Author Topic: PTO Skidding Winches  (Read 552 times)
Offline kyjondeere
« on: August 01, 2018, 10:59:00 AM »
I have about an 80 acre woodlot with mostly white oak, red oak, tulip poplar, and hickory.  Along with severe damage in 2009 from an ice storm, and recent straight line wind storms, I have several either downed or dying trees (primarily white oak).  I plan to harvest these trees myself.  I've decided that there is enough work and future work to invest in a 3 point skidding winch.  My research points to 3 main brands for consideration (Farmi, Wallenstein, and Norse).  I am looking for some input on these from those who are familiar.
Cost is important, however, I don't want to buy poor quality just to save a few bucks.  My initial research indicates that the comparable Norse branded winch is substantially less expensive than the similarly specified Wallenstein and Farmi.  That said, I'm leaning toward the Norse 350.  I have a 80 HP (69 HP PTO) and a 32 HP PTO Kubota tractor that I will be using the winch on.
Any input on any of these winches is appreciated.
Norwood Lumbermate 2000, John Deere 5083e, Kubota L3240, Stihl MS 461, Stihl MS270, Stihl MS250, Load Trail 16' Dump Trailer
Offline thecfarm
Re: PTO Skidding Winches
« Reply #1 on: August 01, 2018, 01:47:09 PM »
I myself would move up to the Norse 450 and put it on that 80hp tractor. I have the 450 on a 40 hp. Those big ones,2 feet across,can only take a couple at a time. I like the butt plate that pivots and mine came with boxes on the side to hold the chains. I also like the higher pulley too. We looked at some of the other winches. That Norse had the highest pulley.We had some big pine, 3 feet was normal.  Even had some 4 foot ones.
But saying that any winch is a good one. Never had any trouble,needing parts,with the Norse. And that winch was worked hard. Now it lives a life of ease with firewood.
Make up some 4 foot chains for the small stuff. I use the 4 foot chains more than the 8 foot ones now.
I run 6 slides. Most times all six are used,sometimes only one. Much better to have  the slides and not use them,than to need the slides and not have them.
Never pull at a sharp angle, You can tip the tractor over. I put down the loader and set the brake each time. Lower the winch too,of course.
Watch the slash that will come towards you when winching in.
I've had that winch since '93 and really like it.
Offline thecfarm
« Reply #2 on: August 01, 2018, 01:51:31 PM »
Offline John Mc
« Reply #3 on: August 01, 2018, 06:06:27 PM »
I've never used a Norse or a Wallenstein myself, though I have seen them used.
I've seen a lot of Farmi winches in action, and spoken to a lot of Farmi owners over the years (they are probably the most popular brand in my area). I've never met a single owner who was unhappy with their purchase - which is probably one of the reasons why you never see a used one up for sale.
I own a Uniforest winch, and have been happy with it, but even so, if I were buyng new now, I would get a Farmi.
Offline g_man
« Reply #4 on: August 01, 2018, 07:15:49 PM »
I agree with Rays statement 100%. I used a 30 hp Kubota L3010 with a Farmi 290 winch for almost 20 years cutting fir and firewood. I wanted to cut some bigger wood and found a used 56 hp M5640 and put a Farmi 501 winch on it. You would not believe the huge benefit I got from the bigger tractor in the woods. Much much safer too. I am now a firm believer in bigger is better when working in the woods. Get a winch sized properly for the 80 hp tractor rather than one you can put on either. You will not be sorry. Any major brand that you mentioned will give you a good winch. When you consider that it will last you a lifetime the cost difference between brands becomes almost meaningless so just get the one you want. Just my opinion.
gg
Offline Jack Lilley
« Reply #5 on: August 01, 2018, 08:00:50 PM »
After doing allot of research I just purchased an Igland (same as a Norse) 350. Price was a factor and people that have them seem happy with them. I ordered it from a place in VT and it was drop shipped to me the next day in  northern Maine, great service. I have it on a New Holland TC30 and have only yarded  7 or 8 large, heavy, fir with but it worked well.
Offline John Mc
« Reply #6 on: August 01, 2018, 08:09:00 PM »
Gman & Thecfarm make some good points.
My set up is similar to Jack Lilley's: I have a Uniforest 35E (similar size to a Farmi 351) on a 33HP New Holland TC33D. It works well for what I need. It can be used safely as long as you are aware of the limits. I chose the winch size because it fit well with the tractor I owned. (I was having enough trouble justifying the purchase of the winch, let alone trying to explain to my wife that I "needed" a whole new tractor.)
If I had already owned a larger tractor, I would have sized the winch for the bigger one.
Other uses for skidding winches
Started by Ford_man on Forestry and Logging
Last post March 10, 2011, 07:18:52 AM
by logman81
Tractor Skidding Winches
Started by dirtmod454 on Forestry and Logging
Last post January 03, 2017, 06:43:00 PM
by thecfarm
Farmi vs. Uniforest 3pt Skidding Winches
Started by labradorguy on Forestry and Logging
Last post September 04, 2018, 05:30:24 PM
by 47sawdust
Sun Faded Uniforest Skidding Winches for Sale!!!
Started by Hud-Son Forest Equipment on For Sale
Last post June 28, 2013, 09:51:28 AM
