TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: anyone ever built any outbuildings or anything with untreated posts?  (Read 708 times)
Offline hazazil
Just curious..........
So I purchased 6 roofing panels from someone who was moving. I had to use a crane truck to load/unload them on a car hauler trailer. Each panel I was told weighs 500 pounds or so. They are approximately 8 feet by 11 feet.
I was hoping to place them 3 long and butt 3 of them together so the total dimensions would be 24 feet x 22 feet.
Obviously that's alot of weight to hold up. I have some dead standing ash trees that I could take down and make some big posts. I figured I could even make some huge posts up to 24 inches for where the 2 panels but up together if needed.  I've been reading online about using untreated posts for post frame buildings.
Some say treat the part that will in in the ground with tar or tar/kerosene. Others say put in a concrete pier/pillar and attach post to top of concrete pier(which defeats the purpose of pole building and jeopardizes lateral support)
Was just wondering what your thoughts are and if anyone has done anything like I'm wanting to do. Obviously I do not want to go to the store and buy any lumber. I do have some cedar trees on the property but don't want to cut them down just to use them as posts.
Thanks for the advice.
Offline Don P
    • Calculator Index
Re: anyone ever built any outbuildings or anything with untreated posts?
« Reply #1 on: July 31, 2018, 08:27:10 PM »
I don't know that it defeats the purpose of a post frame building, the posts simply need to be braced by another method. A braced wall can be one solution.
We used site gathered rocks, concrete and mortar to make piers under these posts. There is steel in the pier as well as the post base bolted to the bottom of the post. When the post plate was in place on the pier plate, the steel was welded together tying the post to the pier.
Offline DPatton
« Reply #2 on: July 31, 2018, 10:09:16 PM »
I.m.o. I think Don P is spot on about the bracing. There are other ways to brace a post or pole framed shed. I build mine with all eastern red cedar posts set 4í + deep and filled with compacted rock for drainage. Personally I would suggest against burying untreated ash and would opt for the concrete pier method if thatís the species your going to work with.
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500, Echo Chainsaw, 60" Logrite.
Work isn't so bad when you enjoy what your doing.
Offline florida
« Reply #3 on: August 02, 2018, 08:13:58 AM »
hazazil
If I'm understanding you the total weight of the panels is 3,000 pounds. That's not much weight at all.  A single pine 6 X 6" post will hold 26,137 pounds and I'm guessing you'll have at least 4 posts sharing the load. 4 posts would give you 750 pounds per post which a  2 x 6 would hold if dead weight were the only factor. But, you also have to consider snow load and uplift so I'd use at least a 6 X 6 or for a little insurance cut some 8 X 8's to be sure.
Use this interactive form to calculate what you might need.
Capacity of wood column calculator
General contractor and carpenter for 50 years.
Offline Wudman
  • Eat, drink, and be merry before you go on quota!
« Reply #4 on: August 02, 2018, 03:18:16 PM »
l would not consider burying the ash.  I will rot in short order.  Saw and sell the ash.  Buy some pressure treated pine if you wish to go with a pole building or chase down some used power poles.  Piers under a post is fine too as long as you have bracing to prevent racking.  If it is subjected to water, I would still tend to shy away from the ash.  White oak, if available, would be a better choice in my opinion.
Wudman
Offline Autocar
« Reply #5 on: August 12, 2018, 03:47:11 PM »
I just got done in June to a adittion on my machine shed, I sawed white oak and socked them in motor oil then poured cement around them . I will try in september or later whaen ever the ground starts to dry I will spray the cement and post four inches off the cement with flex seal. Is that the answer  ;D at 70 years old I hope they last my life time than someone else can dig a footer and place them up on the foundation
Bill
Protecting untreated posts from rotting?
Started by mtcates on Timber Framing/Log construction
Last post August 27, 2010, 06:25:06 AM
by ljmathias
study relating to serviceable life spans of treated/untreated fence posts
Started by Modat22 on General Board
Last post June 01, 2007, 07:47:46 PM
by Tom
question
Locust for hewing outbuildings and maybe my home
Started by Dme1976 on Timber Framing/Log construction
Last post September 09, 2017, 01:05:52 PM
by Dme1976
Untreated pine logs
Started by tbeale on Timber Framing/Log construction
Last post December 04, 2012, 10:57:35 PM
by Mad Professor
