Author Topic: Soon to be new LT15 Wide owner  (Read 1797 times)
Offline Smithkp
Re: Soon to be new LT15 Wide owner
« Reply #20 on: August 06, 2018, 08:00:25 AM »
I noticed the saw was having a hard time pulling that turbo through the white oak I was sawing. The blade it came with was going through the log like butter until it dulled.
Anything worth doing is worth doing well.
Offline Smithkp
« Reply #21 on: August 06, 2018, 08:30:30 PM »
I went and put another turbo on at Joes request and tensioned the crap out of it and I still got the same crappy cut. Those are going back in the morning to get swapped out with double hards at 4 degree. I ordered a box today and hope Joe will get some more to me before Friday or I am out of luck.
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #22 on: August 07, 2018, 12:42:08 PM »
The blades will be there I'm sure.  I get next day deliveries usually.
I have a LT35 with the 25hp Kohler.  I've used 4 degree blades until this morning.  I ordered a box of 5 Turbo 7s and tried one for the first time this morning.  I will likely be switching to the T7s.  They cut all I put on the mill exceptionally well.  Faster cuts, smoother cuts and less sawdust on the boards.
If your 25 hp isn't pulling the Turbo 7s something else might be wrong.  Mine did fine.
Some of the more experienced sawyers here will say, "I told you so."  And they did!
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher
Offline Smithkp
« Reply #23 on: August 07, 2018, 12:54:41 PM »
Joe had some thoughts that the teeth might not have been set or maybe some teeth got bent. I just know they don't work with my set up.
 In the photos you can see what the turbo is doing to a white oak log. Bottom pic is the comparison between the dull blade that came with the mill versus the turbo.
Offline SawyerTed
« Reply #24 on: August 07, 2018, 06:16:28 PM »
Sorry you've had that problem.  Every mill is a little different and blades do vary in their performance.
I hope the 4s work!
LT15 Wide, LT70 Wide, where's the Wide Edger?
Started by Dave Shepard on Sawmills and Milling
Last post March 25, 2018, 11:53:41 PM
by Darrel
New LT 15 wide owner
Started by Damato333 on Sawmills and Milling
Last post December 12, 2017, 07:53:18 AM
by GDinMaine
New Member and new owner LT15
Started by Mentos on Sawmills and Milling
Last post June 06, 2017, 10:57:26 AM
by wng-2
LT15 vs LT15 wide?
Started by gump on Sawmills and Milling
Last post March 17, 2018, 11:18:05 AM
by gump
