Author Topic: Grapple skidder theory?  (Read 2660 times)
Offline Satamax
« on: July 31, 2018, 04:33:04 PM »
In this video, you Can well see the advantage of the rotator on the grapple, around thé 3.20 minute mark.
But, when turning left and right, with trees behind,  you need the rotator to freespool i would think.
How is this done?
French CD4 sawmill. Latil TL 73. Self moving hydraulic crane. Iveco daily 4x4 lwb.
Offline DDW_OR
Re: Grapple skidder theory?
« Reply #1 on: July 31, 2018, 05:09:04 PM »
i am very GREEN about Hydraulic parts.
but would a Relief or Cushion Valve work?
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener,
Offline Skeans1
« Reply #2 on: July 31, 2018, 06:48:58 PM »
Pressure is only applied when the valve handle or joystick is pushed in the desired direction otherwise they’re free moving, on our tsk D4H the grapple can be rotated by hand as long as the valve is in neutral.
Offline kiko
« Reply #3 on: July 31, 2018, 07:51:50 PM »
This is where the rotate action goes down, notice how the open close passages are cast into the spindle .
This is the rotate motor itself. It is a radial hydraulic motor.
The 525C is my favorite with out a doubt.  Major draw backs to them is no declutch and having to twist in the seat to see out the back.  In the video you can see him all twisted backing out. Fine machine though.  Here is a single arch C.
Offline quilbilly
« Reply #4 on: July 31, 2018, 07:53:32 PM »
What's the advantage to declutch?
a man is strongest on his knees
Offline kiko
« Reply #5 on: July 31, 2018, 08:20:31 PM »
It is not good to be stalling over the converter while holding the service brake and throttling to speed hydraulic function.  Constantly doing that will cause premature transmission failure. So the transmission need be in nuetral when stopped, working grapple function.
Offline Maine logger88
  • Don't force it get a bigger hammer
« Reply #6 on: July 31, 2018, 08:20:59 PM »
He’s not going to be happy when the grapple gets caught up in a chain leaving it open and driving around. I guess having a good snubber helps but it still will happen eventually. My old 240 the snubber is completely worn out so you have to grab the arch or it will get tangled up pretty quick
Offline Satamax
« Reply #7 on: August 01, 2018, 01:42:47 AM »
Thanks a lot guys.
Offline mike_belben
  • Pulp Friction
« Reply #8 on: August 01, 2018, 07:47:53 AM »
Max, you will be using a motor spool to control the rotator.  The A and B ports connect to each other in the neutral position allowing the motor to have a metered float.
Revelation 3:20
Offline Satamax
« Reply #9 on: August 01, 2018, 08:51:13 AM »
Duh? :D  ;D
Offline DDW_OR
« Reply #10 on: August 01, 2018, 11:46:46 AM »
please explain?
I am adding a grapple and rotator to my bobcat 331 excavator
the thumb will work the grapple and i will put a manual 3-way valve on the bucket cylinder to operate the rotator
3/8" NPT Carbon Steel 5880 PSI 3-Way Ball Valve | Ball Valves | Hydraulic Valves | Hydraulics | www.surpluscenter.com
will remove the handle during use. and weld a protective bracket
Offline mike_belben
  • Pulp Friction
« Reply #11 on: August 01, 2018, 03:49:45 PM »
Well, in the case of a grapple skidder you want to be able to power rotate to orient your jaws on the log, but when hauling want a free float like a trailer hitch.  A cylinder spool valve would lock the rotator when not being used and create resistance in turns.  It'd chew up logs and maybe break stuff as well as make turns harder.  This is what max needs, a motor spool.
 It just allows the fluid in the motor circuit to circulate within the motor so that rotation is allowed, like a loader float.  On cylinder spools A and B are isolated from each other to prevent drift.
Revelation 3:20
Offline mike_belben
  • Pulp Friction
« Reply #12 on: August 01, 2018, 03:57:10 PM »
For your excavator grapple i think youd be happier with double selector valves on the stick, whether manual or DC.  Manual is obviously more dependable and no wire to plumb or tear.   Surplus center has quite a few and they have PDF tabs on how to set them up.
If youre gonna go with 3 way ball valves, youll need 4, one for each line.  I dont know what type of spool knuckle booms use, i'd imagine a cylinder spool and relief cartridge so nothing gets busted if a log decides it must spin the rotator.  Your conversion will work fine for part time log loader needs im sure.
Just remember its a pain to bleed air out of cylinders so use quick couplers instead of swivels.. That way you dont take on air with every switch.
Revelation 3:20
Offline Satamax
« Reply #13 on: August 01, 2018, 04:08:27 PM »
Got it!
It's not the explanation, but the drawing A cross, a link, and a straight, i understand that!  ;D
Thanks a lot Mike.
And i'm still making no progress, due to the fact that i can't buy parts! Dang France, with it's taxes!
Offline mike_belben
  • Pulp Friction
« Reply #14 on: August 01, 2018, 04:42:35 PM »
Btw they do make add on float spools too, incase you have a need for lock and float.
Revelation 3:20
Offline Skeans1
« Reply #15 on: August 01, 2018, 06:19:03 PM »
please explain?
3/8" NPT Carbon Steel 5880 PSI 3-Way Ball Valve | Ball Valves | Hydraulic Valves | Hydraulics | [url=http://www.surpluscenter.com]Surplus Center[/url]
Same machine that you’re adding a dangle head to correct? If so you’ll normally use the link cylinder plumbing for rotate, then you could use the thumb for open and close.
Offline DDW_OR
« Reply #16 on: August 01, 2018, 07:07:47 PM »
yes, but i was going to put the 3-way on the bucket cylinder lines. that way the joystick movement does the rotation. the auxiliary line that would normally operate the thumb will do the grapple open/close.
Parts list
qty 2, 3-way valves
qty 4, hydraulic lines
qty 4, quick connects
plus adapters and protective frames
Offline mike_belben
  • Pulp Friction
« Reply #17 on: August 01, 2018, 09:18:10 PM »
It would take 4 three way valves.  Two cylinders each with an A and B port.  Thats why i was suggesting the double selectors, itd be a bit cleaner packaging.
Revelation 3:20
Offline DDW_OR
Offline setnctl
  • the main thing is dont get excited
« Reply #19 on: August 25, 2018, 11:36:38 PM »
the way the grapple rotate "floats" so to speak is with a crosser relief valve
grapple skidder
Started by Maineloggerkid on Forestry and Logging
Last post March 02, 2009, 09:18:39 AM
by spencerhenry
JD 640 Grapple Skidder
Started by Kemper on Forestry and Logging
Last post June 15, 2012, 11:35:46 PM
by lonewolf
cat 515 and 525 grapple skidder
Started by logger444 on Forestry and Logging
Last post September 01, 2009, 11:03:45 PM
by logger444
Thinking about a grapple skidder...
Started by danbuendgen on Forestry and Logging
Last post June 12, 2016, 05:30:22 PM
by danbuendgen
