Author Topic: Daily carnage thread  (Read 14415 times)
Online mike_belben
  • Pulp Friction
Re: Daily carnage thread
« Reply #40 on: October 17, 2018, 12:02:59 AM »
I thought you were building some rod iron house plant arbor there for a minute.
Revelation 3:20
Online thecfarm
« Reply #41 on: October 17, 2018, 05:49:04 AM »
At a quick glace I thought it was a hyd hose.  :o
Offline Hilltop366
« Reply #42 on: October 17, 2018, 08:05:07 AM »
I believe I still have a matching drive shaft to that one in the junk pile somewhere if you need a pair.
Offline kiko
« Reply #43 on: October 29, 2018, 09:08:50 PM »
Overloaded ??
Online mike_belben
  • Pulp Friction
« Reply #44 on: October 29, 2018, 11:28:58 PM »
Nah just underweldered.   ;D
Revelation 3:20
Offline barbender
« Reply #45 on: October 30, 2018, 12:38:07 AM »
I can't believe the stuff people can break!
Offline Gary_C
  • Sunrise on the Prairie
« Reply #46 on: October 30, 2018, 03:39:36 AM »
He could have been trying to pull stumps. If you can't lift them out, try driving away. :)
Offline GRANITEstateMP
  • LIVE FREE OR DIE
« Reply #47 on: October 30, 2018, 09:48:59 AM »
If you stand farther away when you take the picture, it'll look better... Maybe not
Hakki Pilke 1x37
Kubota M6040
Load Trail 12ft Dump Trailer
2015 GMC 3500HD SRW
1999 New Holland TC29
Offline KWood255
« Reply #48 on: November 04, 2018, 07:01:00 AM »
Turns out that I didn't really need to turn up the hydraulic pressure on the tractor to split some huge pine logs....
Online mike_belben
  • Pulp Friction
« Reply #49 on: November 04, 2018, 12:04:05 PM »
Its split alright.  We will rebuild!
Revelation 3:20
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #50 on: November 04, 2018, 08:21:42 PM »
My splitter is feeling the effects of running off of my backhoe hydraulics. Break it, weld it better, try a bigger chunk of wood.  :D I don't know what the relief on the splitter is, but the Kubota is putting out 3100.
Offline JB Griffin
« Reply #51 on: November 04, 2018, 08:41:41 PM »
I think you have a low tire Dave. ;D
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2.5 million bdft sawn with a Baker Dominator and counting.
Online mike_belben
  • Pulp Friction
« Reply #52 on: November 04, 2018, 10:06:17 PM »
 Nah thats just a slow leak.
Revelation 3:20
    • My homepage
« Reply #53 on: November 04, 2018, 11:02:37 PM »
I'm going to take those off. Then I can get the beam right on the ground for the big chunks.
  • LIVE FREE OR DIE
« Reply #54 on: November 06, 2018, 04:50:00 PM »
Dave,
I think it's just flat on the bottom, you should be good!
Hakki Pilke 1x37
Kubota M6040
2015 GMC 3500HD SRW
Offline sawguy21
« Reply #55 on: November 06, 2018, 08:31:31 PM »
These pictures remind of my days on ground support for helilogging. Those guys could break a steel ball with a rubber hammer.
Offline moodnacreek
  • Sawin by the notches
« Reply #56 on: November 07, 2018, 07:33:42 AM »
Wait till it gets below zero.
Offline gaproperty
  • Location: Back and forth between Nova Scotia and NewBrunswick Canada
  • From Riches to Rags.
    • Riches to Rags
« Reply #57 on: November 23, 2018, 07:48:18 PM »
This promises to be a good thread😁 I usually don't tear too much stuff up, but when I screw up it's usually pretty bad. A few weeks back, I backed my loaded forwarder into the front of a truck that was loading on the landing (worst part was, he was parked exactly where I told him to load) I was just barely creeping when I hit him, in fact I never even felt it. Pushed him back about 3'. He had just started loading, if he would've had more wood on it probably would've totally wiped his truck out. As it was, it didn't look too bad, but it all adds up- Ali-arc bumper, A/C condenser, radiator, air to air cooler, grill and hood. $10K or so👎👎👎 I'll have my head hanging quite low for some time. No, I did not think taking pictures at the time would be appropriate 😑
The only people who don't make mistakes are the people who don't do anything.
Offline barbender
« Reply #58 on: November 23, 2018, 08:38:41 PM »
Thank you, gaproperty. As it turns out, insurance covered it so it least it didn't come straight out of the boss' pocket. I need to get a back up camera on my machine, not long after the incedent you just quoted, I had an elderly landowner (I later learned he has fused vertebrae in his neck, so he can't look up or to the sides) drive right up behind me when I was unloading on the landing. I started backing up to go to another pile, and I happened to remember the processor operator telling me that this landowner had a tendency to get in the way. So I decided to turn a bit to see behind myself, there was a Suburban about 5' behind me!! If I wouldn't have seen him, I would have drove right over the top of him before I felt it. It was a very bad move on his part to drive right into the blind spot of the machine, when I wasn't even aware he was out there, especially in light of the fact he could barely back up a vehicle because of his medical condition. I mustered my best stern tone (it's not really my way, especually with an elder that you are working for) and told him under no circumstances could he come that close to the machine. He was very sorry, and I felt bad for jumping his case but I'd rather do that than run him over!
Offline snowstorm
« Reply #59 on: November 24, 2018, 06:39:11 AM »
one of this weeks projects. rear springs 2564 ih truck. i did one side by myself. it can be done but it aint fun. the other side i had a little help. when you burn those 1" u bolts off its like a cannon going off..........bang
Daily Fabrication Thread
Started by mike_belben on Forestry and Logging
Last post Today at 01:36:18 PM
by mike_belben
Todays carnage
Started by Kevin on Forestry and Logging
Last post October 25, 2006, 04:25:10 PM
by rebocardo
Daily Maintenance for LT-40
Started by Jjoness4 on Sawmills and Milling
Last post March 04, 2017, 02:20:20 PM
by gww
Our Daily Wood
Started by Ken on General Board
Last post December 13, 2015, 09:37:09 PM
by sandsawmill14
