Author Topic: LT35HD Hydraulic Electrical Connection  (Read 427 times)
Offline Rhodemont
  • Logging and milling just a hobby
« on: August 06, 2018, 11:25:53 AM »
This weekend my hydraulics did not always make electrical connection when I returned the head to home to use them.  Many times I had to jog forward or back a couple inches and they would start working.  Wiped of the copper bus bar which looks tarnished but no dust or crude on it. This seemed to help some but still needed to jog some times after that. Do I need to go in and clean up the contact in the carriage and how do you do that? Should I be doing some PM regularly that I am missing?
Woodmizer LT35HD    JD4720 with Norse350 winch
Stihl 362, 039, and now an Echo CS-2511T
Offline Chuck White
  • Sawing Mobile since 2005
Re: LT35HD Hydraulic Electrical Connection
« Reply #1 on: August 06, 2018, 11:56:13 AM »
I don't know all that much about the LT35, my mill is an LT40!
On my mill there is a spring-loaded ground contact that rides along on the bottom rail, maybe it needs to be cleaned up a little!  That spring-loaded contact is only for the hydraulics!
It could just have a little sawdust in there that interferes with the ground!
~Chuck~
Offline taylorsmissbeehaven
« Reply #2 on: August 06, 2018, 12:16:20 PM »
I clean mine every so often with a light sand paper or emory cloth and wipe down with ATF. That having to jog about is annoying! Brian
Opportunity is missed by most because it shows up wearing bib overalls and looks like work.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #3 on: August 06, 2018, 12:49:31 PM »
   Pretty common problem. Last time it happened to me WM said tighten the little spring connector. I did and has worked fine ever since. May even be a slight bow in the copper bar allowing better or worse connections at different spot.
Offline John S
« Reply #4 on: August 06, 2018, 01:31:31 PM »
Yes, if the 35"s have the same spring loaded arm that contacts the strip, you may have to move slightly closer to the strip.  I have had this situation with both LT40's that I have owned.
2018 LT40HDG38 Wide
Offline Rhodemont
« Reply #5 on: August 06, 2018, 02:17:16 PM »
I will clean the copper strip with some fine steel wool, coat with ATF and tighten the spring loaded contact.
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #6 on: August 06, 2018, 07:53:03 PM »
If it was all hydraulics that didnt work then suspect the copper strip and contacts there.  If it was just individual circuits, there is a micro switch on each valve that needs to be adjusted. The manual explains how. The micro switch activates the pump to power that circuit.
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline PAmizerman
  • Just Another Day In Paradise!!
« Reply #7 on: August 06, 2018, 11:27:14 PM »
Pretty good chance it's the micro switch.
I've been through 3 already. I always keep a spare on hand
Hydraulics everywhere
Traverse 6035 telehandler
WM bms250 sharpener
WM bmt250 setter
