Author Topic: Hydraulic hose  (Read 1989 times)
Offline moodnacreek
  • Sawin by the notches
Re: Hydraulic hose
« Reply #20 on: August 05, 2018, 10:24:13 AM »
For the common pipe thread and jic flare ; Surplus center as mentioned but I still use a lot of the old reuseable  fittings that everyone threw away.
Offline Stuart Caruk
  • Gender: Female
  • Woodmizer LX450 DieselStationary timber processing
Re: Hydraulic hose
« Reply #21 on: August 05, 2018, 05:02:23 PM »
I use NAPA for hose and hydraulic fitting ONLY when it's the weekend and I need to get a machine running. Fittings cost about 4 times what the local hydraulics wholesale supply sells them for, and completed hoses are about 2 two 3 times. We have several good hydraulics shops in town. One primarily sells fittings and they are the cheapest in town. The other sells mostly custom fabricated hoses and since that's their specialty, they are the cheapest. I prefer to get my hose made by them because they pull a plug through the hoses to make sure there is no debris left in them, and they put a heat shrink covering on the ends to keep them from getting contaminated during installation. All for the best price in town.
We have 2 NAPAs close to me. One services the farm stuff primarily and the other is more for auto parts. Same name, completely different prices, attitudes, and abilities. They are competitively priced at what they do best. But hoses... not so much.
Stuart Caruk
Wood-Mizer LX450 Diesel w/ debarker and home brewed extension, live log deck and outfeed rolls. Woodmizer twin blade edger, Barko 450 log loader, Clark 666 Grapple Skidder w/ 200' of mainline. Bobcats and forklifts.
Offline Rhodemont
  • Logging and milling just a hobby
Re: Hydraulic hose
« Reply #22 on: August 06, 2018, 11:03:58 AM »
Had to replace a hose on my JD backhoe.  Was quite surprised that the proper part number hose at JD dealer was about half the price of Napa and the hydraulic shop.  Glad I was not in a hurry and was going by JD anyway!
Woodmizer LT35HD    JD4720 with Norse350 winch
Stihl 362, 039, and now an Echo CS-2511T
Offline bandmiller2
Re: Hydraulic hose
« Reply #23 on: August 06, 2018, 08:14:28 PM »
John Deere's pricing for parts is hard to figure. I've got a bunch of old ones and some big parts are reasonable wile some simple little thing they take a tuck on you. Seems they get your confidence up and then nail you. Frank C.
Offline jtmccallum
Re: Hydraulic hose
« Reply #24 on: August 08, 2018, 09:48:35 PM »
Had a 3ft. 3/8 hose with jic fittings made up this at local Case/IH dealer this week.   38.00  We also have a hydraulic shop nearby that is reasonable as well.
John M.        '97 WM LT40Super Manual 40HP Lombardini,  XP372,  MS361, Logrite Cant Hook  CASE 1210 W/ Loader
Offline crowhill
Re: Hydraulic hose
« Reply #25 on: August 10, 2018, 08:23:39 PM »
I read this post couple days ago and thought it had been so long since I had to buy a hydraulic hose I had no idea what my cost had been. Well I found out this morning working the Kubota! Blew three hoses on the loader digging out a six inch black birch stump. 3 lines each less than 30” long, 4 straight fittings @ $13 ea. and two elbows @ $25 ea, hose was $44 and then tax. Came to $154.76 total. A local garage, dropped their wrenches and built my 3/8” @ 4800psi lines.
TimberKing B-20, Kubota M-4900 w/FEL with tooth bar, hyd thumb and forks, Farmi winch, 4 chain saws.
Offline mike_belben
  • Pulp Friction
Re: Hydraulic hose
« Reply #26 on: August 10, 2018, 10:18:17 PM »
Blew a pressure washer hose right at a rub spot a foot from the current fitting.  Chopped it off, went into my bins, found the right end and fired up the trusty old aeroquip.
Back in business.
Revelation 3:20
Hydraulic hose's.
Started by BargeMonkey on Forestry and Logging
Last post January 25, 2016, 02:31:26 PM
by xalexjx
hydraulic hose
Started by bedway on General Board
Last post September 25, 2011, 12:20:07 PM
by maple flats
How to install hydraulic hose
Started by WV Sawmiller on General Board
Last post March 02, 2017, 11:58:47 AM
by Kbeitz
Ruptured hydraulic hose.
Started by Magicman on Sawmills and Milling
Last post August 12, 2009, 09:27:26 PM
by Magicman
