Author Topic: Sawing fabricated beams  (Read 867 times)
Offline Qweaver
  • The cabin is done and we love it
« on: July 27, 2018, 02:29:05 PM »
I need to saw 5"x11" fabed ply beams.  The customer says hes been told that these beams "can not " be sawed with a chain saw.  I know nothing about these glued beams.  Can I saw them on my band saw?
Quinton
Offline Qweaver
Re: Sawing fabricated beams
« Reply #1 on: July 27, 2018, 02:56:51 PM »
Hey WV Sawmiller.  Know anything about these beems
Offline Bruno of NH
« Reply #2 on: July 27, 2018, 03:21:20 PM »
I would think the bandsaw will cut them.
I would use a cobalt or better type band.
Because of the heat and all the glue.
The chainsaw rips them apart.
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline ljohnsaw
« Reply #3 on: July 27, 2018, 04:19:18 PM »
Quinton
Are you starting with something bigger (how big?) cutting down to the 5x11 or are  you starting with the 5x11 and cutting down to, what?  I'm assuming the customer is taking responsibility for the resulting beam's strength, or lack there of.  Glu-lams are engineered to their manufactured size.  Cut them down and all bets are off!
John Sawicky
Offline Qweaver
« Reply #4 on: July 27, 2018, 04:31:22 PM »
Yeah, my thoughts also on the cutting down.  He wants to cut the 5.5 x 11.5 to 5.5 x 5.75.  I don't trust the resulting strength.  But that is his call.  I will point it out.  They are 16' long
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #5 on: July 27, 2018, 04:43:14 PM »
Quinton,
   No, I have never sawed or even heard of them.
   I have long laminated beams in my log home. They are about 6" wide X 2' tall and 36' long. Looks like they took 2X6's and planed and glued them together.
    Cutting a 5" X 11" the length your mill will handle should be a piece of cake if your mill is properly alligned. The strength would depend on the type and grade wood used I would think. Good luck.
Offline ljohnsaw
« Reply #6 on: July 27, 2018, 05:28:22 PM »
Wow, about all that will be good for is door and window headers!
If you had a Makita beam saw, you could just rip it with a 1x4 nailed on the side as a guide.  Could even use a 10 skill saw if you cut from both sides.
John Sawicky
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
« Reply #7 on: July 28, 2018, 01:18:27 AM »
If these are glulam beams, there's a couple of issues.
First, a lot of them have hardened aluminum nails internally (to hold the laminations in alignment). This may or may not be a problem with your saw blades.
Second, the laminations on the top and bottom are usually clear lumber, because this is where the highest stresses are located. The internal laminations may be a lower grade (and strength) because they serve mainly as spacers. When you cut off the top/bottom layers the resulting beams are weaker then a beam that was designed to be the same depth.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Offline Qweaver
« Reply #8 on: August 01, 2018, 03:36:22 PM »
OK  We sawed a trailer load (about 30) to 5.5 x 8.  Used lots of water and cut slower than usual and the cut stayed straight.  Blade had already cut several logs and was starting to get dull at the end but still OK.  Easy job. These boards were "treated" whatever that means.
Quinton
fabricated a fork bracket for the tractor out of nothing but I-beams.
Started by hackberry jake on Sawmills and Milling
Last post February 21, 2012, 02:59:43 PM
by hackberry jake
Sawing 30' beams
Started by Gilman on Sawmills and Milling
Last post November 23, 2005, 03:02:54 PM
by Gilman
Sawing beams
Started by Jimbob on Sawmills and Milling
Last post January 22, 2006, 01:17:08 PM
by isassi
Sawing my first 21 foot beams.
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post August 12, 2018, 11:18:10 PM
by Andries
