Author Topic: Just another day in Paradise  (Read 7173 times)
Offline sumday
Re: Just another day in Paradise
« Reply #60 on: November 25, 2018, 10:15:15 PM »
Southside, in my experience with them you want to be able to raise/lower and boom in/out at the same time in many situations. Hence them being on the same stick. Allows smoother operation.
But if some other configuration works better for you, give it a try.
Offline thecfarm
« Reply #61 on: November 26, 2018, 07:23:02 AM »
Looks like that will be a handy machine to have around.
Offline PAmizerman
  • Just Another Day In Paradise!!
« Reply #62 on: November 26, 2018, 08:40:29 PM »
Thanks MM. I'm actually using up a bunch of lumber that I've had laying around that was not that great of quality that I wouldn't sell to customers but hated to just pitch it.
Southside
You will love the new machine.
Thats how my machine is plumbed. I have found it handy to be able to boom in and down or vise a versa at the same time.
What is the lift capacity on that one?
Hydraulics everywhere
Traverse 6035 telehandler
WM bms250 sharpener
WM bmt250 setter
Offline Southside logger
« Reply #63 on: November 26, 2018, 08:55:38 PM »
6,000 lbs when pulled in, 1,500 when fully extended with the carriage all the way forward.  She actually paid for herself today.
This morning I could not find a first calf heifer that never ventures far so I went looking for her, we have had so much rain this year and even more lately.  Well that gal found a new spring hole that I have walked over many times in wet conditions and never had a problem, she was sunk to her neck.  I went to check on her and on her left side I could stand on the surface while sinking in maybe a few inches, walked to the other side and WHAM, I went down to my waist with one leg, complete liquification of the ground.  My excavator might have been able to reach in that far, but getting it down there would have been an issue and I don't think she would have made it between some trees so I would have had to deal with that and I didn't have time to waste.  So I went and grabbed the Lull, drove it right between the trees and up to what I knew was solid ground, extended the carriage and boom most of the way out there, grabbed a couple 4" straps and made a sling around the poor girl, had to get into the mud up to my chest to make it happen but she was very cooperative.  Took a couple of lift and withdraw the boom moves along with re-adjusting the sling but I got her up onto solid ground.  I do have an "Upsy Daisy" but there was no way to get that on her as deep as she was.  After a minute of letting her stand there I un did the harness and she slowly walked out of there and went right to grazing, been walking and eating all day ever since so I think she is fine.  I did throw a horse blanket on her to help keep her warm, the mud is not our normal red clay, more of a blue marine type clay and it forms like concrete on you, had to pressure wash my clothes after to get it off enough to throw in the washer.  Of course with all the jigging and moving back and forth to get the machine into place in the beginning I had broken the ground surface so now the Lull was stuck.  Called a buddy who came over and we brought my Franklin skidder down there, 40,000 lb winch made short work of that problem.  I guess that's one way to find out the real world capabilities of a machine, not that I want to do that again mind you, but yes worth every penny already.
Offline PAmizerman
« Reply #64 on: November 26, 2018, 09:02:19 PM »
Very handy in deed. Mine has the same lift capacity listed but I have a feeling it will lift more.
We had a calf born last week as well. No Lull needed yet though :D. It has been exceptionally wet here this year too.
WM bms250 sharpener
WM bmt250 setter
« Reply #65 on: November 26, 2018, 09:06:29 PM »
I have another one in the calving shed at the moment, need to go and check on her again shortly, I kept looking over at her during the ordeal thinking she was going to calf right then and there on me in the middle of it.  At least she is not a heifer, this will be her 4th calf and she milks heavy for a Jersey on just grass, her bag is way out there right now.
Offline PAmizerman
« Reply #66 on: December 02, 2018, 07:10:17 PM »
More progress on the shed.
The outside is done. I started on the inside and got started on setting up the equipment.
WM bms250 sharpener
WM bmt250 setter
Offline sumday
« Reply #67 on: December 02, 2018, 07:19:06 PM »
Looking good.
Offline PAmizerman
« Reply #68 on: January 06, 2019, 07:58:06 PM »
The shed is done and I got some blades sharpened. I  still need to tweak a few things but all in all I'm impressed. I was kinda expecting to have some trouble right off the bat but the blades cut very well. I am happy 8)
Here's a video of my finished shed.
WM bms250 sharpener
WM bmt250 setter
Offline PAmizerman
« Reply #69 on: January 06, 2019, 08:12:18 PM »
Playing catch up now. I took off between Christmas and New year's. I've got over 7000 feet of orders to fill. I got a good jump on it this week.
Here's part of it.
 it's been unseasonably warm here. Lots of mud and rain. It seems it will never quit ::). I sure hope it freezes soon. I need mo logs.
WM bms250 sharpener
WM bmt250 setter
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #70 on: January 07, 2019, 07:31:29 AM »
times like this a mini excavator with long reach would be great. Park it in one spot and stretch to reach everything. or enjoy the flotation of the tracks.
Either way I am sick of this mud. I really wish it would either dry up or freeze.
Only think that kept me from completely burying the tractor was the belly pan.
btw, shed looks great. I really need something like that. even if its just a place to park stuff to open up the rest of the shop.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #71 on: January 07, 2019, 07:52:46 AM »
Nice little blade shop.  Looks like you got the blade on the outside of the 3rd guide, it will keep going forever like that, no doubt you found out, if not better go check it :D :D :D
DJ Hoover, Terrific Timbers LLC,  Mystic CT  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
« Reply #72 on: January 07, 2019, 08:52:36 AM »
Great lookin sharpening setup.
I have retired my old drag sharpener and now use resharp but if were 20 yrs younger I would do something similar to your operation.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline PAmizerman
« Reply #73 on: January 08, 2019, 08:54:04 PM »
Not sure what you are referring to?
I had the magnet on and it stopped when it was supposed to.
I like having all that extra space now.
WM bms250 sharpener
WM bmt250 setter
« Reply #74 on: January 09, 2019, 06:14:29 AM »
I thought  it looked like the blade was outside the vertical pin on the third guide, the guide on the right, rather than between the pin and the roller. Many times Iíve done this, the magnet catches on the pin. and the blade  keeps going round and round. 😹
Offline Don P
    • Calculator Index
« Reply #75 on: January 09, 2019, 07:35:05 AM »
My partner's new '81 644 Lull has been fun to use as well. I found some service info on the web here;
https://drive.google.com/drive/folders/0B9-7bn5CX9NDUUt3YkJtQ1U0LWs
I've got steering cylinder parts coming from Tiffin, we blew out the rear steering seals which made it fun to get into the shop and over the pit, the steering pressure drops to both cylinders. Next up is fixing the frame tilt. Once we can run the pumps I'll remove the rod end hose and see if the packing is blown and if not I suspect trash or a failure in the counterbalance valve, never been inside one of those.
Offline PAmizerman
« Reply #76 on: January 09, 2019, 08:43:18 PM »
Don
Good luck on the Lull.
WM bms250 sharpener
WM bmt250 setter
Trouble in paradise
Started by Texas Ranger on General Board
Last post June 29, 2006, 06:03:01 PM
by Max sawdust
cowcumber, paradise, and shoemake?
Started by hackberry jake on Sawmills and Milling
Last post October 31, 2015, 08:14:07 PM
by WDH
Ahhh Paradise at Eden Lake fishin,forestry,flyin
Started by SwampDonkey on Forestry and Logging
Last post February 01, 2004, 03:28:28 PM
by SwampDonkey
