Author Topic: Hydraulic hose  (Read 1990 times)
Offline Bruno of NH
Hydraulic hose
« on: August 04, 2018, 09:05:29 AM »
I poked a hole in one or the hydraulic lines on my Sundown/Ingland log grapple this week.
Did it busting down a mixed pile the tree company dropped.
Went to Napa to get a new one made.
Picked up yesterday  $100 for a 3ft hose and 2 fitting.
I almost fell over when they told me the price.
Does that sound right?
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline pineywoods
Re: Hydraulic hose
« Reply #1 on: August 04, 2018, 09:18:10 AM »
Hydraulic hose is a high markup item. Most places charge by the inch. I get most of mine from surpluscenter.com. Still expensive but less than custom made.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
Re: Hydraulic hose
« Reply #2 on: August 04, 2018, 09:58:09 AM »
The hose and fittings are the cheap part it's the hose machine time that costs so much.
Offline 47sawdust
Re: Hydraulic hose
« Reply #3 on: August 04, 2018, 10:42:34 AM »
I feel the same way when I leave my local hyd.shop,but when you are in a jam you don't have much choice.SS seems to be the best deal around but only if you are planning ahead.
Mick
Offline ljohnsaw
Re: Hydraulic hose
« Reply #4 on: August 04, 2018, 11:21:11 AM »
Yeah, they have you over a barrel.  A few years ago I had to have a 5/8" or 3/4" x 6' hose redone and NAPA charged me $90 while I waited about 10 minutes for them to make it.  I spent $1,000 on 17 hoses for my Davis Little Monster but that was cash and at a hydraulic shop.  These were all 1/2" and anywhere from 12" to 24" with the exception of 4 for the outriggers - those were 1/4" x 6" long.
Hydraulic repair is a good business.  My two rams for my SkyTrak cost me $600 for new seals!
John Sawicky
Offline Southside
Re: Hydraulic hose
« Reply #5 on: August 04, 2018, 11:26:07 AM »
4 wire or 2 wire? How big of a diameter? Swivel or other special ends? None are cheap. Easy to spend $30 on just a fitting.
Offline mike_belben
  • Pulp Friction
Re: Hydraulic hose
« Reply #6 on: August 04, 2018, 11:43:11 AM »
Price a crimper, a dozen dies, spools of 2 and 4 wire in every size, and about 500 fittings plus bins to keep em in, reel rack, the chopsaw to cut em and an employee who has the brains to distinguish a JIC 37 vs JIC 45 vs a kobelco vs metric flat face etc etc.. then get back to me on that hundred dollar hose being expensive.
Revelation 3:20
Offline kenfrommaine
Re: Hydraulic hose
« Reply #7 on: August 04, 2018, 11:46:06 AM »
Check out tractor supply they have pre made lengths of hose and sell the different fittings.  These are good quality and very reasonable.
Offline stihltoomany
  • I'm new, but not real new!
Re: Hydraulic hose
« Reply #8 on: August 04, 2018, 12:00:45 PM »
Here in the Midwest that would be totally ridiculous but not knowing what kind of hose and what kind of fittings I should not pass judgement seems very high to me but I go to a hydraulic hose supplier for my hoses
Way too many saws, mostly STIHL
 Bobcat S650, Bobcat 331 excavator
and other dirt toys
Looking for hyd bandsaw mill, Timberking used maybe? NOT anymore!
 WoodMizer LT40 super
Offline Larry
Re: Hydraulic hose
« Reply #9 on: August 04, 2018, 12:13:04 PM »
Most Tractor Supply hoses have IP fittings.
A couple of months ago I went to Ozark Fluid Power and had them make a 30" hose for my tractor FEL.  They use good Parker hose and fittings.  It was in the $30-$40 range and took 10 minutes.  The fittings were a bit uncommon but the hose was common.
If they get too pricey it opens the door for others....crimpers, dies, and supplies can be sometimes found at auction for penny's on the dollar.
Offline Bruno of NH
Re: Hydraulic hose
« Reply #10 on: August 04, 2018, 01:32:06 PM »
It was 3/8 hose 2 wire i think
They called them tractor fittings
I had to reuse 2 rubber/metal washers from the old hose
Offline barbender
Re: Hydraulic hose
« Reply #11 on: August 04, 2018, 01:43:12 PM »
That's not uncommon pricing. I had to replace a 6', 5/8" hose on my Case 1845, it was around $100. I have a dozer blade attachment that I blew a hose on. 3/8"x6', I bought a premade hose with pipe thread ends and fittings for around $40 at the lical farm supply store. If I dealt with more I'd probably buy some bulk hose and reusable fittings.
Offline Southside
Re: Hydraulic hose
« Reply #12 on: August 04, 2018, 02:01:59 PM »
I would expect that to cos me around $50 - $60 given what you added.
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Hydraulic hose
« Reply #13 on: August 04, 2018, 07:24:18 PM »
    Sounds high to me. I get my hoses from the local JD equipment company and I'd have thought a hose as described would be under $35 around here.
Offline bandmiller2
Re: Hydraulic hose
« Reply #14 on: August 04, 2018, 08:08:25 PM »
In my younger days I did excavating, kept a 50' roll of hose in my truck and a box of Aeroquip reusable fittings. It took me no time to make up a hose but those were simpler times. An unmentionable company here sells made up hoses reasonable, keep a couple of spares. You can use a longer hose as a stop gap until you get the right one. Frank C.
Offline beav
  • got any logs?
Re: Hydraulic hose
« Reply #15 on: August 04, 2018, 08:48:03 PM »
Napa in Newport? They have been expensive in my experience. Try Bond Auto ( now O'Reilly's) next time
Offline PAmizerman
  • Just Another Day In Paradise!!
Re: Hydraulic hose
« Reply #16 on: August 04, 2018, 10:25:08 PM »
Sounds expensive. I just replaced a 12' hose on my mill $90
Hydraulics everywhere
Traverse 6035 telehandler
WM bms250 sharpener
WM bmt250 setter
Offline Bruno of NH
Re: Hydraulic hose
« Reply #17 on: August 04, 2018, 11:14:01 PM »
Yes Napa in Newport
Couldn't get anyone to wait on me at orielys
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: Hydraulic hose
« Reply #18 on: August 04, 2018, 11:53:45 PM »
Iím replacing two lift hoses for my Cat forklift.
I called and got an estimated price at the local Cat dealer, $110 each, built at the dealership.
Same thing built at a local hydraulic hose company, $40 each.
Shop around.....
HobbyHardwoodAlabama.com
Offline Southside
Re: Hydraulic hose
« Reply #19 on: August 05, 2018, 08:25:59 AM »
Reading @YellowHammer  reply I suddenly had visions of the Cat guy trying to convince him, in his best Dan Ackryoid / Blues Brothers voice that their hose will be better as it will have "Cat rubber, Cat lettering, Cat smell, Cat receipt".... ;D
Hydraulic hose's.
Started by BargeMonkey on Forestry and Logging
Last post January 25, 2016, 02:31:26 PM
by xalexjx
hydraulic hose
Started by bedway on General Board
Last post September 25, 2011, 12:20:07 PM
by maple flats
Hydraulic Hose Removal
Started by plaindriver on General Board
Last post August 09, 2013, 05:55:52 PM
by maple flats
Hydraulic hose replacement
Started by Magicman on Sawmills and Milling
Last post October 07, 2012, 02:41:47 AM
by Woodchuck53
