Author Topic: Adjustments to a chain mortiser.  (Read 1005 times)
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
« on: July 16, 2018, 06:11:16 PM »
I was using a brand new just out of the box chain mortiser today. And I realized that it needed a minor adjustment to make it better.
When you plunge in the third position the bar wasn't going over to it's maximum throw.
In the below picture you see where it did cut and how much more it gained after I adjusted it:
when you want to make it cut the maximum you adjust this bolt:
at red arrow
Loosen the jamb nut and move the bolt until the round roll pin in the red circle is at the maximum position.
This will gain you this much:
About 3/4 of an inch.
Nice new machine.
Jim Rogers
Offline Andries
  • Making buildings out of big curvy logs
Re: Adjustments to a chain mortiser.
« Reply #1 on: July 23, 2018, 07:38:10 PM »
Thanks for posting this Jim.
Could you please identify the make of chain mortiser - and no, I won't take it as either an endorsement or criticism. 😆
LT30G24
Ford 545 Series loaders
Stihl chainsaws
Offline Jim_Rogers
  • Board Moderator
    • jrsawmill.com
« Reply #2 on: July 24, 2018, 07:21:39 AM »
Makita (7104L) I believe that is the model number.
Jim Rogers
Offline Geeg
  • Living the Dream!
« Reply #3 on: August 12, 2018, 05:22:07 AM »
Hi Jim,
Nice, I will check mine to see if I can get any extra range. Have you sharpened your chain yet? Mine is getting dull and needs a sharpen but don't know what the best way would be.
Geeg
Airbus 380 Captain, living in the Middle East, counting down the days till retirement. Timberking 2200,  Kioti RX6010PC,  Nyle Kiln KD250, Polaris WV850
Offline Jim_Rogers
  • Board Moderator
    • jrsawmill.com
« Reply #4 on: August 12, 2018, 09:33:54 AM »
I do have a spare chain I can use when I need to send mine out to be sharpened.
I have a machine shop in ME that does them pretty reasonable.
But I can't find their info right now. I know a friend who has used them and I have just emailed him to ask him to send me their contact info again so I'll have it on hand for you.
Jim Rogers
Offline Geeg
  • Living the Dream!
« Reply #5 on: August 12, 2018, 09:54:24 AM »
Thanks Jim, If I recall, the chains are quite expensive.
Standing by.
Geeg
Offline Jim_Rogers
  • Board Moderator
    • jrsawmill.com
« Reply #6 on: August 12, 2018, 10:14:04 AM »
Last time I checked about $500.
I sold one to a friend for $250 with the deal that I could borrow it back while mine was being sharpened.
Jim Rogers
Offline Don P
    • Calculator Index
« Reply #7 on: August 12, 2018, 10:55:30 AM »
That's a good idea, a shared spare chain. We were looking for the number of the shop in Salem, VA, downtime, etc.  My partner successfully sharpened mine by hand a few weeks ago. I'll see if he remembers which file but you can do it in the field.  I was in white oak and he took it from smoking to almost pleasurable.
Offline rjwoelk
    • countrysidefirewood
« Reply #8 on: October 16, 2018, 10:49:04 PM »
Don did you find out the file size for the mortiser chain?
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
Offline Don P
    • Calculator Index
« Reply #9 on: October 17, 2018, 07:32:54 AM »
Whoops I forgot. We're taking down a yard walnut today, I'll ask the other Don what he was using.
Offline Don P
    • Calculator Index
« Reply #10 on: October 17, 2018, 05:46:59 PM »
5/32" file, straight across 2 at once IIRC.
It was a nice walnut, I hope about $600 worth, I smushed a Husky :'(
Offline rjwoelk
« Reply #11 on: October 17, 2018, 06:24:05 PM »
Thanks Don.
Sharpening a Chain Mortiser chain?
Started by LOGDOG on Timber Framing/Log construction
Last post March 27, 2010, 06:14:40 PM
by Jim_Rogers
Chain Mortiser .....
Started by TexasTimbers on Wanted
Last post December 15, 2005, 12:57:21 PM
by srjones
Mortiser Chain
Started by jimdad07 on Timber Framing/Log construction
Last post February 18, 2016, 10:21:00 PM
by danreed76
Chain Mortiser
Started by flibob on Wanted
Last post October 18, 2013, 10:08:35 AM
by flibob
