Author Topic: Maximum angle for a cardan joint?  (Read 387 times)
Offline Satamax
« on: July 26, 2018, 04:48:42 AM »
Hi everybody.
If i were to link my winch and Pto with a cardan jointed shaft, what would ne the max angle from the axis of the Pto ? 30░ or more?
Thanks guys.
French CD4 sawmill. Latil TL 73. Self moving hydraulic crane. Iveco daily 4x4 lwb.
Offline mike_belben
  • Pulp Friction
Re: Maximum angle for a cardan joint?
« Reply #1 on: July 26, 2018, 11:20:51 AM »
You can prob get 30* but you must ensure that the other joint is exactly the same angle in negative plane.   Itll probably have a pretty short lifespan on joints since the needle bearings will be very active.
 Consider a double cardan off the PTO shaft and tilting the winch so that the single joint at the winch end is at zero angle, inline with the winch input.  Tilting down will reduce the overall angle required, say maybe to 20* or so.. And the double cardan will share it across two joints so only 10* each.  Toyota 4wd truck front driveshafts are a good source.  They can be modified to bend quite far.
Revelation 3:20
Offline thecfarm
« Reply #2 on: July 26, 2018, 08:32:35 PM »
Now I know what a carden joint is. :)
Offline Satamax
« Reply #3 on: July 27, 2018, 07:07:21 AM »
Thanks a lot guys.
Well, on wikipedia, they say 45 absolute maximum.
But i don't think i'll bother with cardan.
Maximum log length
Started by Birk-man on Sawmills and Milling
Last post August 05, 2010, 01:56:38 AM
by paul case
maximum removal
Started by woodmills1 on General Board
Last post March 22, 2007, 09:17:25 AM
by woodmills1
Maximum Open Span?
Started by Kirk_Allen on Timber Framing/Log construction
Last post October 04, 2005, 09:03:11 AM
by ronwood
Maximum Log for Loading onto LT40
Started by mhasel on Sawmills and Milling
Last post February 23, 2008, 07:59:49 AM
by Warren
