Author Topic: Blade guide on lt30  (Read 437 times)
Offline kenlt30
  • I'm old
Blade guide on lt30
« on: August 06, 2018, 05:27:58 PM »
Blade guide motor trips the breaker, any ideas?  Worn brushes maybe?
Online Southside logger
Re: Blade guide on lt30
« Reply #1 on: August 06, 2018, 06:11:52 PM »
More likely a dead short somewhere along the line. Under hook the motor and see if it still trips, then you will have a starting point.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #2 on: August 06, 2018, 06:47:47 PM »
My guess would be "the brushes"!
~Chuck~
I LOVE MY SAWMILL
Offline YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
« Reply #3 on: August 06, 2018, 09:24:38 PM »
Is the blade guide arm jammed?
HobbyHardwoodAlabama.com
Offline kenlt30
  • I'm old
« Reply #4 on: August 07, 2018, 11:10:21 AM »
Blade guide will move normally for a few times before the breaker trips. Thanks for the replys, I'll disassemble when the weather cools.
Outer blade guide adjustment cable replacement on manual lt30
Started by Jeff on Sawmills and Milling
Last post May 28, 2010, 09:18:52 AM
by trapper
my acme band saw blade (captive needle bearing )roller blade guide
Started by buildthisfixthat on Sawmills and Milling
Last post January 16, 2012, 09:34:15 AM
by 5quarter
Caution!!! Potential Pinch Hazard.....LT30 blade tension lever
Started by Slingshot on Sawmills and Milling
Last post October 31, 2010, 11:00:34 PM
by Slingshot
Blade guide arm
Started by Hale87 on Sawmills and Milling
Last post August 11, 2011, 09:48:52 AM
by york
