Council Tool
Baltic Abrasives Technologies
Author Topic: Just another day in Paradise  (Read 7132 times)
Offline PAmizerman
« on: July 18, 2018, 11:51:57 PM »
I figured its about time I started my own milling thread. Everyone please feel free to post in this thread.
So Western PA has been extremely rainy this year. This week has been no different.
I came out to the mill yard yesterday after 4.25 inches of rain in about 36 hours to find this
Luckily there was no damage to the lumber. So I took five minutes and got it cleaned up
 I set it aside to be sawn into firewood later and got back to sawing and finished the 4x17 beams I was working on
Hydraulics everywhere
Traverse 6035 telehandler
WM bms250 sharpener
WM bmt250 setter
Offline Busysawyer
Re: Just another day in Paradise
« Reply #1 on: July 19, 2018, 12:23:42 AM »
Very nice. I have equipment envy, yours is bigger than mine. I wanted a skytrack but couldn't find one in my price range that wasn't old and ragged out or had a ton of hours. We have had the opposite problem here in west Michigan  hot and humid with little to no rain in weeks. I'm working in a dust bowl over here.
Offline PAmizerman
« Reply #2 on: July 19, 2018, 12:29:50 AM »
If you were closer busy Beaver we could swap equipment back and forth :D
I'd love to get set up with an edger.
How's you're new equipment working out for you?
WM bms250 sharpener
WM bmt250 setter
Offline Busysawyer
« Reply #3 on: July 19, 2018, 12:52:56 AM »
There are definitely days I could use more muscle in the lifting dept . Today for example I had to split a stack of walnut that my bobcat wouldn't lift. I could get it to lift about 2ft but no more. I made a flat stack, no stickers 5ft x 4ft of 11 and 12ft 5/4 and had to scramble to split it so I could get it to the grader in time to get a check this week. My equipment has been pretty good so far.  The mill has had some bugs but with the help of the forumites and woodmizer it seems to be running smooth now. I had some intermittent problems that seem to have been solved with a new ECU. Nothing that's kept me from running, just some hiccups now and then. Anybody who ever turned wrenches knows it's the intermittent problems that are the hardest to solve. When something is flat out broken it's usually pretty easy to diagnose.  The edger has already saved me a ton of time . I don't know how the gas ones are for power but the diesel doesn't even sound like its breaking a sweat feeding it 5/4 walnut or 4/4 hickory and hard maple.
Offline thecfarm
« Reply #4 on: July 19, 2018, 05:19:17 AM »
I was thinking you went to Paradise for the day. ;D
We use to go to the auction there in Loretto. The produce and flower one.
Offline bobborneman
  • Just Starting out
« Reply #5 on: July 19, 2018, 09:11:34 AM »
Just curious,  what are the 4x17 beams going to be used for?
Make it work, use what you have.
Offline PAmizerman
« Reply #6 on: July 19, 2018, 10:23:22 PM »
He is using the beams in a timber frame
WM bms250 sharpener
WM bmt250 setter
Offline PAmizerman
« Reply #7 on: July 22, 2018, 11:16:14 PM »
Got a pic from the customer today
WM bms250 sharpener
WM bmt250 setter
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #8 on: July 23, 2018, 05:57:57 AM »
nice.
Offline Lawg Dawg
  • True South Sawmill Lumber
« Reply #9 on: July 23, 2018, 05:22:43 PM »
WOW! How they cutting them curves? :o
2018  LT 40 Wide 999cc
John Deere 5020, John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
Offline PAmizerman
« Reply #10 on: July 23, 2018, 08:09:05 PM »
I believe he said he was going to use a sawsall
WM bms250 sharpener
WM bmt250 setter
Offline PAmizerman
« Reply #11 on: July 23, 2018, 08:22:41 PM »
We'll when there's no room to expand horizontal I guess the only other option is vertical!!
WM bms250 sharpener
WM bmt250 setter
    • A&P Saw mill LLC
« Reply #12 on: July 23, 2018, 08:36:41 PM »
How about 46'  ;D :D ;)
Offline PAmizerman
« Reply #13 on: July 23, 2018, 09:58:38 PM »
You got me beat Peter. I can only go 32 :D
I'm only half way here
 well a little more than half. That slab pile is stacked 18' high. It needs to get cold out so I can move some of it!
Uh oh I may get banned for that comment. :snowball:
WM bms250 sharpener
WM bmt250 setter
Offline PAmizerman
« Reply #14 on: July 31, 2018, 05:37:03 PM »
Today was an almost wide head day!
I maxed my mill out. The customer wanted a live edge slab from his log.
Got that done and it started raining again.
And I didn't feel like getting soaked bucking logs so I realigned my laser that has been a tad off.
I believe I got this idea from @ElectricAL
It is the quickest most effective way I've found.
Then I got the Bibby attachment permanent on my mill
It really speeds up blade changes.
WM bms250 sharpener
WM bmt250 setter
Offline PAmizerman
« Reply #15 on: August 06, 2018, 11:43:16 PM »
It finally quit raining so I took the opportunity to get my future mill site brush hogged
WM bms250 sharpener
WM bmt250 setter
    • A&P Saw mill LLC
« Reply #16 on: August 07, 2018, 06:21:42 AM »
You will have room there to mill. 8)
Offline PAmizerman
« Reply #17 on: August 07, 2018, 09:45:04 PM »
Yep plenty of room. But 4x4 told me it will fill up fast :D
WM bms250 sharpener
WM bmt250 setter
    • A&P Saw mill LLC
« Reply #18 on: August 07, 2018, 09:54:53 PM »
What are you going to do with the slabs off the logs??
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #19 on: August 08, 2018, 12:11:14 PM »
Build a slab cabin. Make it entirely with slabs :)
Offline PAmizerman
« Reply #20 on: August 08, 2018, 06:39:37 PM »
I sell them cheap for firewood.
I sell them bundled just as they are
And precut by the pick up load.
My slab cutting rack and a 3' bar make short work of it.
WM bms250 sharpener
WM bmt250 setter
Offline PAmizerman
« Reply #21 on: August 09, 2018, 09:53:00 PM »
I'm finally getting some logs in now. It's been so wet here I have not been able to get logs in for a couple months. My stash was getting really low.
Now I'm getting hammered. I had three loggers contact me this week.
I'll be getting a triaxle load in tomorrow.
WM bms250 sharpener
WM bmt250 setter
Offline Busysawyer
« Reply #22 on: August 09, 2018, 10:09:27 PM »
Nice rack! I need to build myself something like that. I have been sliding them off my mill into a pile and using the grappler on my bobcat to pile them into a mountain of mess. Really need to do something about that.
Offline PAmizerman
« Reply #23 on: August 20, 2018, 11:03:32 PM »
Sawed a bunch of live edge slabs the other day. I've been having more and more requests for them.
Anyone ever saw apple?
This was my first time. Not sure how they will dry. It was either slabs or firewood.
And I didn't feel like splitting firewood :D
WM bms250 sharpener
WM bmt250 setter
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #24 on: August 21, 2018, 07:45:32 AM »
Is this close enough?  :)
Offline PAmizerman
« Reply #25 on: August 23, 2018, 09:32:28 PM »
I can't believe I did this :(
Yup that's my firewood cutting rack. I was unloading a log truck today and had customers waiting. I don't even remember backing into it. I never felt it in that big machine. Guess I'll be building another one.
WM bms250 sharpener
WM bmt250 setter
Offline PAmizerman
« Reply #26 on: August 30, 2018, 09:39:39 PM »
Got two more triaxle loads of hemlock in yesterday!! Look at the size of those suckers!!
A couple are around 28" at 25' :o
WM bms250 sharpener
WM bmt250 setter
Offline PAmizerman
« Reply #27 on: September 09, 2018, 09:42:34 PM »
I got a good bit of sawing done last week.
It was hot and humid but it wasn't raining so I took advantage of it. I picked some of the smaller logs out for 1x10's
It's a good day when you get 1x12x14 out of the flitch pile 8)
WM bms250 sharpener
WM bmt250 setter
Offline Lawg Dawg
« Reply #28 on: September 09, 2018, 10:07:58 PM »
Heck, yeah! Now how do you get that sawdust outta ther :o
Pro Sawyer Network
Offline PAmizerman
« Reply #29 on: September 09, 2018, 10:14:27 PM »
One shovel full at a time :o.
I can't wait to get set up at my new location. No more shoveling
WM bms250 sharpener
WM bmt250 setter
Offline PAmizerman
« Reply #30 on: September 09, 2018, 10:18:48 PM »
When that shed was built it was for a lt30.
And it was only going to be a hobby. I was only going to have to shovel sawdust once a year. Well things changed now I saw full time. I don't wanna know how many tons of sawdust Ive shoveled.
WM bms250 sharpener
WM bmt250 setter
Offline PAmizerman
« Reply #31 on: September 15, 2018, 11:41:47 PM »
I started building another slab cutting rack. This one's gonna be just a little more stout than my last one :D
WM bms250 sharpener
WM bmt250 setter
    • A&P Saw mill LLC
« Reply #32 on: September 16, 2018, 07:07:30 AM »
That will work for a while.  smiley_thumbsup
Offline Bruno of NH
« Reply #33 on: September 16, 2018, 07:09:24 AM »
Nice
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline PAmizerman
« Reply #34 on: September 21, 2018, 09:24:06 AM »
Got er finished yesterday!! Works like a charm
WM bms250 sharpener
WM bmt250 setter
Offline PAmizerman
« Reply #35 on: October 01, 2018, 09:20:07 PM »
Ever have one of those days?
Seems I couldn't get nothen accomplished today.
I had an order for some 2x8x18
And some 1x10x10
The 18 foot log went crazy on me and I had to dig another out.
And 2 of the 10 foot logs were full of shake.
But hay....just another day in Paradise :)
It hasn't rained here for 3 days 8)
WM bms250 sharpener
WM bmt250 setter
Offline Southside logger
« Reply #36 on: October 01, 2018, 09:37:34 PM »
Magicman - would that be a Pineapple cookie?  :D
    • A&P Saw mill LLC
« Reply #37 on: October 02, 2018, 06:29:49 AM »
If you have lumber going sideways, You are cutting down on the wrong face .
Offline PAmizerman
« Reply #38 on: October 02, 2018, 09:08:18 AM »
Thanks Peter. I'm aware. There was a big ugly knot that I didn't want in the face of every board. I knew it was going to go sideways on me but I didn't think it would go that much. I left the can't an inch wide to edge out the crook. But that wasn't enough.
He is going to use them as runners on a hay wagon so a little crook wouldn't be an issue. But 4" :o I don't think he would be happy with that. I know I wouldn't.
WM bms250 sharpener
WM bmt250 setter
Offline Quebecnewf
« Reply #39 on: October 04, 2018, 07:10:58 AM »
Getting the last of our logs ready to tow. As you can this is our bit of paradise
Quebecnewf
Offline tule peak timber
  • roborob
    • tule peak timber
« Reply #40 on: October 04, 2018, 08:04:18 AM »
Beautiful pic,,,,I want clams for dinner !
Offline PAmizerman
« Reply #41 on: October 04, 2018, 11:18:34 PM »
Very nice Quebec!! Sure looks like paradise to me.
WM bms250 sharpener
WM bmt250 setter
Offline PAmizerman
« Reply #42 on: November 02, 2018, 09:41:31 PM »
I've been swamped with orders. Things looked like they might slow down a little and I could finally get started on my sharpening shed!
Nope. had a guy roll in with a couple loads of nice ash he wants sawn. He says he has about 5000 feet down and ready to bring over. It's been a good year for me
I guess I'll just keep buying blades if I don't get my equipment up and running ;D
WM bms250 sharpener
WM bmt250 setter
Offline PAmizerman
« Reply #43 on: November 09, 2018, 06:35:14 PM »
Got a hole chiseled out for my sharpening shed. Looks like I might get to it here shortly.
WM bms250 sharpener
WM bmt250 setter
Offline samandothers
« Reply #44 on: November 09, 2018, 06:57:32 PM »
A bit moist!  Tis the season.
Offline Busysawyer
« Reply #45 on: November 09, 2018, 07:45:41 PM »
Your land looks similar to mine as far as having to carve space out if the hills. Thankfully my ground is mostly sand so not much mud. I do get some areas of liquified sand though. It looks solid but when you step in it ya sink up to your calf. It's what we call mud season in Michigan right now it goes from October until June most years. There is generally a few ice seasons mixed in between as well. The key here is to flatten out the ruts right before the ground freezes or else your stuck dealing with lumpy frozen ground for a couple months.
Offline PAmizerman
« Reply #46 on: November 09, 2018, 08:09:25 PM »
Just a little soggy! :D
The ytd precipitation for here is just over 57 inches so far. It has been non stop rain here.
I've had mud since last November. Usally I'll smooth things up before it freezes. Last winter it never really froze here.
It's just been mud mud mud.
I only got my hole dug because it didn't rain for 36 hours prior.  8) it was nice not having a day and a half of rain!
The sun even came out the one day  :)
WM bms250 sharpener
WM bmt250 setter
Offline PAmizerman
« Reply #47 on: November 12, 2018, 05:55:59 PM »
I got started on the sharpening shed today. Not too bad for one guy working alone all day.
I did have my dad come out for 10 minutes to set the wall.
WM bms250 sharpener
WM bmt250 setter
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #48 on: November 12, 2018, 06:21:22 PM »
you cheat :)
I would love to have me a telehandler.
Offline PAmizerman
« Reply #49 on: November 13, 2018, 07:26:31 PM »
It's not cheating it's time management :D
Telehandlers are easy to get I see them advertised all the time :D
WM bms250 sharpener
WM bmt250 setter
« Reply #50 on: November 13, 2018, 07:31:53 PM »
But they go for a pretty penny usually.  I actually scooped one up yesterday at a decent price.  1991 Lull 644.  She needs a little TLC but overall a decent machine and it will serve me well.
Offline PAmizerman
« Reply #51 on: November 13, 2018, 07:51:39 PM »
Congrats Southside!!
Got any pics?
WM bms250 sharpener
WM bmt250 setter
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #52 on: November 13, 2018, 07:55:07 PM »
yea. the ones I keep seeing start about 23k. I can't justify that. I think I will get a 3.5 ton mini excavator. it will be more versatile for me. I already have 28 hp Kubota with loader so that works ok. just need to build a grapple for it.
Offline PAmizerman
« Reply #53 on: November 13, 2018, 07:59:48 PM »
All the walls aren't even up and there's already stuff hanging on the walls :D
It was kinda slow going today. I left all my wood piles uncovered last night and then got snow/rain/ice last night. Then it warmed up a little and made a really muddy mess. Sorry no progress pics today. it was snowing pretty good when I quit for the day.
WM bms250 sharpener
WM bmt250 setter
« Reply #54 on: November 13, 2018, 08:09:07 PM »
Got any pics?
Here is one from where she was sitting.  Same style as yours with the main carriage that slides as the first stage of the boom.  It does have the tilt head so I am going to make or find a grapple for it and use that hydraulic feature to keep from chasing logs around.  Needs a tire, foam filled of course, but other than that it's just some small stuff here and there to deal with.  5,xxx hours so for the age not bad at all.
« Reply #55 on: November 13, 2018, 08:19:08 PM »
Well that did't work!!  >:( I will get some when she shows up in a day or so.
Offline PAmizerman
« Reply #56 on: November 13, 2018, 08:21:20 PM »
That sliding carriage is handy.
Telehandlers can be tricky to scoop logs off the ground with. I want to get a farma grapple to use on mine eventually.
WM bms250 sharpener
WM bmt250 setter
Offline PAmizerman
« Reply #57 on: November 25, 2018, 08:32:29 PM »
Progress :)
WM bms250 sharpener
WM bmt250 setter
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #58 on: November 25, 2018, 08:59:21 PM »
Dat's gonna be a sharp looking sharpening shed.  8)
« Reply #59 on: November 25, 2018, 09:45:31 PM »
Looks good for sure.  PA here is my new lift. Changed the filters today - boy that woke her up for sure!!
I think I am going to re-plumb the joysticks so the boom up down and fork tilt are on the same stick, and cariage out / squirt boom are on the other stick. Not sure why they were not set that way to begin with.
Offline sumday
« Reply #60 on: November 25, 2018, 10:15:15 PM »
Southside, in my experience with them you want to be able to raise/lower and boom in/out at the same time in many situations. Hence them being on the same stick. Allows smoother operation.
But if some other configuration works better for you, give it a try.
Offline thecfarm
« Reply #61 on: November 26, 2018, 07:23:02 AM »
Looks like that will be a handy machine to have around.
Offline PAmizerman
« Reply #62 on: November 26, 2018, 08:40:29 PM »
Thanks MM. I'm actually using up a bunch of lumber that I've had laying around that was not that great of quality that I wouldn't sell to customers but hated to just pitch it.
Southside
You will love the new machine.
Thats how my machine is plumbed. I have found it handy to be able to boom in and down or vise a versa at the same time.
What is the lift capacity on that one?
WM bms250 sharpener
WM bmt250 setter
« Reply #63 on: November 26, 2018, 08:55:38 PM »
6,000 lbs when pulled in, 1,500 when fully extended with the carriage all the way forward.  She actually paid for herself today.
This morning I could not find a first calf heifer that never ventures far so I went looking for her, we have had so much rain this year and even more lately.  Well that gal found a new spring hole that I have walked over many times in wet conditions and never had a problem, she was sunk to her neck.  I went to check on her and on her left side I could stand on the surface while sinking in maybe a few inches, walked to the other side and WHAM, I went down to my waist with one leg, complete liquification of the ground.  My excavator might have been able to reach in that far, but getting it down there would have been an issue and I don't think she would have made it between some trees so I would have had to deal with that and I didn't have time to waste.  So I went and grabbed the Lull, drove it right between the trees and up to what I knew was solid ground, extended the carriage and boom most of the way out there, grabbed a couple 4" straps and made a sling around the poor girl, had to get into the mud up to my chest to make it happen but she was very cooperative.  Took a couple of lift and withdraw the boom moves along with re-adjusting the sling but I got her up onto solid ground.  I do have an "Upsy Daisy" but there was no way to get that on her as deep as she was.  After a minute of letting her stand there I un did the harness and she slowly walked out of there and went right to grazing, been walking and eating all day ever since so I think she is fine.  I did throw a horse blanket on her to help keep her warm, the mud is not our normal red clay, more of a blue marine type clay and it forms like concrete on you, had to pressure wash my clothes after to get it off enough to throw in the washer.  Of course with all the jigging and moving back and forth to get the machine into place in the beginning I had broken the ground surface so now the Lull was stuck.  Called a buddy who came over and we brought my Franklin skidder down there, 40,000 lb winch made short work of that problem.  I guess that's one way to find out the real world capabilities of a machine, not that I want to do that again mind you, but yes worth every penny already.
Offline PAmizerman
« Reply #64 on: November 26, 2018, 09:02:19 PM »
Very handy in deed. Mine has the same lift capacity listed but I have a feeling it will lift more.
We had a calf born last week as well. No Lull needed yet though :D. It has been exceptionally wet here this year too.
WM bms250 sharpener
WM bmt250 setter
« Reply #65 on: November 26, 2018, 09:06:29 PM »
I have another one in the calving shed at the moment, need to go and check on her again shortly, I kept looking over at her during the ordeal thinking she was going to calf right then and there on me in the middle of it.  At least she is not a heifer, this will be her 4th calf and she milks heavy for a Jersey on just grass, her bag is way out there right now.
Offline PAmizerman
« Reply #66 on: December 02, 2018, 07:10:17 PM »
More progress on the shed.
The outside is done. I started on the inside and got started on setting up the equipment.
WM bms250 sharpener
WM bmt250 setter
Offline sumday
« Reply #67 on: December 02, 2018, 07:19:06 PM »
Looking good.
Offline PAmizerman
« Reply #68 on: January 06, 2019, 07:58:06 PM »
The shed is done and I got some blades sharpened. I  still need to tweak a few things but all in all I'm impressed. I was kinda expecting to have some trouble right off the bat but the blades cut very well. I am happy 8)
Here's a video of my finished shed.
WM bms250 sharpener
WM bmt250 setter
Offline PAmizerman
« Reply #69 on: January 06, 2019, 08:12:18 PM »
Playing catch up now. I took off between Christmas and New year's. I've got over 7000 feet of orders to fill. I got a good jump on it this week.
Here's part of it.
 it's been unseasonably warm here. Lots of mud and rain. It seems it will never quit ::). I sure hope it freezes soon. I need mo logs.
WM bms250 sharpener
WM bmt250 setter
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #70 on: January 07, 2019, 07:31:29 AM »
times like this a mini excavator with long reach would be great. Park it in one spot and stretch to reach everything. or enjoy the flotation of the tracks.
Either way I am sick of this mud. I really wish it would either dry up or freeze.
Only think that kept me from completely burying the tractor was the belly pan.
btw, shed looks great. I really need something like that. even if its just a place to park stuff to open up the rest of the shop.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #71 on: January 07, 2019, 07:52:46 AM »
Nice little blade shop.  Looks like you got the blade on the outside of the 3rd guide, it will keep going forever like that, no doubt you found out, if not better go check it :D :D :D
DJ Hoover, Terrific Timbers LLC,  Mystic CT  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
« Reply #72 on: January 07, 2019, 08:52:36 AM »
Great lookin sharpening setup.
I have retired my old drag sharpener and now use resharp but if were 20 yrs younger I would do something similar to your operation.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline PAmizerman
« Reply #73 on: January 08, 2019, 08:54:04 PM »
Not sure what you are referring to?
I had the magnet on and it stopped when it was supposed to.
I like having all that extra space now.
WM bms250 sharpener
WM bmt250 setter
« Reply #74 on: January 09, 2019, 06:14:29 AM »
I thought  it looked like the blade was outside the vertical pin on the third guide, the guide on the right, rather than between the pin and the roller. Many times Ive done this, the magnet catches on the pin. and the blade  keeps going round and round. 😹
Offline Don P
    • Calculator Index
« Reply #75 on: January 09, 2019, 07:35:05 AM »
My partner's new '81 644 Lull has been fun to use as well. I found some service info on the web here;
https://drive.google.com/drive/folders/0B9-7bn5CX9NDUUt3YkJtQ1U0LWs
I've got steering cylinder parts coming from Tiffin, we blew out the rear steering seals which made it fun to get into the shop and over the pit, the steering pressure drops to both cylinders. Next up is fixing the frame tilt. Once we can run the pumps I'll remove the rod end hose and see if the packing is blown and if not I suspect trash or a failure in the counterbalance valve, never been inside one of those.
Offline PAmizerman
« Reply #76 on: January 09, 2019, 08:43:18 PM »
Don
Good luck on the Lull.
WM bms250 sharpener
WM bmt250 setter
Trouble in paradise
Started by Texas Ranger on General Board
Last post June 29, 2006, 06:03:01 PM
by Max sawdust
cowcumber, paradise, and shoemake?
Started by hackberry jake on Sawmills and Milling
Last post October 31, 2015, 08:14:07 PM
by WDH
Ahhh Paradise at Eden Lake fishin,forestry,flyin
Started by SwampDonkey on Forestry and Logging
Last post February 01, 2004, 03:28:28 PM
by SwampDonkey
