Author Topic: Vacutherm iDry input  (Read 23400 times)
Offline Stephen1
    • muskoka Sawmill
Re: Vacutherm iDry input
« Reply #280 on: March 26, 2019, 08:15:17 AM »
Have a great road trip!
I had a small water problem at the kiln with a pin hole leak in the 3/8 water supply line. I called and a new line is on the way. Brian's comment was that "we paid extra to get a braided high pressure line"
The kiln runs at 130-140 F as it cycles thru the heat and the fan.
I hope to be there tonight when it drops the vacuum. I want to pull out the load and see what is and what is not dry.
I also have my 1st customer 8)coming on Thursday with a small load of fresh sawn maple
Offline flatrock58
« Reply #281 on: March 26, 2019, 09:50:23 PM »
Been keeping up with this post.  It has been mentioned that oak is harder to dry with this kiln than other woods.  Has anyone dried red or white oak yet.  If so how long did it take?  Thanks
2001 LT40 Super Kubota 42
6' extension
resaw attachment
CBN Sharpener
Piney Woods modified Dual tooth setter.
Offline NC Daniel
« Reply #282 on: March 27, 2019, 11:33:30 AM »
I think I saw a post on their website where someone dried a load of 5/4 White Oak, 1 month air dried then took 13 days in the kiln
Woodmizer LT40SHDWide, iDRY 2.0
Offline Stephen1
    • muskoka Sawmill
« Reply #283 on: March 28, 2019, 11:37:51 AM »
I am opened the kiln on Teusday night. The temp of the kiln was at 140F. I pulled some cookies out to test. ( some were still solid and some were checked) I also put in some air dried Walnut pieces,  to fill up the space in the kiln. A full load is better or you need to baffle a partial load.
They seemed very dry and they were at 8%. I am also trying to learn the moisture meter.
I am opening the kiln this afternoon as I have my 1st customer coming with a small load of maple. I plan to pull the maple and poplar and cookies out. I will leave the pine slabs. I will update for everyone.
I will load more of my air dried Walnut-Elm. I will load the customers maple and fill the space with more cookies and ovals.
Offline Stephen1
    • muskoka Sawmill
« Reply #284 on: April 02, 2019, 12:57:02 PM »
Well here is an update. I fixed the water leak, replaced the line. I pulled out the load on Friday morning. I left the kiln shut down from Thursday night. The 4/4 poplar and maple were dry, also the birch and cherry cookies, all down to 6-8%
The EWP was mixed %. The 16 x2 pieces  were down to 8.8%. I pulled them out of the kiln.
The bigger 24 were mixed, some probe locations were8% some 12% , some 18% I only used the hand held probe.
I loaded the kiln with customers 300 bd ft of 7/4 maple on the bottom filled by new EWP 24 x2 then the almost dried EWP . On top of all that I placed air dried  coffee table live edge walnut and elm. To fill the empty spaces I loaded about 100 birch and cherry cookies/ovals. A real mixed load.
I would like to put other wood in but winter will not quite up here and a lot of my wood is still buried in the snow and ice. What isnt buried my little bobcat cant lift with the added weight of the snow and ice on top.
Offline Just Right
    • JustRightSawing
« Reply #285 on: April 08, 2019, 08:53:57 AM »
Got back with the kiln after 2 flats and a sick Ford.  Injection pump is going.  But all that behind us now.  Going to start on the concrete pad this morning.  Hoping to pour Wed or so.
If you are enjoying what you are doing,  is it still work?
Online Southside
« Reply #286 on: April 08, 2019, 09:09:14 AM »
Is the pump throwing metal into the tires and causing them to go flat or something?   :D
Offline Stephen1
    • muskoka Sawmill
« Reply #287 on: April 08, 2019, 09:16:07 AM »
I'm glad your home safe. nothing like an adventure to get started with. How many miles was your road trip, mine was a total of 1000 miles there and back, since my truck is american I am still in miles, I never switched it over to Kilometers
Offline briankingsbury
« Reply #288 on: April 08, 2019, 11:56:22 AM »
We just tested a water feed pump if anyone wants to do a recirculated system.
https://www.freshwatersystems.com/products/aquatec-5853-gb12-v81d-variable-speed-pump-0-1-1-0-gpm-40-psi
Offline Just Right
    • JustRightSawing
« Reply #289 on: April 08, 2019, 09:39:06 PM »
LOL Southside you made me laugh.  I wish it was a coordinated group effort to do me in.  One flat on trailer and one on the truck.  Just luck of the draw on the truck.  But the trailer . . . . . it is evil 8 new tires with less than 6000 miles on them.  And I have had to replace 4 already.  Axles must be tweaked.  And the injector pump is just time for a new one.
Stephen,  it was about 2500 miles round trip.  Took a week to do it,  but me and lil Wiffie made a good road trip out of it.  Figured I'd prepay her before she figures out that she will be helping me load and unload that kiln!
Offline Just Right
    • JustRightSawing
« Reply #290 on: April 08, 2019, 09:41:28 PM »
And Brian,  Now that I know the vacuum pump and the drain from the inside of the kiln are two different things that is a good idea.  Problem is I just finished the ditch to bury my water supply.  LMAO
Online Southside
« Reply #291 on: April 09, 2019, 12:18:23 AM »
Just Right, I got sick of crappy trailer service tires and went to 14 ply G's in 16", keep them at 100 PSI and never had a flat again.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #292 on: April 09, 2019, 06:37:56 AM »
Me too, 100%, take off the Es and roll with the Gs. I get mine at the local farmers COOP.
HobbyHardwoodAlabama.com
Offline Just Right
    • JustRightSawing
« Reply #293 on: April 09, 2019, 10:35:01 AM »
Thanks for that advice.  I don't like that trailer anyways.  It is a tag along.  I love the goose necks.
Had a decent day yesterday getting the slab and underground utilities ready.  Worked till dark getting this 100 ft ditch dug.  Then it stormed all nite and I am sure flooded it.  Good thing I took the time to make sure it could flood all my ditch and not just a part of it!  LMAO.
Offline Stephen1
    • muskoka Sawmill
« Reply #294 on: April 09, 2019, 12:19:33 PM »
My only problem, is the 100psi and I find my tires are going bald in the Center as I run empty half the time. How do you guys get around that or is it the nature of the beast?
Online Southside
« Reply #295 on: April 09, 2019, 12:22:08 PM »
I have not had that problem with my G's, they are hard as rocks so not much difference loaded or unloaded. It is fun to watch the tire guy try to put them on the rim sometimes.
« Reply #296 on: April 10, 2019, 10:07:09 AM »
My biggest problem is that people always seem to want to pull out in front of me and I have to end up standing on the brakes, occasionally smoking the tires.  Unfortunately, standing on my horn and giving them what for doesnt do anything about the new flat spots.
Offline Stephen1
    • muskoka Sawmill
« Reply #297 on: April 10, 2019, 08:50:28 PM »
YH Flat spot are the norm when its empty especially
I asked Brian at IDRY about sterizlizing or Heat Treating wood in the kiln. He mentions remote units so I do not have to drill a hole in the the kiln.
Anybody using one of these units ?
who does HT and how do I find out more info?
Stephen
Offline PA_Walnut
« Reply #298 on: April 12, 2019, 05:51:40 AM »
I had a neighbor complaining about the same thing until one day he came home and was super-excited to tell me that he had someone pull out and try to block him in a cattle-chute. Said, I had enough and mashed'er to the floor (big F350 beast). Explained, "I docked with him and pushed him down the highway about 100 yards or so...when the cops came, said I told them that idiot swerved in front of me and when I stabbed for the brakes, I accidentally hit the throttle and it stuck". Said the cop kinda smirked and continued on with paperwork. I'm assuming that they no longer attempt lane-blocking. :o I have a couple stories of my own, which include going "agricultural". :D
LT40HD Wide 35HP Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Northland 800 Kiln
Offline Just Right
    • JustRightSawing
« Reply #299 on: April 13, 2019, 09:04:56 AM »
PA I love your style!  I so wanted to do that on several occasions!!!!!!!!!
Please welcome our newest sponsor! iDRY Vaccum kilns
Last post December 02, 2018, 08:04:14 AM
by fishpharmer
Looking for some input
Started by summerboy1958 on Chainsaws
Last post June 26, 2015, 09:12:01 PM
by Ianab
I would like a little input
Started by peter nap on Forestry and Logging
Last post February 27, 2009, 08:24:07 AM
by Chico
looking for input
Started by little-guy on Sawmills and Milling
Last post January 06, 2006, 01:35:12 AM
by little-guy
