Author Topic: Cat back hoe  (Read 1166 times)
Offline Peter Drouin
    • A&P Saw mill LLC
Cat back hoe
« on: July 25, 2018, 08:21:16 PM »
Looking for info on the pin that holds the boom to move left to right.
On the 416 / 420.
 Talking with guys about it wearing out in 4000 hrs.
Line boring is out because of the thing is cast iron.
 To me, that's a weak point.
Anyone know anything about it.
Offline kiko
Re: Cat back hoe
« Reply #1 on: July 25, 2018, 11:42:35 PM »
Line boring is not completely out. It can be bored and custom steel bushings installed.  Still expensive.
    • A&P Saw mill LLC
Re: Cat back hoe
« Reply #2 on: July 26, 2018, 06:02:16 AM »
Is this a trend for the cat hoe, Are the new weak there?
    • A&P Saw mill LLC
Re: Cat back hoe
« Reply #3 on: August 05, 2018, 06:47:51 AM »
Thanks, Kiko for your info. I was hoping some here knew something about backhoes, But I guess loggers don't use them.
Offline snowstorm
Re: Cat back hoe
« Reply #4 on: August 05, 2018, 07:16:13 AM »
you dont say what year it is. the first cat hoes. 80's. the hoe was a copy of a case. later cat had the curved boom. now almost everyone has it also. i would not expect the casting you refere to being cast iron. case always said theres is ductile iron. no matter what its made from its always moving and in the dirt.    i have spent a lot of time on case and jd hoes. and a few hrs on a 10 yr old cat. the cat was very nice
Offline Riwaka
Re: Cat back hoe
« Reply #5 on: August 05, 2018, 08:04:08 AM »
expander 'pins' are used in excavators if in a hurry to reduce pin slop for a while.
Expander portal global  (probably need to 3d metal print accurate inserts etc to take up slop)
    • A&P Saw mill LLC
Re: Cat back hoe
« Reply #6 on: August 05, 2018, 11:03:48 AM »
2005. My town has 2, 2006 and 7. The 2006 has 1200 hrs on it and is sloping around some already.
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
Re: Cat back hoe
« Reply #7 on: September 17, 2018, 10:31:26 PM »
I just had my pins replaced on my 2006 420E IT.  They got bad around 4,000 hrs.  I have 5200 hrs on it or so when we did it.  I had my mechanic chang top and bottom pins bushings and bearings.  About $600 in parts and $600 in labor and good to go another 5000hrs.  Didnt need any line boring as the pin wore before the bushing so it was fine.  I had heard cat designs the pins so that they wear out first and youre supposta change two pins for every 1 bushing.  But I dont screw around I screw straight so I had em replace everything all in one shot.
Boy, back in my day..
back in the woods and back in the game
Started by Quebecnewf on Forestry and Logging
Last post February 12, 2011, 09:13:50 PM
by Ed_K
He's Back!!! I figgered he would find his way back!!!
Started by ADAMINMO on General Board
Last post March 13, 2008, 10:42:54 PM
by Warbird
Back to the top
Started by woodman58 on Sawmills and Milling
Last post May 03, 2016, 07:34:05 PM
by woodman58
im back now
Started by efitzgerald on Sawmills and Milling
Last post February 27, 2005, 03:14:56 PM
by Fla._Deadheader
