20
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
« Reply #5 on: July 11, 2018, 11:02:11 PM »
Overheated blade? Not drinking enough fluids ???
I've seen cuts like that in wide spruce.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Offline Mt406
« Reply #6 on: July 12, 2018, 12:58:35 AM »
New  blade helped some.
That was one log that didn't want to be lumber.
I use diesel on my blade instead of water.
Had so much pitch build up even with diesel drip every 2 seconds
Saw dust was so sticky it would build up on mill and fall off clumps
And yes the blade got hot and lost tension.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #7 on: July 12, 2018, 08:19:10 AM »
Some logs are just like that.  Difficult.  Like some people.
Offline delvis
  • "I jus' 'bout 'magine"
« Reply #8 on: July 12, 2018, 11:49:13 AM »
I used to used off-road diesel mixed with ATF.  I switched over to water and Dawn dish washing soap and it works so much better, is hundreds of times cheaper,and I'm not dripping fuel all over the ground and my finished product.  Helps greatly to have a powered blade lube system too!
If I never saw another board I will at least die happy having spent the last few years working with my dad!
Offline KODAK
« Reply #9 on: July 12, 2018, 12:59:23 PM »
Nice! Does the blade develop surface rust with the water sitting on the blade on guides?
Offline MobileSawMilSlo
  • New owner just learning and working
    • Mobilna zaga - Slovenia
« Reply #10 on: July 12, 2018, 03:16:17 PM »
Hi
My experience is that I MUST NOT cut pine with blades less than 10 degrees.
If I would use 7 degrees I would get big waves like yours. But this is pine here in Slovenia and yours is sure different.
Offline CX3
« Reply #11 on: July 12, 2018, 07:33:06 PM »
Walkabout lol
John 3:16
You Better Believe It!
Offline LoneDuck
« Reply #12 on: July 12, 2018, 08:41:54 PM »
I understand your pain. I'm trying to get enough of more or less the same pine to finish the house and cring when it happens. I have such a hard time finding logs and any waste is hard.
Offline Mt406
« Reply #13 on: July 13, 2018, 01:03:43 AM »
I may try going back to water and cascade I have some of that around the saw shed.
I am thinking with the pitch build up and long wide cuts I am getting heat in the blade.
The next batch of Pondo are long logs 18-20s I going to buck them to shorter length.
I was side tracked today will be back at the saw dust mine tomorrow.
I will post as things progress.
Offline Brucer
« Reply #14 on: July 15, 2018, 10:21:41 PM »
Water will do a better job of cooling the blade. You will probably go through it pretty quickly ;D.
Offline ljohnsaw
« Reply #15 on: July 16, 2018, 12:51:19 AM »
I cut down some Pondarosa and it was oozing sap.  So I figured I pour on the water/pinesol.  Blade kept diving.  Stopped the water and it cut fine.  Another log, another blade and same results - water, dive - no water, fine.  Go figure.
John Sawicky
Offline thecfarm
« Reply #16 on: July 16, 2018, 05:28:18 AM »
KODAK,welcome to the forum.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #17 on: July 16, 2018, 06:05:32 AM »
I cut all the time dry, If I get some pitch I turn on plain water for one or two cuts and the blade is clean. What happens is most guys cut too slow. That heats up the blade and you have trouble. Sharp blade and cut as fast as the mill will cut and have less trouble. For me mixing all the junk in the lube is a waste of time. Now if you want to cut faster push the set out on the blade. You will have more sawdust and cut lumber at the end of the day.
Good luck.
A&P saw Mill LLC.
License NH softwood grader.
Offline PA_Walnut
« Reply #18 on: July 16, 2018, 07:05:50 AM »
Looks like the work of the infamous Turbo7! (on my wide, they are NO DEAL for big cuts). :-\
As Peter says, going too slow heats the blade, but going too fast slows it down and causes The Dive...delicate dance.
Odd for a 4 though. I think you could cut steel beams with those things!  :D
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Baker Portable Edger with Kubota Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Offline 123maxbars
    • www.outofthewoodsforestry.com
« Reply #19 on: July 16, 2018, 08:28:52 AM »
well said,
Sawyer/Woodworker/Timber Harvester
W/M LT40HD, W/M KD150 Dehumidification Kiln Mahindra 4550, BMS 250 Sharpener, BMT 150 Setter, MS880 chainsaw mill,
outofthewoods
Youtube page
Out of the
smiley
A drinking problem
Started by Ianab on General Board
Last post March 24, 2005, 07:50:32 PM
by Ed_K
Am I drinking too much?
Started by DouginUtah on FOOD! FOOD! FOOD!
Last post February 19, 2012, 05:59:13 AM
by SwampDonkey
Drinking permiate water
Started by Chuck White on Health and Safety
Last post March 20, 2018, 07:07:54 AM
by Chuck White
No Mill Yet...Yet, No Problem.
Started by tcsmpsi on Sawmills and Milling
Last post May 06, 2006, 01:03:19 PM
by tcsmpsi
