Author Topic: I have gotten myself a 450 timberjack. Love it! But she needs some TLC  (Read 540 times)
Offline 1st450Jack
Need some help understanding something's about timberjack. Clark Tran's 3 speed. Charge presser. Year model.ser # is 452788. Hydraulic filter was missing from the tank. Need a part #. were is the Tran's screen filter located. I think i know but can't get the nut loose. Break housing leeks. Every valve body leeks. She was really packed with dirt an gunk. Charge presser was 250 but now 100. But im on it. Need some info on parts an how to an were to an so on. Thanks. An she's sucking air.
Offline Firewoodjoe
  • Im getting old
Re: I have gotten myself a 450 timberjack. Love it! But she needs some TLC
« Reply #1 on: August 02, 2018, 08:15:58 PM »
Might want to move this to the logging and forestry section.
Offline 1st450Jack
« Reply #2 on: August 02, 2018, 11:00:05 PM »
I'll try doing that. Still learning how to navigate the forum. Thanks
Offline thecfarm
« Reply #3 on: August 03, 2018, 04:39:37 AM »
Just want to welcome you to the forum.
Offline Logger RK
« Reply #4 on: August 03, 2018, 06:55:10 AM »
Welcome to The Forum,and to owning a Skidder. I don't have any TJ's,but a few TF's.
Offline mike_belben
  • Pulp Friction
« Reply #5 on: August 03, 2018, 09:22:26 AM »
Generic info here.  Bottom of the trans is likely the sump, and it probably has a cover with a strainer behind it.  Maybe an external pipe from down low up to a pump suction inlet.  That pump will make the transmissions flow and the relief valve just past it in the circuit (wherever it may physically be) will set pressure. The seat being pounded, rusted, cracked or jammed with a chip or Oring chunk will lower charge pressure.  As will broken, missing, incorrect or tired spring and any associated shims.  Large enough hydraulic leaks can also lower the ol blood pressure.
Start with your worst leaks first.  My powershift komatsu lost reverse over a trans cooler leak.
Revelation 3:20
Why do we love what we do....?
Started by islandlogger on Forestry and Logging
Last post November 12, 2010, 07:09:36 AM
by Maineloggerkid
I Love This
Started by woodmills1 on Sawmills and Milling
Last post July 13, 2010, 11:00:52 PM
by Meadows Miller
I love
Started by Ronnie on Sawmills and Milling
Last post May 08, 2014, 11:14:53 PM
by SawyerBrown
I LOVE my new hat!
Started by Pete J on General Board
Last post June 18, 2004, 06:37:45 PM
by WV_hillbilly
