Author Topic: Woodmaster RazorTip Carbide blades  (Read 885 times)
Offline Geeg
  • Living the Dream!
« on: August 04, 2018, 06:05:28 PM »
Was wondering if anybody is using RazorTip Carbide blades. I heard that they may last 10 times longer? How about sharpening? Any pros or cons on these versus standard blades.
Airbus 380 Captain, living in the Middle East, counting down the days till retirement. Timberking 2200,  Kioti RX6010PC,  Nyle Kiln KD250, Polaris WV850
Offline Beavertooth
Re: Woodmaster RazorTip Carbide blades
« Reply #1 on: August 06, 2018, 03:01:14 PM »
I have not run any of the carbide blades but have been running some bi-metal turbo 7's from Woodmizer. They cost me exactly twice as much as the double hards cost and in my opinion I will save money in the long run. Reasons are that they do run 2 to 3 times as long before becoming dull, that means less time changing blades and less money spent on sharping them, they are suppose to have longer flex life because the entire blade is made out of a different material not just the tip (Woodmizer  told me that the carbides did have 5 times the flex life as the double hard) but did not have an exact number on the bi-metals but that it was longer. The only way you would lose money on them is to hit something that would tare them up but I am also sure that I have lost many double hard blades to nails that I would not have lost if the blade would have been a bi-metal so still better I think in the end with the bi-metal. And running the turbo 7's is definitely making more money for me than running any other profile since I can cut a very noticeable amount faster with them. I do not remember what profiles and blade thickness they make in the carbide.
2007 LT70 Remote Station 62hp cat.
Offline Percy
  • Resident trouble maker
« Reply #2 on: August 06, 2018, 06:38:44 PM »
On occasion, I have to cut a full container load of 1x6x13(metric). This involves a lot of resawing cants/2inch etc. For resawing, I will use the carbide blades. They are mega expensive but I can resaw a full container without changing blades. Double hards would be at least 10 blade changes. At 5 min per change, thatís 50 miniutes or about 1600 bdft of resawing. With a full crew handling and packaging, ithe blades pay for themselves easily. As long as the wood is clean and no nails yadda, they are a good investment. Profit goes out the window on first nail nugget whatever.  Las Vegas 🤓
Offline pineywoods
« Reply #3 on: August 06, 2018, 09:17:40 PM »
I tried a couple. Wider teeth require more hp. Cut nicely, but load down my 25 hp mill noticeably.
Offline Percy
« Reply #4 on: August 06, 2018, 10:32:00 PM »
On occasion, I have to cut a full container load of 1x6x13(metric). This involves a lot of resawing cants/2inch etc. For resawing, I will use the carbide blades. They are mega expensive but I can resaw a full container without changing blades. Double hards would be at least 10 blade changes. At 5 min per change, thatís 50 miniutes or about 1600 bdft of resawing. With a full crew handling and packaging, the blades pay for themselves easily. As long as the wood is clean and no nails yadda, they are a good investment. Profit goes out the window on first nail nugget whatever.  Las Vegas 🤓
Offline Geeg
  • Living the Dream!
« Reply #5 on: August 08, 2018, 11:04:12 PM »
Thanks for the info Gents, I may buy both and like Percy mentioned, just use the carbide for the stuff that I know will not have any metal.
Offline shenandoahsawmill
« Reply #6 on: August 09, 2018, 09:44:04 AM »
Something else to consider as a plus to the carbide or stellite tipped blades is that they do stay sharper, two to three times as long as standard blades which leads to fewer thick/thin cuts over the life of the blades. Some of us change blades when the blade on the mill starts cutting thick/thin boards. With the blades staying sharper longer, it means more good boards over the life of the blades.
Offline woodyone.john
« Reply #7 on: August 09, 2018, 02:21:03 PM »
Another advantage of tipped blades is the set lasts so much longer as the tip provides the clearance.Sharpening blades is easy [with a cbn sharpener] accurate setting takes me longer.As any body who has used them will tell you striking metal is the pits.
Saw millers are just carpenters with bigger bits of wood
WM razortip blades
Started by qbilder on Sawmills and Milling
Last post November 01, 2010, 07:15:12 PM
by poolman
Carbide tiped blades
Started by arj on Sawmills and Milling
Last post November 08, 2006, 10:17:03 PM
by WH_Conley
carbide band blades
Started by Engineer on Sawmills and Milling
Last post February 01, 2007, 06:33:20 PM
by D._Frederick
Razor Tip Carbide blades
Started by ncsawyer on Sawmills and Milling
Last post August 21, 2017, 12:05:26 AM
by Percy
