Author Topic: Another tool for use around the woodlot - Kobelco ED150 BladeRunner  (Read 3435 times)
Offline nativewolf
Re: Another tool for use around the woodlot - Kobelco ED150 BladeRunner
« Reply #20 on: August 21, 2018, 07:25:17 AM »
so my mechanically inclined friends, does that heel rack and rotating grapple come as something one can buy off shelf or is the heel rack custom?
Skeans and Stuart, what's the hydraulic flow on one of those?  I'd like to be able to put a small mulching head on it once in a while and do a little site clearing.
Liking Walnut
Online Skeans1
« Reply #21 on: August 21, 2018, 07:31:55 AM »
We built the heel rack, quick attach, and all the guarding for that machine. Theres companies such as Jewell or Pierce Pacific that build heel rack and grapples for shovel logging, if we did it again wed probably go with a built up 120 or 130 shovel the only bad part is they weigh a good share more then the standard excavator if I had to guess theyd be north of 55K.
To the mulching head yes they can a friend has two Doosan 140s with rotary brushing heads on them.
Offline mike_belben
  • Pulp Friction
« Reply #22 on: August 21, 2018, 11:40:25 AM »
Dont let insufficient hydraulic flow stop you from snagging up an otherwise good machine.  Its not hard to set an auxiliary hydraulic unit-  motor/pump/tanks cooler etc- on the bridge opposite the operator station to power a high flow attachment.  Drum flail is just an on off tool so solenoid valves and wired in switches to the cab are easy.    excavators converted ti scrap yard use  run a complete standalone generator sitting there to power the mag.  Not hard to take it off and switch to grapple.  No reason it cant be hydraulic rather than electric.
Revelation 3:20
Online 2308500
« Reply #23 on: August 21, 2018, 08:13:55 PM »
we have welded worn out impact sockets onto the end of the reamers that had a morse taper, never had any problems with em. did hundreds of holes in truck chassis over the years mounting hitches and moving components around.  the reamers are worth every penny if you need em.
Offline Stuart Caruk
  • Gender: Female
  • Woodmizer LX450 DieselStationary timber processing
Stuart Caruk
Wood-Mizer LX450 Diesel w/ debarker and home brewed extension, live log deck and outfeed rolls. Woodmizer twin blade edger, Barko 450 log loader, Clark 666 Grapple Skidder w/ 200' of mainline. Bobcats and forklifts.
  • Gender: Female
« Reply #25 on: September 04, 2018, 08:04:41 PM »
Well, I'm tickled. I found a used set of blade wings for my ED150. It took a bit of work to get them to fit, and no matter what I did, the last set of holes was off about 1/16". Simple solution, out came the Bridge Reamer and now it's all good.
I know own an excavator with a fully functioning 6 way blade. I can drive it since I installed a pattern changer and now have either CAT or JD control patterns available. First time I've owned an excavator with mirrors and AC. So far it's proven to be a really useful tool.
Stuart Caruk
  • Gender: Female
Excavator Stump Splitter / Saw
« Reply #26 on: September 04, 2018, 08:09:45 PM »
Now that I have a big enough machine, It's time to build a stump splitter for it. Since it was a holiday weekend, and customers weren't around to bug me, I whipped out some parts from T1 plate that were bump formed in the press.
Tacked up it now looks like this...
Kneeling on the floor proved to be a bit much, so I slapped it on a pallet. The forklift will bring it up to a comfy welding height to finish it up. I need to go grab some 65mm pin stock and a chunk of 4140PH in the morning to help finish it up.
Stuart Caruk
Offline mike_belben
  • Pulp Friction
« Reply #27 on: September 04, 2018, 11:04:28 PM »
Ohhhh baby....
Revelation 3:20
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #28 on: September 05, 2018, 12:41:38 PM »
That has all sorts of sexy in it.
Online thecfarm
« Reply #29 on: September 05, 2018, 08:39:56 PM »
And it all fits together nice and snug. Good job. We going to see it on the new tool? ;D Action video?
  • Gender: Female
« Reply #30 on: September 06, 2018, 02:11:02 AM »
I picked up a remnant 65mm induction hardened bar for the pins, and a 4" x 5" x 22" remnant of 4140 prehard for the cutting bit this morning. I've already got several feet of 4 1/2" 4140 PH for the bushings, then it will go together. I've got a monster maple stump that will give this thing a good test, as well as about 30 fir stumps from 28" to 52" in diameter that need to come out. I gave up with the stump grinder after a half dozen. I'll be sure to get a video for you.
Stuart Caruk
Offline Haleiwa
  • Clinton county, New York
« Reply #31 on: September 06, 2018, 01:03:43 PM »
That looks like a good machine.  As to plumbing a grapple, i used to have a 50 ton Koehring with a clamshell bucket to clean irrigation ditches.  The rotator and pinch controls we're toggle switches on top of the joysticks.  The valves were on the main machine, and hoses ran out the boom.  It was a pretty good system.
Socialism is people pretending to work while the government pretends to pay them.  Mike Huckabee
  • Gender: Female
Excavator stump splitter/saw
« Reply #32 on: September 18, 2018, 04:56:28 PM »
Well, I finally found time to finish up my stump splitter/saw. Interesting tool. Considering I took a picture of a similar one and redrew it in a CAD system it fits perfectly. The pivot point lines up flawlessly so that if you set the tooth on a stump and curl the bucket, it neatly slices a slot about an inch wide  by 10 inches deep. On a small stump less than 24" or so you curl the wedge into the slot, and the stump splits, making it simple to grab with the thumb and rip out.
On big stumps my 40,000 pound machine just doesn't have the power to split really big fir stumps, so I need to resort to the old proven technique of ripping out the lateral roots to help loosen it. This thing shines at this. Instead of digging a massive hole, you simply curl the saw and slice through the roots. Working around the stump down to about 6' usually does it, then you can split, or pop the sucker loose.
This was a massive clump consisting of 3 large maple trees, intertwined with 3 medium to large fir stumps. I figured dynamite would be required. I was able to split the smaller fir and maple stumps and rip them out. Then you can see where I sawed up the roots to separate them so I would have any hope of getting them out. A bit of effort and I had the mess out of the ground. Here's one of the wads... I can't lift it even curled in, as my boom cylinder goes over relief. So that's around 15,000 pounds of stump. It's a lot bigger than it looks. But, with the blade and this tool and the thumb, it was simple enough to drag over to the stump pile to rot.
Coolness! OF course now the problem is that I can rip out stumps that I can barely move... I need a bigger excavator...
Stuart Caruk
Online thecfarm
« Reply #33 on: September 18, 2018, 05:26:31 PM »
Now that's a weapon!!!!
Online barbender
« Reply #34 on: September 18, 2018, 06:04:47 PM »
That's awesome!!👍👍
Offline mike_belben
  • Pulp Friction
« Reply #35 on: September 18, 2018, 07:16:30 PM »
Came out incredible. Howd you roll the plate contour?
Revelation 3:20
  • Gender: Female
« Reply #36 on: September 19, 2018, 05:50:43 PM »
It's bump formed in a press brake with a radiused upper die. Marked every 1 1/2" push to line tap closed, and repeat.
Stuart Caruk
Online Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #37 on: September 19, 2018, 08:52:00 PM »
There's a similar contraption on YouTube. I think the channel is Northwest Sawyer.
Offline Chop Shop
« Reply #38 on: September 22, 2018, 07:12:33 PM »
That splitter came out great.
One thing to keep in mind, its not a bulldozer.  Dozers have gear driven drivetrain and steering clutches, not hydro drive motors and planetaries.
I know when looking at 75 sized machines which are common with blades many need or have had track drive motors replaced.  Used track motors are impossible to find because of the demand.
A heavy machine will push dirt good, but its hard on drives.
Online Dave Shepard
    • My homepage
« Reply #39 on: September 22, 2018, 07:20:39 PM »
Bulldozers have had hydro drives for a coupl decades now. The Bladerunner machines have beefed up under carriages to accommodate the blade.
Another Woodlot tool
Started by Wood Shed on Firewood and Wood Heating
Last post November 18, 2018, 10:58:48 AM
by hedgerow
Kobelco 909 LC II excavator - need help with a log grapple
Started by Southside logger on Forestry and Logging
Last post November 04, 2013, 12:57:24 AM
by OlympicYJ
Tractor 3pt Multi-tool - And Another Log Handling Tool Added
Started by tcsmpsi on General Board
Last post February 08, 2007, 07:18:52 PM
by SPIKER
A bad day in the woodlot
Started by Ox on Sawmills and Milling
Last post June 15, 2015, 11:45:30 PM
by Brucer
