Author Topic: Red flags for long loads question  (Read 1169 times)
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
« on: August 04, 2018, 11:52:47 AM »
I'm looking to buy a box of red flags so that I can give one to customers when they load their trucks or trailers and have a long load hanging out.
I'd like to get the cheap ones that you just staple on or something like that.
I tried an internet search but didn't see what I was thinking about.
Does anyone have a site where they buy 12" square red flags that they give away with their lumber sales?
Thanks in advance.
Jim Rogers
Offline SawyerTed
  • Summey Lumber Services, LLC
Re: Red flags for long loads question
« Reply #1 on: August 04, 2018, 11:56:33 AM »
Have you checked ULINE?  A box of 100 is $17.
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline Jim_Rogers
    • jrsawmill.com
« Reply #2 on: August 04, 2018, 11:57:37 AM »
Just found that, after I posted the question.
thanks
Jim Rogers
Offline Southside logger
« Reply #3 on: August 04, 2018, 02:08:34 PM »
I have contemplated buying a single 2 x 4 from Lowes and then grabbing a big wad of those flags on the way out of the door. Safety First!!!  :D
Offline ljohnsaw
« Reply #4 on: August 04, 2018, 02:33:36 PM »
I was going to suggest the same thing.  But then take the 2x4 back a little later and say you didn't need it (which would be true) :D
John Sawicky
Offline Stuart Caruk
  • Gender: Female
  • Woodmizer LX450 DieselStationary timber processing
« Reply #5 on: August 04, 2018, 06:58:15 PM »
I buy a bag of 50 hand wiping rags in the red, not white color. When a customer needs a flag I grab a dirty one and staple it to the can't. If I can't find a dirty one I'll grab a new one, but I prefer to recycle the old used ones.
Stuart Caruk
Wood-Mizer LX450 Diesel w/ debarker and home brewed extension, live log deck and outfeed rolls. Woodmizer twin blade edger, Barko 450 log loader, Clark 666 Grapple Skidder w/ 200' of mainline. Bobcats and forklifts.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #6 on: August 04, 2018, 07:11:41 PM »
   I keep a roll of Fluorescent flagging tape in the console of of my truck and when I have a long load I tie a piece on there. Not sure about the actual regs as to the size of flag but I'd bet they say so many square inches and whether square or long should not matter. They really do work to warn people against walking into them and should work for other drivers too. Mine current roll is actually hot pink and more visible than red.
Offline Hilltop366
« Reply #7 on: August 04, 2018, 07:14:00 PM »
If someone was going through a lot of them you could get a long roll of red plastic table cloth and cut it into 3 sections, at 300' x 3 sections = 900 flags for around $30.
Offline btulloh
« Reply #8 on: August 04, 2018, 08:52:43 PM »
All good suggestions above.
I keep a roll of yellow safety tape in the truck box.  Very cheap. Just cut of a few feet and tie it around the end of something and let a long end trail behind.  Not sure if it needs to be red, but I've never been ticketed for using yellow.  If you can get a roll of the yellow "Police Line - DO NOT CROSS" it's a real attention getter.
HM126
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #9 on: August 04, 2018, 09:14:42 PM »
I was also going to suggest a bundle of shop rags!
They are usually cheap and they are about 12x12!
~Chuck~
I LOVE MY SAWMILL
Offline Whitman
« Reply #10 on: August 06, 2018, 12:41:54 PM »
I worked in purchasing for a large G &T for 4 years in the start of my 35yrs with them. 12x12
  was law at the time. I found a company that had the size by 500 count boxes. It worked
ok nailing to poles but to steel or alum they taped them on an only 8x8 showed .So several
were used be legal. The problem was solved by getting 18x18 and putting small rock in the
corner taping around it and then to the Alum or steel.
Offline moodnacreek
  • Sawin by the notches
« Reply #11 on: August 07, 2018, 12:49:39 PM »
Is 12" x12" legal?
Offline james
  • truck drivin fool
« Reply #12 on: August 08, 2018, 01:16:26 PM »
size varies by state 18x18 should be legal everywhere 12x12 might not be
james
Offline moodnacreek
« Reply #13 on: August 08, 2018, 07:31:09 PM »
james
Offline btulloh
« Reply #14 on: August 08, 2018, 08:21:56 PM »
Figured I'd use this opportunity to look it up for VA.  12x12.  Lighted at night.
46.2-1121. Flag or light at end of load.
Whenever the load on any vehicle extends more than four feet beyond the rear of the bed or body thereof, there shall be displayed at the end of the load, in such a position as to be clearly visible at all times from the rear of the load, a red flag, not less than twelve inches, both in length and width. Between sunset and sunrise, however, there shall be displayed at the end of the load a red light plainly visible in clear weather at least 500 feet to the sides and rear of the vehicle.
Code 1950, 46-304; 1958, c. 541, 46.1-300; 1989, c. 727.
HM126
thumbup
Flags
Started by Magicman on General Board
Last post May 25, 2013, 02:07:09 AM
by Howdy
Flags Half staff today
Started by jdtuttle on General Board
Last post December 08, 2011, 07:56:01 PM
by Warbird
lamp
new guy question, why do & how long,,,,,
Started by robotguy on Forestry and Logging
Last post April 05, 2004, 07:41:32 AM
by Mark M
How much risk...long question
Started by edge on Chainsaws
Last post April 11, 2005, 09:05:56 AM
by slowzuki
