Author Topic: Mystery Tree  (Read 723 times)
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Mystery Tree
« on: July 31, 2018, 03:56:13 PM »
OK this was sent to me by DelawhereJoe.  It's a tree with 7 different leaf patterns, some very distinctly different.
Top of the leaves.
The underside.
Branch tip.
Tree trunk.
Offline bluthum
  • Tick magnet.
Re: Mystery Tree
« Reply #1 on: July 31, 2018, 07:20:30 PM »
Just guessing as there are several red oaks with variable leaves and some like to hybridize. Might be Quercus marilandica  [blackjack] or Q. falcata, or.....
It's usually easy to separate those two from a distance by gross characters or even from their site, leaves maybe not so much.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Mystery Tree
« Reply #2 on: July 31, 2018, 07:38:19 PM »
I have seen the lower limbs produce much differently shaped and usually larger leaves than the top limbs.
Offline DelawhereJoe
  • Trapped in Delawhere
Re: Mystery Tree
« Reply #3 on: July 31, 2018, 08:12:57 PM »
The tree is growing at the edge of the woods about 30' - 35', there are no black jack oaks that I know of in the area. Its growing around northern red, southern red pin, willow and others that I have your to identify. Yes they all came from lower branches between 6-8'.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Mystery Tree
« Reply #4 on: July 31, 2018, 10:39:13 PM »
Quercus falcata.  Southern red oak.  100% sure.  Two clues.  The rounded base with the "bell and clapper" shape of the shade leaves.  The two toned color.  Top is bright green, bottom a tawny color.
Re: Mystery Tree
« Reply #5 on: August 01, 2018, 11:25:50 AM »
Thank you both MagicMan and WDH
Offline timberking
Re: Mystery Tree
« Reply #6 on: August 01, 2018, 03:10:12 PM »
Looks like SRO to me.  Big difference what part of the tree the leave came from.  Our dendro instructor was the master of deception.
Mystery Tree
Started by johnjbc on Tree, Plant and Wood I.D.
Last post July 06, 2006, 03:16:44 PM
by Phorester
Mystery tree.
Started by Ianab on Tree, Plant and Wood I.D.
Last post November 20, 2018, 09:59:11 PM
by DelawhereJoe
Mystery tree from Florida
Started by leyvajd on Tree, Plant and Wood I.D.
Last post September 18, 2015, 10:01:33 PM
by Ianab
Spiky mystery tree
Started by Southside on Tree, Plant and Wood I.D.
Last post June 04, 2018, 10:34:49 PM
by ESFted
