Author Topic: Ford Dually Issue/Question  (Read 378 times)
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« on: July 30, 2018, 10:53:30 AM »
I have a 2014 Ford F450 dually that I have had issues with accessing the rear tire valve stems since I purchased it new.    The openings are pretty small and near impossible to reach the inside tire valve stem to remove and replace the cap when checking and adding air.   This photo is what I am talking about.
This is a real issue for me as I use a TPMS to monitor pressure and temperature while towing my 5th wheel toyhauler and the caps are larger and impossible to get on or off.    Even doing the inside tire first, reaching in over the outer tire valve stem usually ends up ripping skin off of my hands or leaves bruises.
Several times in the past when it's been in for service I have had the dealer rotate the outer tire so the valve stems are offset from each other.     This seems to work OK and I can access everything fine.    However, if I do not remember to specify this the dealer will rotate the tires and line up the valve stems.  :(
Anyone else have this issue and what have you tried to resolve it?
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40HDG38
Lucas Dedicated 60" Slabber
Offline mike_belben
  • Pulp Friction
Re: Ford Dually Issue/Question
« Reply #1 on: July 30, 2018, 11:31:43 AM »
Napa and any HD truck shop like fleetpride will sell thread on extender hoses.  Theyll screw onto your inners and clamp to the hole of your outers.  Im sure amazon etc also has them.
Northern stocks a Slime brand dually extender kit for $15.  Maybe tractor supply too.
Revelation 3:20
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #2 on: July 30, 2018, 07:22:54 PM »
D
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #3 on: July 30, 2018, 07:57:55 PM »
DOT legal?
Ford F 250 5.4 engine issue
Started by MartyParsons on General Board
Last post June 25, 2013, 08:51:50 AM
by Hilltop366
Starting Issue On A 300 Ford Six Cylinder
Started by Autocar on General Board
Last post February 23, 2017, 01:09:52 PM
by Ox
Yet another gx390 (clone) question/issue
Started by btulloh on General Board
Last post November 15, 2017, 01:27:50 AM
by starmac
Ford 8N question
Started by Raider Bill on General Board
Last post June 05, 2014, 04:54:02 AM
by 36 coupe
