Author Topic: 1998 Timberjack 460 transmission problem  (Read 1233 times)
Offline tomthumb
« on: July 22, 2018, 09:29:39 AM »
Hi! 1998 Timberjack with Cummings and 6 speed Clark transmission. While in first gear, transmission will shift into third gear on its own. Digital display still shows 1 and yellow T light blinks. If i turn engine off and start over will operate in first gear for a few minutes before going to a higher gear again. Used this procedure to get it out of woods. Not sure where to start trouble shooting and any help would be appreciated. This is a cable skidder and has the joystick shifter. Thank You
Offline Southside logger
Re: 1998 Timberjack 460 transmission problem
« Reply #1 on: July 22, 2018, 10:32:15 AM »
I am not familiar with the TJ set up but I think my Franklin has a Clark transmission and the shifting is controlled by a series of neutral safety backup switches which activate based on a plate that rotates by their position creating a series of on and off switches to open the right valves via electro magnetic coils.
If you have a series of coils I would check for a chafing or damaged wire, then look under the joystick for a cross contact problem.
When I had a NSBU go bad on me I only had certian gears sometimes and all gears other times, $30 bucks later and a couple hours with a multi meter and she was all fixed.
Offline kiko
« Reply #2 on: July 22, 2018, 11:20:12 AM »
With the key off, move the shifter into reverse then to the left, while holding it there turn the key to the on position. It will then run a diagnostic test.  G for good circuit, O for open , and S for short.
Offline tomthumb
« Reply #3 on: July 22, 2018, 05:20:37 PM »
Thank You kiko and Southside logger for your reply's. Will do the diagnostic test tomorrow and if the weather allows jack the cab and start trouble shooting.
Offline kiko
« Reply #4 on: July 22, 2018, 08:46:56 PM »
Sitting in the seat, the transmission wiring harness goes down the right side of the transmission the comes up and over transmission under the transmission pump to the control valve. Where it comes up and over is a common rub spot for the harness.
Offline tomthumb
« Reply #5 on: July 23, 2018, 05:46:14 AM »
I know the wires you are talking about and hope to troubleshoot today if weather permits. Thank You
Offline tomthumb
« Reply #6 on: July 23, 2018, 07:53:39 PM »
Well I didn't find a short but the first gear solenoid was bad. Got it ordered and hope to be back running Wednesday. Anybody know where to buy them cheaper than JD. Thanks again  kiko and Southside logger.
Offline tomthumb
« Reply #7 on: July 25, 2018, 10:46:47 PM »
Well put the new shift solenoid in and tested before putting covers on and letting cab down and everything was good. Got everything back together and no forward gears. In the process of putting cover on the solenoids i had pulled one of the wires out. Brought the solenoid home and have re soldered the wire back in and sealed it. Meter says everything is good to go so hope it works when i put it back on tomorrow.  Don't understand why these solenoids are so high. Does anybody know where the best place is to order them.
« Reply #8 on: July 25, 2018, 11:29:19 PM »
When you say selonoid is it the electromagnetic style that slides over the valve stem?
Offline kiko
« Reply #9 on: July 25, 2018, 11:34:03 PM »
Those coils should be available from a Clark transmission supplier. Like Bowers. There are no aftermarket supplier that I am aware of.  It is a 32000 model transmission.  Aftermarket Parts Inc would be a place to try.
Offline tomthumb
« Reply #10 on: July 28, 2018, 09:48:01 PM »
Sorry for the delay in replying. Internet has been on the blink. It is the electromagnetic style Southside logger. If i remember right they are made by Hydra.
Kiko when i get enough internet I will see what is available thru your suggestions. Not happening tonight.
Thank You both for your reply's.
1998 Timberjack 608B computer
Started by Mike_M on Forestry and Logging
Last post March 08, 2018, 09:45:57 PM
by Mike_M
404 timberjack transmission
Started by Adrian lucas on Forestry and Logging
Last post August 13, 2017, 09:28:59 PM
by Neilo
230 D Timberjack transmission
Started by Bolie on Forestry and Logging
Last post June 01, 2013, 09:49:00 AM
by redneck
Started by redneck on Forestry and Logging
Last post June 09, 2014, 05:14:35 AM
by redneck
